Old 12-12-2008, 08:38 PM
stevinator's Avatar
stevinator stevinator is offline
Front tow hooks
Where is the best place to find tow hooks for a late model pickup? I am gonna check GM dealer price but there should be an aftermarket place for these cheaper I would think.
pro-level dumpster diver Hobart 125EZ
Old 12-12-2008, 08:48 PM
lugweld's Avatar
lugweld lugweld is offline
Location: south GA where its hot in summer and cold in winter
Re: Front tow hooks
Junk yard.
They pull them off by the hundreds. Was in one the other day. Had them laying all over the counter.
Welders:
Esab Migmaster 250
Penncraft 230 (oldy but goody)
HF Plasma 30 (Italian)
Lincoln Ranger 8
Smith Oxy/Acetylene/Propane
Lincoln SA200
Everlast Power Tig 250 EX
Everlast PowerUltra 205
Old 12-12-2008, 08:54 PM
Mondo's Avatar
Mondo Mondo is offline
Re: Front tow hooks
Any local auto parts store will have a generic model that can be bolted on or welded on. Northern Tools and Equipment has 7500 lb hooks for as low as $6.99 each, or 10,000lb models in black or chrome plated for $8.99.
-Mondo
Member, AWS
Lincoln ProMIG 140
Lincoln AC Tombstone
Craftsman Lathe 12 x 24 c1935
Ask for a wrench and someone will offer you a grinder.
I'll just keep on keepin' on.
Old 12-12-2008, 09:47 PM
tanglediver's Avatar
tanglediver tanglediver is offline
Re: Front tow hooks
You have a lot of options, OEM hooks, generic after market hooks, "D" rings, jumbo anchor shackles...the coolest i.m.o. are the military style lifting/tow shackles, but those are fewer and farther between. You could look for hummer style shackles, probably an expensive option.
These are a bit overkill! What can I say? I had a Tim taylor moment! RRR!!!
Job 28:1,2
Lincoln, Miller, Victor & NKJV Bible
Danny
Old 12-12-2008, 09:58 PM
Re: Front tow hooks
Moderator please remove the picture, sorry about the sizing error. Stupid 'puter, do what I want, not what I tell you.
Here is the resized version, the edit button was run off the edge previously!!
Job 28:1,2
Danny
Old 12-13-2008, 04:00 AM
Mack Mack is offline
Re: Front tow hooks
You should be able to buy the d rings that tanglediver posted at a semi-truck/trailer dealer or parts house. They come in several different sizes and are not too expensive. Weld em on yourself. I have four of them hanging on the back of my old International. Work great as a place for trailer safety chians to hook up. I get them at a place called Catco here in northern MN. Not sure if it is a national or more of a regional store.
Mack
Old 12-13-2008, 05:14 PM
stevinator's Avatar
Re: Front tow hooks
Dealer says 90.00 for a pair.I will head for the bone yards around here.Seems they fit 04 to 09 so that was good info.You could use d rings or make some,lot of good ideas offered here.I would like to find the oem's because the holes are in the frame and when mounted they would be hidden.Thanks guys for the responses.
Old 12-13-2008, 05:23 PM
lewray's Avatar
lewray lewray is offline
Re: Front tow hooks
I have some over stock ones.... not fancy though
We use them on our crawlers. 1"x6"
I like the ones Mondo posted. Maybe you can make something like that work
weld it like you own it
Old 12-13-2008, 07:35 PM
farmersamm's Avatar
Re: Front tow hooks
Those babies are handy fer a lot more than towin'. Like say, maybe hangin' the truck offa crane in order to do a really thorough job of drainin' the oil outta the rear end
Old 12-14-2008, 08:44 PM
500HpSilverado 500HpSilverado is offline
Re: Front tow hooks
I have an OEM set off of a 2004 Silverado 2500HD, if you want them you can have them.
If you cannot convince them, confuse them.
Harry S Truman
Old 12-14-2008, 10:23 PM
stevinator's Avatar
Re: Front tow hooks
Silverado thanks for the offer but these are for a colorado.I think I'll find them, the dealer said 04 to09 colorado and canyon so I should be in luck at a junk yard.
Old 12-14-2008, 11:53 PM
farmersamm's Avatar
Re: Front tow hooks
Do the D rings if you can. They're more versatile. You can use chain, a clevis, or a strap without fear of it slipping out.
Old 12-19-2008, 12:59 AM
Loose07 Loose07 is offline
Re: Front tow hooks
Dont know if they make them any more but from my experence the round oem tow hooks are a lot stronger than the square ones had square one snap off right were it starts makin the bend were the round ones the bolt holes were getting elongated and still no breaking, actually suprized the bolts didnt shear off in either case.
Old 12-21-2008, 10:38 AM
63-Yankee's Avatar
63-Yankee 63-Yankee is offline
Re: Front tow hooks
Buyers Products has a large range of tow / tiedown hardware.
Here are a few:
http://www.buyersproducts.com/Towing...ntrol/D-Rings/
http://www.buyersproducts.com/Towing.../Towing-Hooks/
Old 12-24-2008, 02:57 PM
Cliff Lodes Cliff Lodes is offline
Re: Front tow hooks
I had a set of "D" shackles I got from 4 wheel parts on my old jeep and i winched myself out along with 3 other trucks in tow
HTML code is On
