Old 05-06-2008, 10:19 PM
rumme rumme is offline
My Chinese expireince
I am a hobbyist and read about the 3 in 1 mutli function chinese units on ebay for several weeks. I finanly ordered one about a month ago and heres my expriencne so far :
the seller on ebay had 100% postive feedback and the unit was a Simadre 416 for $499 shipped { from China even though the ebay seller was listed as living in California }
the unit took a few days longer to get here, but the seller sent me free consumables to make up for the slight delay. It was packaged well and all components were unharmed in shipping.
Negatives :
some of the chinese hose clamps are chessy so I went with american made clamps. The air regulator has a small air leak around the plastic bowl area where it threads on. Wehn using the plasma cutter today, it started to only work intermitnently. I found out that a small metal pin in the thumb trigger had backed out of its hole a bit and wasnt allowing the thumb trigger to make contact to kick the plasma cutter on. I pushed the pin back in and epoxied it and the problem has now been permanently fixed. Finally, the instruction manual isnt very good but anyone with a bit of common sense can figure out how to setup the unit { there is a troubleshooting guide in the back of the manaul to try and help diagnose any problems that may arise, but its mostly a joke.
Postives :
Ive used this unit for about a month now and have used the plasma cutter and stick welder for :
7-8 gauge flat plate steel
12-14 gauge galvanized steel culvert
sheet metal roofing.
I have built a woodstove, welding cart and am in the process of building a large underground steel culvert storm shelter. The unit has performed nicely and if it performs this nicely for only a couple years, I will be satisifed , It is the best $499 Ive spent in a long time. ....{ im using 220 volts and using a Homier 110 volt - 15 gallon - 4 hp compressor to power the plasma cutter at 70 psi } .
I hope this review helps others and if you have any questions, feel free to ask and I will try to answer.
{ and no, I am not a dealer. I am just trying to help others make a informed decision based upon my expierience keeping in mind that i am a hobbyist and dont use this unit everyday...8 hrs a day out in the field. }.
So far, I give the unit a rating of B+ considering its features, cost, portability/ weight and performance. I have no idea if it will hold up for a few years and I did not review the TIG function becuase I havent used that yet and probably never will. Just for a American made plasma cutter with simliar amperage as this unit, one can expect to pay about $1200 and it would be significantly bigger and heavier and not be able to stick/tig weld. I have read reviews of other chinese brands and it seems like its a hit or miss. This is why I choose to purchase from a ebayer with 100% positive feedback who has sold several of these units. With that said, I have no idea if I need to use the one year warranty, how easily/ smoothly that transaction would go. Hopefully I wont have to find out :}
Old 05-07-2008, 05:15 AM
longevity-inc.com's Avatar
longevity-inc.com longevity-inc.com is offline
Re: My Chinese expireince
Negatives :
Postives :
Glad to hear you are enjoying your unit and that you gave an imported welder a try.
We have a forum dedicated to these types of machines, check it out.
Thanks
LONGEVITY Welding
www.longevity-inc.com
Phone: 877-566-4462
JOIN OUR WELDING FORUM. Go to www.freeweldingforum.com
Old 10-11-2008, 03:56 PM
Flege Flege is offline
I bought one as well from Ebay by Roland out of Arizona, the units are blue. Plasma, stick and tig I love it. I built a trailer BBQ pit out of it. I have never had the High temp circuit shut me down.
I was wishing they made Migs unit, until I found a ESAB Migmaster 251 that needed a ground torch, spool kit, power cable, consumables, and cleaning up. Now I will be build a cart to hold both along with 2 Bottles then I will have a great set up for a hobbyist. Just like Harbor frieght and Northern Tool, if your not making a living with them they are great.
Whether it's wire or rob keep on burning them.
Old 07-15-2009, 07:42 PM
alias46 alias46 is offline
i have a lotos 520d and i can't seem to get the plasma cutter to work i feel i'm doing something wrong but not sure what i keep going over everything but can't figure it out i get air i see spark when i touch the metal and push the trigger but i can't get a full arc to cut. there is a nob for post flow which the book doesn't say what it is for. also i know the machine is grounded through the plug but there is also a ground screw on the back and they show it being used does it have to be grounded on the back also.and will they cut galvanized
Old 07-15-2009, 09:17 PM
GiantTechGuy's Avatar
GiantTechGuy GiantTechGuy is offline
Will cut any elecrically conductive material.
IGNOR that ground screw on the back of the machine.
Be sure the ground clamp cable is inserted into the port on the front right side of the machine.
http://www.PlasmaMetalCutter.com
GiantTech Cut40D
GiantTech Cut50D
GiantTech CT520D
GiantTech Tig200s
GiantTech Arc200
GiantTech Tig200PACDC
Miller MM210
No Brand Chinese Chop Saw
No Brand Chinese 4" Angle Grinder
Old 07-15-2009, 09:21 PM
Oh, and if it's a "Foot Pedal Ready" machine then be sure that the "Machine/Pedal" switch is in the "Machine " position.
