Old 06-30-2008, 05:03 PM
MatthewF's Avatar
MatthewF MatthewF is offline
welding with car batteries
today i took two drill bits, touched them to positive negitave terminals on my drill battery and touched them together , sparks flew and they got welded together.
can i put like 3 car batteries in a circut, minus to work peice positive to an electrode and weld with it???
it will be ugly *** but i wanna see if it works? anyone try this?
M Fed
Old 06-30-2008, 05:12 PM
aczeller aczeller is offline
Re: welding with car batteries
it'll work... you can also do the same thing by making a red-neck welder. DC only with a spare alternator hooked into the belt system on your truck. pretty red-neck'ish, but it works.
the thing you have to be careful about is keeping the batteries from exploding and/or over-heating. sulfuric acid burns like hell when it leaks out/ explodes out.
Later,
Andy
Old 06-30-2008, 05:14 PM
MatthewF's Avatar
how would i go about not blowing up my garage? just dont use it alot? and what kinda amps do you think ittl put out? and what will the welds look like?
M Fed
Old 06-30-2008, 05:19 PM
no boom = no use... there is no real good way of determining when they will blow. a lot of factors go into it like how old your battery is and/or what condition it's in.
welds, IN THEORY, will look okay... similiar to a CV/CC DC welder. in reality, they will look like poo and will probably not be anywhere near the quality of a welding machine.
as far as amperage, figure you have 3 batteries, 12 volts each, 600 CCA each. depending on how you hook them up, you can look at either 12 volts and 1800 amps, or 36 volts and 600 amps.
Later,
Andy
Old 06-30-2008, 05:20 PM
P.S. take a look on youtube for "homemade welders"... there's gotta be something out there... i've seen transformer welders made from old battery chargers. also, DC voltage supplies for things like printers and what-not work great, but can either blow themselves apart or flip the breaker/fuse.
Later,
Andy
Old 06-30-2008, 06:04 PM
MatthewF's Avatar
thanks andy... i did a search and found an awesome thread
http://weldingweb.com/showthread.php...tteries&page=2
M Fed
David R's Avatar
David R David R is offline
Do a search right here. There was one that did it in depth.
David
Real world weldin.
Old 06-30-2008, 06:46 PM
MatthewF's Avatar
hey wait.. .is this safe???? not the batteries but this.
i took an old power cord, chopped it to expose the black and white wires. then i wrapped the wires around nails . plugged the power cord into 2 power bars, with serge protection and i struck an arc on a big bolt i have. it instentaly melted part of the bolt and the breaker didn't trip....
im worried that i might start an internal fire inside my house somewhere... am i in danger???
M Fed
Old 06-30-2008, 06:51 PM
David R's Avatar
Please don't play with electricity. Yeah, you could get hurt.
David
Real world weldin.
Old 06-30-2008, 06:53 PM
MatthewF's Avatar
no no its cool im wearing a pair of winter gloves :P yeah your right.. probally shouldnt be doing that
M Fed
Old 06-30-2008, 06:59 PM
MEWelding.com's Avatar
MEWelding.com MEWelding.com is offline
Oh man, i have too many windows open again. I can't delete the post it was meant for another thread.
Old 06-30-2008, 07:02 PM
MatthewF's Avatar
no but i dont think that would change TOO much
M Fed
Old 06-30-2008, 07:09 PM
okay... i can;t keep my mouth shut any longer... are you completely dumb? i mean i know this sounds kinda bad, but what dim-wit just starts cutting wires, plugging them in, sparking things, THEN asks if it's safe?
i won;t say much more unless this shear stupidity continues.
Later,
Andy
Old 06-30-2008, 07:13 PM
tresi's Avatar
tresi tresi is offline
welding with car batteries has been done before. but yuor method is going to get you a room beside mine in the hospital. food is good and i get share 2 computers among 3 people who are able to still use one. Beside that you can get a welder from a pawn shop for the price of two or three batteries.
