Old 01-05-2009, 11:28 AM
Fuzzydog Fuzzydog is offline
Jeep work
Been on the site for a while, just sitting back and enjoying the wealth of information and ideas. The recent jeep roof rack thread has inspired me to share some of my work. No up close welds or anything, but having the welders (220V stick and 220V MIG) sure is great when you want to do your own mods.
1990 Cherokee with 6.5" long arm lift (purchased) and I built the roof rack and the front bumper. Plans for this year are relocating the rear leaf mounts, replacing the sheet metal rockers with rectangular tubes (that double as air tanks) and replacing the front D30 axle with a D44 with air locker to handle the upcoming 35's and finally getting around to putting on the rear flares
Old 01-05-2009, 12:09 PM
MarkBall2's Avatar
MarkBall2 MarkBall2 is offline
Re: Jeep work
Looks good, but I would shy away from using the rockers as air tanks. Reason being, they will be bashed much more than a central tank tucked up above the frame rails. With a welded tank & pressure inside it, it could be a potential bomb if struck in the right place & a weld fractures.
The Jeep looks good & you've already made some excellent mods on it. Rockers made out of rectangular tubing or round tubing will really help keep the sheetmetal from caving in.
Mark
Me, stressed? I'm not stressed, cause nobody's shooting at me, cause I kilt em all. I haven't always been a nurse........
Hobart Handler 175
Lincoln SP 175 Plus
Oxy/Aceteyline
Some left over steel, lots of ideas
Old 01-05-2009, 01:18 PM
Skwerly's Avatar
Skwerly Skwerly is offline
Re: Jeep work
Hey cool Jeep! I like the long arm kits, super cool! Here's mine .
Old 01-05-2009, 04:58 PM
Ranger Ranger is offline
Re: Jeep work
Dont get a d44 out of a rubicon. They are junk. only thing d44 about them is the ring and pinion. everything else is d30 junk. i say go Full width High pinion 44 out of a bronco or f150
Old 01-05-2009, 06:00 PM
Re: Jeep work
I considered going full width for the longest time - back and forth, til I finally decided to stay relatively stock width. I already put a Ford explorer 8.8 with disc brakes, LSD, and 4.10's in the back, so I am going with a wagonneer 44 up front. It will be trussed. I only plan to go up to 35's and I am relatively easy on the skinny pedal so it should hold up fine.
That will be my next project that I will post pics up for - trusses for the 44.
Old 01-05-2009, 07:12 PM
rustywrangler rustywrangler is offline
Re: Jeep work
The rubicon D44 is just fine for an XJ/YJ swap. IMHO.
Got some nice looking XJ's there gents. Curious if you wander over to www.jeepforum.com???
Millermatic 180 with spoolgun
Rigid 14" Chop saw with carbid and diamond blades
Millwalkee 6" porable band saw
Delta 12" variable speed drill press
Old 01-05-2009, 10:30 PM
lewray's Avatar
lewray lewray is offline
Re: Jeep work
All this talk about heeps just joking Jeeps
I wheel a 79 FJ40 w/ alluminum tub, Bilstiens, chromolies in the axles the works on 38s whith a stock low hp mtr....anyway...and never wheeled a jeep untill I needed one because the above money pit was under more construction.
During one of my builds I bought a nice 93 Wrangler from a friend locked and geared ready for some pretty good trails. I really enjoyed it. Took it out a bunch of times and decided to try a trail called 1410---you know the U-joint size does that say anything about the trail or what.
Well here is the aftermath. Basically stock 30 and 35s with 33" TSLs
Broke both front axle shafts, rear u-joint (go figure), and the left front ball joint ears so the !@### front wheel went rolling down the hill. All within two minutes
I was a chore stuffing that heep back into the trailer at 4 am in the morning with 3 wheels
weld it like you own it
Old 01-05-2009, 11:59 PM
farmersamm's Avatar
Re: Jeep work
Fuzzydog--- Man what a place to sit and have a meal before you head back down
Lewray--- So what did ya expect man? BTW, ya bent your trailer
Old 01-06-2009, 12:06 AM
lewray's Avatar
Re: Jeep work
Oh my gosh you should see it now. It looks like a rusty pretzel on 4 wheels. Its so .... I wont even claim it any more
We hoisted a rig from a tree to stuff it into that trailer, its been run over, burned and well you should see it now
And BTW Fuzzydog thats an awsome awsome pic. Very sweet rig too!!
