Old 01-06-2009, 05:53 PM
aametalmaster's Avatar
aametalmaster aametalmaster is offline
Shortening small bolts easily.
Maybe some of you already knew this tip. I bought some small SHCS and they were about 1/8" too long. So i made up a small sleeve and slipped the bolt thru the hole and put a nut on. After it was tightened i chucked it up and cut it with my lathe tool, then touched with a file. It left a perfect thread that screwed in my project nicely and my fingers didn't get burned using a grinder...Bob
Bob Wright
Salem, Ohio Birthplace of the Silver & Deming Drill
http://groups.yahoo.com/group/southbend10k/
http://groups.yahoo.com/group/sawking/
1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Old 01-06-2009, 06:43 PM
farmersamm's Avatar
Re: Shortening small bolts easily.
That looks a lot saner than the way I always do it
I'm always in a bigazz hurry, and put the nut on, then cut it with a razor wheel mounted on the grinder. Then I back the nut off the bolt to "rethread" where I cut it. Sometimes I have one hell of a time gettin' the nut back on It USUALLY works
Old 01-07-2009, 11:35 AM
Mondo's Avatar
Mondo Mondo is offline
The next time I need to shorten a small bolt by 1/8" of an inch I'll go buy myself a LaBlonde lathe.
Nice tip, though!
keep on keepin' on.
Old 01-07-2009, 01:32 PM
Oldtimer Oldtimer is offline
Nice tip, though!
Hey, that will work. I usually just saw them off with a hacksaw if they are 5/8" or less and grind a starting thread on 'em with a fine cut wheel on the bench grinder. If they are short I hold them with vice grips to save my fingers.
Old 01-07-2009, 08:27 PM
David R's Avatar
David R David R is offline
Moderator
Hacksaw and a file (1/2 round or knife) to touch up the threads. A lathe would be nice!
David
Real world weldin.
Old 01-07-2009, 08:47 PM
tapwelder tapwelder is offline
My technique is similar to aametal', though I don't usually use a lathe. Shortening and dressing before backing it out of the nut or die straightens the threads and provides a nice cutting guage. I cut it with whatever is handy.
I go that technique from one of those pbs woodworking shows. They had a board set up with various nuts mounted to it They ran the screw through from the opposite side of the board hacksawed it off then backed it out.
Old 01-07-2009, 09:12 PM
Oldiron2 Oldiron2 is offline
When it's a short socket-head bolt like that, I usually can just chuck the bolt by the head and take a light cut so as to not deform the bolt head. For hex heads (which aren't always that symmetrical), I often just turn them into some long nuts and chuck the nuts, though then I need to reverse the spindle travel to keep the bolt from unscrewing, taking the cut from the bottom instead.
Old 01-08-2009, 09:41 AM
minner minner is offline
I usually bite mine off....
Old 01-08-2009, 10:01 AM
ironman715 ironman715 is offline
Portaband, or band saw, hack saw if nothing else is available and a file or grinder to touch it up. Has never failed me....yet.
Old 01-08-2009, 04:37 PM
jdom5274 jdom5274 is offline
I use a method taught to me by a toolmaker when I was an apprentice. Get a matching nut for the screw / bolt and cut a slot inwards from one flat to the thread. Run the modified nut up the screw to the length required and clamp the nut in a bench vise. Cut off the excess threads and dress with a file. You can do the same thing in the bench lathe if you have one available. It makes for a nicer job and the split in the nut gives good gripping on the threads. I have made several for each thread size I run into and reuse often. Works everytime.
Old 01-08-2009, 05:51 PM
tnjind tnjind is offline
I just tighten the heck out of it til it bottoms out then it magically twists off! Of course the bolt and hole are now junk. But i seem to do that more often then I should.
Tim Beeker.
Old 01-08-2009, 06:21 PM
farmersamm's Avatar
That's neat. You made the nut into a collet. Thanks for the info
Old 01-08-2009, 07:01 PM
Magnetic Mechanic's Avatar
Magnetic Mechanic Magnetic Mechanic is offline
after cutting, grind or cut a lead on the screw at 60º
A butterfly without wings,
is just an ugly bug
Old 01-09-2009, 12:16 AM
dr stan dr stan is offline
That's a good way to loose the bolt and have the grinder send it flying back at you.
Old 01-15-2009, 04:28 AM
Weldordie Weldordie is offline
When I had to shorten some small screws, I grabbed a foot-long piece of scrap 1/4" thick flat, and drilled and tapped to fit the screws. Then, I ran each screw through to the desired length, and held it to my grinding wheel to remove the excess. And, yes, I did have to hold the head of the screw with a screwdriver to keep the screw from turning while against the wheel.
Old 01-15-2009, 08:57 PM
daddy's Avatar
daddy daddy is online now
dr stan,
You must have some mighty strong fingers to hold onto a bolt tighter than Oldtimer can with a set of vice grips.
Jarret
Old 01-16-2009, 03:41 AM
Blackcypress-EB's Avatar
Blackcypress-EB Blackcypress-EB is offline
I have a piece of 1/8"x3/4" strap about six inches long with the normal increments of thread sizes drilled into it from 3/16 to 1/2. I screw the victim into the strap and use it as a handle. I grind the bolt on my 72" grinder with a 36 or 60 grit belt, cool if necessary, then bevel like Mag Mech illustrated with the fine wheel on my bench grinder. No heat on the hands and I have good control. I can zip one out in no time. I am not fortunate enough to own a lathe though. I sure wish I had one sometimes.
Miller 250DX
TD Cutmaster 100
Duct Tape
BFH
Old 01-16-2009, 07:40 AM
Now, I've gotta start drillin' and tappin' sum mo. A 72" grinder... is that the total length of the belt, or the length from roller to roller? Sounds like it would be just about right for sharpening iceboat blades.
Old 01-16-2009, 08:45 AM
That is the length of the belt. There are many different attachments for them to grind flat or concave and so on. Companies like KMG and Bader are popular. They aren't cheap, but definitely versatile for any grinding needs. There are shorter less expensive rigs than the 72" that are made by craftsman and similar companies that might get what you need done for less.
Miller 250DX
TD Cutmaster 100
Duct Tape
BFH
Old 01-17-2009, 11:50 AM
specter specter is offline
Well I use the same process that Sam described above and then taper the end at which point I back off the nut over the finished end. I always make sure that the nut is a couple of grades harder than the bolt.
Own farm:Harris oxyacy torch, lincoln 225, stick,Century 135GL mig, Hypertherm PowerMax 45 Plasma Cutter
Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.Hypertherm HPR260 Plasma Cutter
HTML code is On
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