GiantTech Cut40D
GiantTech Cut50D
GiantTech CT520D
GiantTech Tig200s
GiantTech Arc200
Miller MM210
Old 07-15-2009, 09:39 PM
Is this the machine you have ?
GiantTech Cut40D
GiantTech Cut50D
GiantTech CT520D
GiantTech Tig200s
GiantTech Arc200
Miller MM210
Old 07-15-2009, 09:40 PM
If so be sure that the center bottom switch is OFF.
GiantTech Cut40D
GiantTech Cut50D
GiantTech CT520D
GiantTech Tig200s
GiantTech Arc200
Miller MM210
Old 07-28-2009, 02:06 PM
racintck racintck is offline
That is the machine I just bought and every time I stop tig welding the pressure regulator allows argon to escape out the bottom of the bowl. I am not sure if it is designed that way or what. I thought the post flow should come out the tip of the tig torch.
Any ideas?
Old 07-28-2009, 02:21 PM
cdlale's Avatar
cdlale cdlale is offline
The air pressure regulator is only used for plasma cutting,not for tig welding. Your argon is leaking out of regulator water drain.
"You cannot invade the mainland United States. There would be a rifle behind every blade of grass."
Isoroku Yamamoto,
Commander-in-Chief, Imperial Japanese Navy
Old 07-28-2009, 03:23 PM
Thanks cdlale.
I had another friend tell me that as well...A well writen setup guide would have been handy.
I am going to reconfigure that and try again tonight.
Thanks again
Old 02-11-2010, 07:11 PM
stevewm stevewm is offline
Hello all. I am new here, weekend warrior type and wanted to comment on Simadre products. Been doing stick and wire since 1990, plasma last two years and am starting TIG. Latest project is a weld up 1200 square foot steel building.
I ordered a Simadre Cut520D off Ebay, wired the plug and gas/air lines and plugged it in - BANG. Seller was a quick shipper and offered a rebate on return shipping. I got a refund and purchased a 200P from the same place as I thought I'd get to aluminun welding at some point. The first one would power up but had no output at the torches and rod holder. Seller sent a replacement with return shipping covered by UPS "damaged goods" Second one came. I tested the plasma and MMA functions and found them to woek very well. Today I started hooking up the TIG and quickly found that the torch has the wrong connection. I robbed an extra 5/8"x 18 x 1/8" connector off a Harbor Freight regulator worked fine. Then I found the argon connector had a non standard connection to the gas bottle so now I am back to square one with TIG until I find another connector for the HF regulator. The regulator they supplied is basically useless.
My plasma unit is a Cut 40D and it has worked great since day one. I used it to cut all the steel for my building. Ibought it from Parker Metalworking (parkermetalworking.com). They are out in Oregon and re-engineer chinese welders for reliability. They also do a flat rate upgrade for other brands. They have the same 200P as my Simadre so I plan to send mine out to them if and when it fails rather than back to the Ebay seller. Their rate for repair, upgrade, and shipping both ways is $399 with one year warranty. Their upgraded unit is $1199 and at this point I have $949 in the Simadre so my cost of ownership won't be too far out of line should mine quit. If not, I am dollars ahead. Not the best solution but live and learn. It has taken me nearly two months of hassle to get a welder up and running and clearly I should have gone to Longevity, Everlast, or Parker in the first place.
Steve
Old 02-16-2010, 04:46 PM
EVERLAST's Avatar
EVERLAST EVERLAST is offline
stevewm
please check your PM
Old 03-02-2010, 02:41 PM
BONZ99 BONZ99 is offline
Where can I get a .024 roller for a Longevity LM - 250 L ? Thanks for your help !
Old 07-04-2010, 12:03 PM
shyboy2146 shyboy2146 is offline
Thanks
Does this mean you have a connection to SIMADRE TECH????
I see a similar responce to a RILAND post. You stated in a previous post that you sold welders on ebay in 5 differant names over a period of years but refused to disclose what they were.
I will ask you again .....are you in ANY WAY connected with SIMADRE.....SIMADRE TECH or anything related?
Old 07-05-2010, 07:47 PM
joedirt1966's Avatar
joedirt1966 joedirt1966 is offline
这是什么话吗?
Old 07-27-2010, 12:07 PM
Invert'd Invert'd is offline
So you're back!? It's heartwarming to see that you have time to help people with competitors' machines, but you don't have time to help people your own warrantied customers?
Old 07-27-2010, 12:38 PM
Rugar Rugar is offline
You might want to look at the date on that post?
Millermatic 251
Spectrum 300 Plasma
Everlast PowerTig 250EX
Everlast PowerCool W300
Harris / Victor OA
Craftsman 13 Speed Drill Press
ProTools Air/Hydraulic Bender
48" Brake
Compressor, Notchers, Grinders, etc.
Old 08-06-2010, 07:26 PM
Oops, my bad, sorry. It did make me feel a little better though.
