Help with machine
Hello all,
Recently purchased a brand new Lincoln 180T off Craigslist. Wired a separate 30 Amp, 220 circuit for it, tested the outlet and made sure that it had power, then assembled the 180T per instructions on manual. After double checking all connections, I plugged it into the outlet and no power whatsoever. I tried calling Lincoln but they were already closed for business. Any suggestions on what to check? Appreciate any assistance the forum could offer. |
Re: Help with machine
When you checked the outlet for 220 did you probe both hots for 220 or each to ground/neutral for 110?
MM200 w/Spoolmatic 1 Syncrowave 180SD Bobcat 225G Plus - LP/NG MUTT Suitcase Wirefeeder WC-1S/Spoolmatic 1 HF-251D-1 PakMaster 100XL SA-200 Blackface Code# 8638 Star Jet 21-110 ![]() Two term limit - one in office, one in jail. |
Did you confirm the 'Identity Plug Configuration' at J4 is for 230V?
And of course did you check the circuit breaker to make sure it wasn't tripped?
I checked each to ground which read 110. The circuit breaker wasn't tripped and as far as the "Identity Plug Configuration at J4", I have no clue what you mean by this.
You need to make sure it reads 220v Hot to Hot
Ed Conley http://www.screamingbroccoli.net/ MM252 MM211 Passport Plus & Spool gun TA 185 Lincoln SP135 Plus- (Gone to a good home) Miller 125c Plasma 120v O/A set SO 2020 bender Beer in the fridge |
Ed,
Nope, I'm not getting a 220 V reading between the two hots. What did I do wrong? |
That's where I was headed Ed.
![]() It's probably that both sides of your breaker (in the house/shop electrical panel) is being fed from the same incoming power leg. If so, move the breaker down one slot and recheck. J4 and plug identification configurations are shown in the electrical diagrams of your manual and determine the operating voltage.
MM200 w/Spoolmatic 1 Syncrowave 180SD Bobcat 225G Plus - LP/NG MUTT Suitcase Wirefeeder WC-1S/Spoolmatic 1 HF-251D-1 PakMaster 100XL SA-200 Blackface Code# 8638 Star Jet 21-110 ![]() Two term limit - one in office, one in jail. Last edited by duaneb55; 10-29-2008 at 10:51 PM. |
Thanks duaneb55,
I think that's the problem. I will move it down a slot tomorrow. Thanks for the help. I was so excited to energize my new weldor and I didn't pay attention to detail. Great forum! |
We've seen it happen before and it's just easy to miss. Hope that's it and don't forget to keep us posted!
And if all else fails....GROUND TO NEUTRAL
![]() ![]() NOT serious advice, just someone revisiting his worst moment ![]()
Well, I've never made a mistake. You can ask my ex-wife.
9-11-2001......We Will Never Forget Retired desk jockey. ![]() Hobby weldor with a little training. ![]() Craftsman O/A---Flat, Vert, Ovhd, Horz. ![]() Miller Syncrowave 250
Saw ya at the "wedding", shoulda said hello
![]() ![]() ![]() I can see it now - 4+ years from now... ![]() And what about bent over nails?!
Hey, I saw you. You were the guy wearing BLACK.
I assume to match all the 'Bridesmaids'.