Old 01-06-2009, 12:28 AM
Re: Jeep work
That is one beat up trailer.
IF you gents are not already on www.Jeepforum.com, I invite you to join.
Old 01-06-2009, 12:34 AM
LanceM's Avatar
LanceM LanceM is offline
Re: Jeep work
Cool to see some other jeep guys on here, might have to post some pic's of mine now
Old 01-06-2009, 12:49 AM
farmersamm's Avatar
Re: Jeep work
Pics from LanceM won't download on my machine, but if their anything like what Skewerly put up, it's no wonder you guys have to know how to weld. I can hear every piece of bodywork on that Jeep groan as it's goin' over those rocks
Old 01-06-2009, 09:34 AM
Billdacat's Avatar
Billdacat Billdacat is offline
Re: Jeep work
Owning a Jeep requires learning many skills to keep things going. Knowing how to weld and build stuff is a huge asset that separates the men from the boys. Anybody can buy sh*t and bolt it on; but there is nothing more pleasurable then invention and fabrication.
Pics of some of the folks I wheel with. 04TJ 31”s. TT-MML-BL and 2”BB. 06 Rubi. stock.
Old 01-06-2009, 10:06 AM
Re: Jeep work
Now that is my kind of wheelin. Now to just find decent legal spots around here
Old 01-06-2009, 01:18 PM
Re: Jeep work
That will work, but all waggys are nasty low pinion. But it is a upgrade from the d30.
Old 01-06-2009, 02:37 PM
Re: Jeep work
yeah, I hear ya on that. There are options - I considered narrowing a hi pin 44 to use waggy shafts (that would be totally cool) but don't trust my fab skills and don't want to pay someone else to do it. I think the waggy 44 will hold up - it will have lock out hubs and very limited hwy use as I now trailer it (in case I break something, I still have a way to get it home)
Old 01-06-2009, 09:30 PM
TozziWelding's Avatar
TozziWelding TozziWelding is offline
Re: Jeep work
I don' see any Jeep's in this post.
Can you tell I am a CJ man
CJ-5 that is
Old 01-07-2009, 02:16 AM
tanglediver's Avatar
tanglediver tanglediver is offline
Re: Jeep work
This kid asked me one day if I was going to build my Dj5 into "some kind of insane rock crawler". No, it's SOME kind of thing, but,....no.
See it, it's a white jeep in a snow storm.
Job 28:1,2
Danny
Old 01-09-2009, 12:43 AM
Joker11's Avatar
Joker11 Joker11 is offline
Re: Jeep work
I am the outcast....I have a 69 Bronco. It has a D30 front and a Ford 9 in the rear powered by a 302. Name:  Diamond T Memorial.jpg
Lincoln Power Mig 350MP
Lincoln Ranger 9
Lincoln LN-25
Lincoln Water Cooled Tig Module with HF
Lincoln Water Cooler
Lincoln WeldPak 100
CK TIG TORCH with gas diffuser and pyrex cup
Old 01-09-2009, 01:36 PM
Re: Jeep work
You'd be welcome to hang with us jeepers anyday with that Bronco. Nice rig!
Old 01-09-2009, 01:45 PM
Billdacat's Avatar
Rovers
Friggen photo was way to large. What a PITA to delete....repost later today...
Old 01-09-2009, 07:21 PM
Joker11's Avatar
Re: Jeep work
Really? I usually get the response..."It's a jeep thing"
Lincoln Ranger 9
Lincoln LN-25
Lincoln WeldPak 100
Old 01-09-2009, 07:30 PM
lewray's Avatar
Re: Jeep work
Hahaha Joker I know what you mean....
Heres what I got on my personal plate
Old 01-09-2009, 07:38 PM
Joker11's Avatar
Re: Jeep work
My license is SROHTFG....which is GFTHORS backwards, which Means Gift Horse.
The bronco was left to me as a GIFT by my buddy after he passed from brain cancer. Bronco is a HORSE....He had GFTHORS on his plate but when he died his father kept it. Since I wanted to remember him I just flipped it backwards. It was given to him as a gift from his father....long story.
Sorry to hijack.....my bad.
Lincoln Ranger 9
Lincoln LN-25
Lincoln WeldPak 100
Old 01-09-2009, 07:48 PM
Re: Jeep work
A short Bronco fits in well with the Jeeps, and small Scouts, FJ-40's as well.
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
