Old 04-27-2008, 11:21 PM
tanglediver's Avatar
tanglediver tanglediver is offline
Question Math question.
I have a right triangle with angles of 90 degrees, 31 degrees and 59 degrees. I know the length of one side, the longer side of the right angle, it is 0.086".
How can I find the length of the other side of the right angle?
Job 28:1,2
E-tig;SP135t;XMT304;NKJV Bible
Danny
Old 04-27-2008, 11:45 PM
Broccoli1's Avatar
Broccoli1 Broccoli1 is online now
Re: Math question.
http://www.mathsisfun.com/pythagoras.html
Old 04-27-2008, 11:49 PM
DSW DSW is offline
Re: Math question.
It can be done with basic trig functions.
Tan of an angle= opposite length / Adjacent length.
Sine of an angle= opposite length / Hypotenuse.
Cosine of an angle= Adjacent length / Hypotenuse.
So if the angle is 31deg, the adj side is the long one at 0.086
tan59= unknown length / 0.086
0.086* tan 59 = Unknown length.
I can't find my trig calculator right now or I would do the math for you.
As long as you know the angle and one length you can find any of the others on a right triangle.
Hope this helps.
Old 04-28-2008, 12:26 AM
Brett's Avatar
Brett Brett is offline
Re: Math question.
0.05167
A good guess is better than a bad measurement
Old 04-28-2008, 12:49 AM
Re: Math question.
I knew I would end up with a headache!
I found .051 after googling this up...
http://www.mathopenref.com/righttriangle.html
...I knew there is a formula of some trigometric sort, but not which or how to use it.
Where is that "Bang Head Here" sign?
Thanks for the clues, for sure!!
Job 28:1,2
Danny
Old 04-28-2008, 05:10 PM
Magnetic_re's Avatar
Magnetic_re Magnetic_re is offline
Re: Math question.
2 2 2
A+B=C(longest side of triangle)
Old 04-29-2008, 12:28 PM
wannabe_welder wannabe_welder is offline
Re: Math question.
Originally Posted by Magnetic_re View Post
2 2 2
You need at least 2 sides for that to work.
Old 04-29-2008, 09:56 PM
Thumbs up Re: Math question.
http://i176.photobucket.com/albums/w...r/P4270011.jpg
Here is the drawing with the problem and the answer that I wrote in. Then I found the trig functions explained well enough in the "Machinery's Handbook", page 91 of the 27th edition, so that I could punch the numbers into my scientific calculator. I never took triggernometry!
Job 28:1,2
Danny
Old 04-30-2008, 04:35 PM
DesertRider33's Avatar
Re: Math question.
Queen SohCahToa
MM350P/Python/Reach/Q400
MM175/Q300
DialarcHF
HTP MIG200
PowCon 300SM
HyperthermPM380
ThermalArc185
Victor o/a
-F350 CrewCab4x4
-LoadNGo utilitybed
-Bobcat250NT
-XMT304/Optima/XR/Spoolmatic
-Suitcase8RC/Q300
-Passport/Q300
-JacksonEQC
Old 05-01-2008, 11:28 PM
William McCormick Jr's Avatar
William McCormick Jr William McCormick Jr is offline
Re: Math question.
What angle is using the known side as one ray from its vertex?
Sincerely,
William McCormick
Old 05-02-2008, 12:04 AM
dabar39's Avatar
dabar39 dabar39 is offline
Re: Math question.
Here's a real simple and easy way to figure out your math problem with out a lot of math involved. Dave
This was done real quick on scrap paper as an example, to make it work you must use a ruler and protractor!
I am what I am, Deal with it!
If necessity is the Mother of Invention, I must be the Father of Desperation!
Old 05-02-2008, 12:08 AM
Brett's Avatar
Re: Math question.
Sincerely,
William McCormick
Two are William,
The 90° and the 31°
Old 05-02-2008, 01:54 AM
Lightbulb Re: Math question.
Dude, when was the last time you took an I.Q. test? That is sheer genius!
Job 28:1,2
Danny
Old 05-02-2008, 08:35 AM
dabar39's Avatar
Re: Math question.
No genius here, just had to improvise out in the field many, many times. Dave
Old 05-03-2008, 01:45 AM
Re: Math question.
