Old 09-05-2008, 09:10 AM
halltrail halltrail is offline
What is this ring for?
Hey guys, what is this ring on the ram used for on this style press? Sorry for the dumb question...just I havent seen this design before. Its for sale locally. I think Im going to go check it out. It's listed as a 60 ton press.
Miller 210
Lincoln AC225-s
Hypertherm Powermax 600
Old 09-05-2008, 09:14 AM
prop-doctor's Avatar
prop-doctor prop-doctor is offline
Re: What is this ring for?
its used for lowering down or up. like a screw jack, then you pump the handle
Old 09-05-2008, 09:20 AM
duaneb55's Avatar
duaneb55 duaneb55 is offline
Yup - used to take up the slack between the ram and work piece so you don't have to jack all day before making contact.
60 ton is a pretty big press. Should do ANYTHING you might have to do around the house that's for sure.
MM200 w/Spoolmatic 1
Syncrowave 180SD
Bobcat 225G Plus - LP/NG
MUTT Suitcase Wirefeeder
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
SA-200 Blackface Code# 8638
Star Jet 21-110
Old 09-05-2008, 11:40 AM
Thanks, I see now that there are presses that have adj tables and I guess there are some with adj rams. Yea if you saw my post below....you know im looking to bend 1/4 steel plate.
Miller 210
Lincoln AC225-s
Old 09-24-2008, 06:20 PM
Donald Branscom's Avatar
WOW !! that thing should be able to press coal into diamonds !!1 HAHAahahhhahha
AWS certified welder
44 years experience.
Miller 110V 140 MIG
Old 09-24-2008, 06:59 PM
Tractapac Tractapac is offline
This is the high end model with both. Adjustable table and ram. The beauty is you don't lose any of the ram's stroke length taking up the gap to what you're pressing.
"One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)
Mitch 180 (NZ)
Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 Plasma
Miller Spectrum 375
Old 09-24-2008, 10:26 PM
busyman's Avatar
busyman busyman is offline
My dad has an old press like that in his mechanic shop, which he enherated from my grand father.The picture dosent show the hand pump,but it should be overhead on the right side with the release valve next to it.
Its the only one like it I have ever seen until now.
If the price is right buy it.
It will probably out last you.
Old 09-25-2008, 08:20 PM
Make sure you use the proper V blockes when bending small plates.
If the metal is not secured properly it can squirt out and hit you in the face.
Miller 110V 140 MIG
Old 09-25-2008, 09:24 PM
David R's Avatar
David R David R is offline
My dad has one of those too. It has a handle that has a drive that dogs into the top side of the hand wheel to turn it, and a hydraulic cylinder. Its a good find.
David
Real world weldin.
Old 10-10-2008, 08:14 PM
Well, I ended up picking up this monster. I also picked up a Dake 25t press. I actually got that first but it wasnt working so I got the 60ton. Two days later, I fixed the Dake, turned out someone had plugged the exhaust port - duh. Took the plug out and it works like a charm.
The 60 ton actually has two levers on the right. One is fast action and the other is slower. It also has a 5 ton manual press on the left side. It is pretty damn cool Ill probably end up selling the dake...and use the money to get a milling machine.
Here are some pics:
By the way, Im not a Ravens fan....That belongs to the wife.
Miller 210
Lincoln AC225-s
Old 10-10-2008, 10:51 PM
duaneb55's Avatar
halltrail, Those are some pretty heavy-duty presses you have there.
btw, the dual levers (pumps) are not just a matter of fast and slow but the 'slow' pump allows you to achieve the 60T capabilities of that bad bear. It would be almost impossible to develop the pressure required to exert 60T of pressure with the high volume (fast) pump due to the pump-to-ram displacement ratio.
Some nice lookin' gear in that shop.
Syncrowave 180SD
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
Star Jet 21-110
Old 10-11-2008, 07:02 AM
David R's Avatar
Nice presses. My welders are NOT TOOL BENCHES!
Apparently a pet peeve of mine.
David
Real world weldin.
Old 10-11-2008, 08:28 AM
Duane, Thanks and you are right....Ive noticed that the "slow" one is the one that allows me to develop the higher pressure.....not necessarily move slow.... :-)
Hey Dave, I dont like to use it as a tool bench either...you caught me at a bad moment ....but if it makes you feel better....what is on there are my welding gloves, and various clamps used for welding....and I think that is the user manual on there too.
Im hoping to start making a few dies/punches this weekend.
Miller 210
Lincoln AC225-s
Old 10-11-2008, 09:32 AM
duaneb55's Avatar
Nevertheless, slow is good when dishing out 60T of pressure!
Syncrowave 180SD
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
Star Jet 21-110
HTML code is On
