Old 01-16-2009, 08:49 PM
Beagle Fab Beagle Fab is offline
Math needed for welding
I am currently taking some welding courses, but it moved straight into more hands on training as opposed to classroom getting used to measurements, welding symbols, blue prints, exc. Coincidently, I am also taking a some advanced math courses to shore up those skills.
Any recommendations on the type of math I should gear up on? Trig, Geometry?
Old 01-16-2009, 11:03 PM
Magnetic Mechanic's Avatar
Magnetic Mechanic Magnetic Mechanic is offline
Re: Math needed for welding
If yer gonna do any layout, you gots ta have geometry.
A butterfly without wings,
is just an ugly bug
Old 01-16-2009, 11:16 PM
lugweld's Avatar
lugweld lugweld is offline
Location: south GA where its hot in summer and cold in winter
Geometry definitely, particularly if you do fabricating. But trig, is helpful, though I can't hardly remember a thing about it. Accounting math might be nice....got to keep those books.
Welders:
Esab Migmaster 250
Penncraft 230 (oldy but goody)
HF Plasma 30 (Italian)
Lincoln Ranger 8
Smith Oxy/Acetylene/Propane
New to the family:
Lincoln SA200
Everlast Power Tig 250 EX
Everlast PowerUltra 205
Aka..The Everlast Pimp...
Old 01-17-2009, 02:00 AM
Static-XJ Static-XJ is offline
Trig. Very useful, sine cosine tangent and the like. Algebra as a pre-req, it's a foundation for solving all sorts of stuff.
If you work in the US, knowing how to convert from imperial to metric measurements can be handy, and likely will only become more so with time. Being able to apply the correct conversion with the correct math.
Being able to take degrees and convert that into length measurements on an arc. For example a part that is essentially a large arch (30' length of a circle with radius of 150') had brackets spaces every 7.9°, had to be able to use that information to mark locations for the brackets.
Being able to estimate volume, and convert volume into weight. Very useful if you're dealing with larger items and overhead lifting.
I would also recommend knowing how to do math long hand, without a calculator. Including long division. Sometimes it's more convent to just write the math out than it is to go get a calculator.
As for weld symbols, I'm assuming that you're located int he US and are learning ANSI/AWS weld symbols. I would try and at least take a look at some ISO weld symbols as well. They are similar, but have differences. Particularly in arrow side vs other side designation, weld dimensions, and intermittent weld lengths/pitch. Be familiar enough that you can recognize which a symbol is, and be able to look up how the welds are called out.
Old 01-28-2009, 01:59 PM
mn welder's Avatar
mn welder mn welder is offline
definatly geometry and when iwas in school at ndscs we had a practical welders math book that was the thing also fractions, decimals and a very good calculator where you just plug in formula and get your answer
Old 01-28-2009, 04:28 PM
A_DAB_will_do's Avatar
Start with sound fundementals...some of the guys I attended welding school with couldn't add, subtract, multiple, and divide; even with a calculator. Know how to perform all these mathmatical operations with fractions and decimals. Be comfortable converting from fractions to decimals and back. Someone else mentioned the metric system. I second this suggestion. Understand how to convert from one unit of measurement to the other.
If you've mastered all this already, then look at geometry. A few simple concepts, like a 3,4,5 right triangle will enable you to build things square. If you don't know, ask someone to show you the proper technique for using a tape measure, plumb bob, and spirit level. Knowing how to use these tools properly will help you avoid a lot of time consuming mistakes.
Best way to learn how to read blueprints is to learn how to produce one yourself. Take a drafting course if you have the time. There are lots of good reference books on welding symbology that can provide the details you're looking for.
www.bensonmobilewelding.com
Old 01-28-2009, 08:57 PM
Thanks for all the suggestions and recommendations! I've got the fraction/Dec conversions down cold, and all the adding stuff well in hand as well.
That said, I really like the Drafting course/study idea and that is a great suggestion! Welding symbols and blueprints as well!
Thanks again!
Old 01-28-2009, 09:18 PM
Fat Bastard's Avatar
Fat Bastard Fat Bastard is offline
I find that I use all 4 types of math addin miniusin timesin and dvidin
anything else?
Somewhere in the world there is an indiginous pigmy praying to a Jet plane flying overhead thinking it's his God, he might just be the sanest one of us all. bigwhitebeast
Old 01-28-2009, 09:44 PM
steve45 steve45 is offline
Look at this and see if you can figure out how to lay it out: http://weldingweb.com/showthread.php...091#post247091
That will give you an idea of what you might need to know.
America Needs AMERICA'S Oil!!!
"Global warming is the greatest scam in history ...There is no run away climate change. The impact of humans on climate is not catastrophic. Our planet is not in peril."--John Coleman, Founder of The Weather Channel
Old 03-03-2009, 11:37 PM
DAKW DAKW is offline
get a copy of "MATH TO BULD ON" its about $25 a great reference when you need to look up the right formula isbn # 0-9624197-1-0
Old 03-05-2009, 01:37 AM
Donald Branscom's Avatar
Wink Re: Math needed for welding
Simple geometry - like if you have a round steel disk how do you find the center?
Figuring supplies for a job. But there is a hand held calculator made just for welders that can really help you with this task and i have seen it in Welding Journal magazine.
Weights of materials - like you are going to load a 1 ton truck with steel plates and you want a safe load.1/4 inch steel plate weighs 10.2 pounds per sq.foot.What would a safe load be?
Weights of materials are very important.
How large of a tank to hold 10 gallons of liquid. Etc.,.
My brain and experience
Miller welder, Miller Elite helmet.
Old 03-14-2009, 12:33 PM
dr stan dr stan is offline
All of the previously posted suggestions are excellent, especially those referring to trig, geometry, and drafting. I would however add a couple of thoughts. If you can find a board drafting class instead of AutoCADD it will serve you better. Unless you are using a CNC cutter you will be doing your layout and cutting by hand. Thus the skills you learn on the board are directly transferable to sheet and plate stock. If you can take a class in Descriptive Geometry that is taught on the board that will improve your math skills in ways that will serve you best.
Another source of info is the Audel’s series of technical books. Don’t just concentrate on the welding books, but also look at the millwrights, carpenters, and other tradesman books that contain math information.
Glad to see someone pursuing your craft with such a focus.
[IMG] code is Off