Originally Posted by Brett View Post
Two are William,
The 90° and the 31°
The Cosine of Angle 31 is 0.8572 It is in a table in a book under 31 degrees cosine.
Hypotenuse = The side you know, 0.086 divided by 0.8572 =0.10032664489034064395706952869809
Sincerely,
William McCormick
Old 05-03-2008, 02:10 AM
Re: Math question.
Two are William,
The 90° and the 31°
Here are the formulas. It is funny in this book they misprinted the book. And the tables for the angles are wrong.
This book clearly defines how to use the formulas though, and the angle values. I use another book or a calculator for the angle values.
http://www.Rockwelder.com/WeldingWeb...ctformulas.JPG
Sincerely,
William McCormick
Old 05-03-2008, 07:19 PM
Tinbasher's Avatar
Tinbasher Tinbasher is offline
Re: Math question.
Two ways to do it using tangent function...if I am understanding your question correctly
Name:  trig problem 004.jpg
Old 05-03-2008, 08:37 PM
Re: Math question.
Attachment 19322
0.052 is correct!
William, I used a formula from that same list along with my calculator also. Once the data was input correctly, I got an answer that made sense.
Job 28:1,2
Danny
Old 05-06-2008, 01:05 AM
Re: Math question.
0.052 is correct!
I used the formula to find the hypotenuse. I thought that was what you were looking for. Then I went back and reread it. And saw you wanted the smaller side.
I cannot figure triangles without a book or cheat sheet.
Sincerely,
William McCormick
Old 05-09-2008, 05:09 PM
Donald Branscom's Avatar
Re: Math question.
2 2 2
Then devide by 2 to get the awnswer.
Old 05-11-2008, 12:47 PM
Sandy Sandy is offline
Re: Math question.
Here are a few of the Alt/Numbers combo keys here.
Sometimes there are other combinations that will do the same things. Even just three digits.
Depends on which text type and bla bla yadda yadda.
Play around with them.
Hold the Alt key and hit these numbers on the Nums key pad for these;
0178 = ² squared
0179 = ³ cubed
0247 = ÷ divided by
0215 = × multiply by
0176 = ° degree, also 167, 248
0162 = ¢ cents, also 155
Old 05-11-2008, 01:29 PM
smokeshow smokeshow is offline
Re: Math question.
¼ ( 172 )
½ ( 171 )
¾ ( 0190 )
° ( 248 )
² ( 253 )
√ ( 251 )
± ( 241 )
≥ ( 242 )
≤ ( 243 )
+ ( 43 )
☺ ☻ ♥ ♦ ♣ ♠ • ◘ ○ ◙ ♂ ♀ ♪ ♫ ☼ ► ◄ ↕ ‼ ¶ LOL.. sorry I got carried away... I used to send alt messages to people as a coded messages... I won't get into all of that but I have used them way too much.. and a lot of them repeat several times... the only difference is how many numbers you have to put in...
Old 06-04-2008, 07:02 PM
Re: Math question.
Are you saying AxA + BxB = CxC ?
The square root of AxA + BxB = the length of side C or the hypotenuse of the triangle.
Sincerely,
William McCormick
Old 06-22-2008, 12:57 AM
TEK TEK is offline
Re: Math question.
WOW....that sure went off on a tangent.......( i'm sorry, really, i am)
Old 06-22-2008, 09:28 AM
Mondo's Avatar
Mondo Mondo is offline
Re: Math question.
The way I learned trigonometry in electronics school was to remember these relationships:
Square of the length of side A plus the square of the length of side B equals the square of the length of side C. This editor does not support superscript so I will post an image:Name:  Pythagorean.jpg
Next, a phoney Indian word:
Soh Cah Toa (say it like this: So C-ahhh Toe-a)
Sine = length of side Opposite the angle divided by length of the Hypotenuse
Cosine = length of the side Adjacent to the angle divided by the length of the Hypotenuse
Tangent = length of the side Opposite the angle divided by the length of the side Adjacent to the angle.
If you have any two values of either of the above items you can calculate all the others.
We needed to learn this to calculate things like RMS voltage and energy in AC circuits, and other esoteric things like plotting the load line of a Class A transistor amplifier. But the same formulae are handy for any carpenter, fabricator, or just about any other tradesman.
keep on keepin' on.
[IMG] code is Off