Old 06-30-2008, 09:34 PM
Mark... Mark... is offline
Snap on used to carry a spool gun that runs off of batteries. I used to have one and it worked pretty good. Worked on up to 36 volts. There was no voltage adjustment, just from 24 to 36. You would be surprised by the nice beads that thing would put out. Went through deep cycle batteries pretty quick though.
Old 07-01-2008, 03:28 AM
boogaloo boogaloo is offline
Redneck's last words,,,,,,,,,,,,,,,,,,,,Hey ya'll watch this, haha,,,,just had to be said,,,,,,,,,Boo,,,,
Old 07-01-2008, 04:43 PM
flydrifter flydrifter is offline
Are you getting some video of this??? This seems to be akin to that guy video taping himself with the bears in Alaska and I think Darwin had some things to say about things like this...
Old 07-04-2008, 06:36 AM
Tractapac Tractapac is offline
Yep, has all the hallmarks of adding chlorine to the gene pool.
"One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)
Mitch 180 (NZ)
Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 Plasma
Miller Spectrum 375
Old 07-04-2008, 11:23 AM
comp comp is offline
Old 07-04-2008, 11:29 AM
looks like you could tack things together if you were fabing things ,,light gauge stuff
Old 07-04-2008, 04:33 PM
z0diac's Avatar
z0diac z0diac is offline
David
The best advice in this thread.
I'm not even sure what you're using as a ground, but I wouldn't even experiment with basically big cases of sulfuric acid beating heated up. Save up, buy a welder that's built for what you're doing.
"A winner isn't someone who doesn't lose, a winner is someone who doesn't quit."
Old 07-04-2008, 06:53 PM
gnm109 gnm109 is offline
I don't mean to be critical but I also was wondering why we need to weld with batteries, a whole bank of batteries. I understand that there are four wheeler drivers who have battery welders with them for a quick fix when something breaks but I can't understand why one would want to do this at home.
For general use, I really think it's a waste of time. This is just my uneducated, unsolicitated, certainly unwanted opinion.
Old 07-04-2008, 07:00 PM
Skwerly's Avatar
Skwerly Skwerly is offline
http://www.jeepsunlimited.com/forums...d.php?t=302823
Check that thread out. I have seen it done on the trail firsthand, it's really cool!
Old 07-04-2008, 08:48 PM
mudbugone's Avatar
mudbugone mudbugone is offline
Instead of trying to blow up batteries in your face you might want to look at this and be a lot safer... http://www.readywelder.com/ if you visit their forum you might get better answers to your questions about what 2-3 batteries can weld. The military likes these,but then their stuff is 24 volts. These are popular with the 4x4 guys too.
Old 07-05-2008, 12:26 PM
Aquafire's Avatar
Aquafire Aquafire is offline
When I was a 12 year-old basement scientist/inventor, one of my experiments was building an electromagnet by coiling wire around a nail and running current through the wire. Pretty simple experiment, however what I didn't know was that batteries (especially when charging, which this one was) produce hydrogen gas (remember what happened to the Hindenburg). I kneeled over the battery on the concrete floor, shorted it out just as described and saw a nice arc too.
However unlike the above contributor(s) above, my barrel in the game of russian-roulette was loaded. The explosion knocked me backward, covered in suphuric acid and bleeding from the forehead. The house shuddered and the shrapnel left holes in the ceiling. Luckily for me, I received no acid (or anything else) in the eyes, no serious burns and no hearing loss (the ringing eventually went away). I was very lucky.
In short, if you don't REALLY know what you're doing (or even if you DO)- be careful building these contraptions and be even more careful following the how-to-guides of strangers that involve messing with batteries and lots of juice.
"How did you lose your left eye, Dave?" "Well, some guy on the internet named Hillbilly62 said I could..."
Trying to save a couple of bucks might cost you a lot more than you intended in the long run. Be safe!
Lincoln AC225 & MigPak 140, Lincoln Magnum SpoolGun, Miller Spectrum 375-X Plasma, Syncrowave 200 TIG, Millermatic 252 MIG, Miller Digital Elite, General 7x12" horiz/vert bandsaw, 3' box/pan brake, 20 ton press, milling machine, 12x28 lathe, etc.
