Old 08-21-2008, 11:52 PM
wagin's Avatar
wagin wagin is offline
oxy-acetylene regulator pressures?
It's been a long time since I've had to do a lot of burning on heavy steel. I"m probally wrong but I remember setting acty, regulator on 7psi and the oxy regulator on twenty psi. I am burning 1/4 inch, maybe a litte thicker, and am having trouble. Are my settings correct, or should I use different pressures. Oh yeh, I'm using a Harris tourch with a #3 tip. Anyone have advice? Thanks, Wesley(Wagin)
Miller TrailBlazer 251
Miller HF-250-1
Miller MaxStar 150 STL
HyperTherm PowerMax 380 plasma
Lincoln PowerMig 180
Millermatic 252
Miller Diversion 180
Old 08-22-2008, 12:19 AM
Craig in Denver's Avatar
Craig in Denver Craig in Denver is offline
Re: oxy-acetylene regulator pressures?
1/4" is a load for O/A (maybe a little thicker) and a #3 Harris is too small. The Harris chart shows you should be using a #7 tip with 7psi on both sides.
9-11-2001......We Will Never Forget
Retired desk jockey.
Hobby weldor with a little training.
Craftsman O/A---Flat, Vert, Ovhd, Horz.
Miller Syncrowave 250
Old 08-22-2008, 12:23 AM
Tensaiteki's Avatar
Tensaiteki Tensaiteki is offline
Moderator
Assuming you are cutting and not welding:
Your pressure setting look about right for the metal thickness. However, they seem to be way off for the tip size and the tip size is way off for the material thickness.
A #3 Harris tip is meant for cutting 2-3" thick steel. For cutting 1/4" the recommended tip size is a 00.
Here is a chart for material thickness, tip size, and recommended pressures (it's actually a Victor chart, but the sizes etc. pretty much match with Harris tips):
Visit Tensaiteki.com
Old 08-22-2008, 12:59 AM
Uh-oh. Are we cutting or welding?
Old 08-22-2008, 02:02 AM
Oldiron2 Oldiron2 is offline
Cutting tip #3, series 2490 or 6290 is for 2 to 3" thick material.
Welding tip #3 in series 23-A-90, 1390 or 5090 is for 1/16" thickness.
For an equal pressure torch using those above tips:
For cutting, you need a size 00 with 5 to 10 psi acetylene, 20 to 30 psi O2.
For welding, you need #7 tip with 7 psi of each gas.
This data is from an old Harris catalog (No.746), undated but probably from mid 70's.
Old 08-22-2008, 10:43 PM
wagin's Avatar
thank ya'll for the advice. Got a #1 tip today,(was the smallest available), and it performed much better. After pondering this cutting problem, and the great info, I recalled that I used a #00 tipp for most everything during my construction and fab. days. thanks again.
Miller HF-250-1
Millermatic 252
Old 08-23-2008, 03:48 PM
farmersamm's Avatar
I've always had a Harris, and a lot of guys have suggested that a Victor might be better. I've never run one so I don't know.
It's sometimes a nuisance running the Harris because the preheat flame is so short. You have to pretty darn near touch the iron with it. Tip needs cleaning more often too. I guess that's because of the short preheat.
Try to stick with genuine Harris tips if your supplier can get them. I've tried other brands which are supposed to work on the Harris but they never seem to work right.
A 2/0 tip works great on 3/16 to 1/4, 3/8 if you slow down. Generally I like a 0 tip for 3/8 to 1/2. I seldom cut much thicker stuff.
Don't drop any iron on yer tootsies.
Old 08-23-2008, 03:59 PM
Hammack_Welding's Avatar
Hammack_Welding Hammack_Welding is offline
I've never seen much difference in actual cut quality from torch to torch and I use them all in my shop, and service rigs. If you are having trouble preheating then step up a tip size. However I do agree with others that a #3 tip is way to large for 1/4" material. I generally run a #2 on all of my torches, and the majority of what I cut is from 3/8"" to 2" material.
