Old 06-25-2008, 05:52 AM
JohnnyWeld JohnnyWeld is offline
Coal / wood burner
Heres a coal burner I made. You can see the old one in the background which somebody had made and it cracked all around the seems due to poor fusion. I totally redesigned the front and inner guts of the thing.From what I hear from my customer, it works awesome. He especially liked the sliding infinately variable air intake.
Old 06-25-2008, 06:52 AM
DSW DSW is offline
Re: Coal / wood burner
Looks great! Very nice work.
Old 06-25-2008, 10:39 AM
Waldarosa's Avatar
Waldarosa Waldarosa is offline
Johnny,
Looks grrrrrrrrate! What thickness and type of material did you use? Are there any baffles in the stove? What did you weld this with?
Waldo
Old 06-25-2008, 04:56 PM
The wall thickness is a wopping 3/8ths. I used a miller 350p with Trimark metalloy 76 - metal cored wire @ .045 . I should have got a closer pic of the welds for you guys. Anyhow, no baffles - cept it does have a flap that swings up and down to allow larger logs and access for grate replacement. Also, below the grate the sidewalls taper in to funnel ash into the tray.
Old 06-25-2008, 09:54 PM
daddy's Avatar
daddy daddy is offline
Nice work. That 3/8" ought to radiate some heat.
I'm curious to see how long that grate lasts, but it looks real simple to drop another in as needed.
Again, good job. I like the ash pan and air control.
Is the flue on the back, or not cut in yet?
Jarret
Old 06-25-2008, 10:03 PM
DSW DSW is offline
I wondered about why the ash drawer was smaller than the box. Figured there had to be some system that kept the ashes from falling outside the box.
Old 06-25-2008, 11:38 PM
Bob's Avatar
Bob Bob is offline
If you build another grate try using a high grade rebar. It out lasts any thing else I've tried.
Old 06-26-2008, 03:16 AM
STwelder STwelder is offline
I like it. Bet it would heat a 2 car garage real good!
Miller Thunderbolt 225
Millermatic 130 XP
Lincoln HD 100
Forney C-5bt Arc welder
Plasma Cutter Gianteach Cut40A
Cent Machinery Bandsaw Horz/Vert
Cent Machinery 16Speed H.D. Drill Press
Chicago Electric 130amp tig/90 amp Arc
Old 06-26-2008, 02:31 PM
spiral-cut-bevel's Avatar
spiral-cut-bevel spiral-cut-bevel is offline
Really nice job ! I like it !
-Graham-
Mechanical Engineer
Autosport Mechanic/Fabricator
Old 06-27-2008, 12:11 PM
sc6chuck9 sc6chuck9 is offline
Great job, now for the big question, Do you have plans or sketches we could have so as to build one for ourselves. See with the way things are going for my machine shop it looks like I better start heating the shop with wood and all snail mail I get, which is a lot. Thanks ahead of time,,,,Chuck
Old 06-27-2008, 04:31 PM
comp comp is offline
ya T-shirt and shorts
