Old 01-24-2009, 01:31 AM
wagin's Avatar
wagin wagin is offline
rotary tables??
I am biding a job that would require a small rotary table. The tables I have found are way out of my price range. Can anyone suggest a more affordable solution?
Miller TrailBlazer 251
Miller HF-250-1
Miller MaxStar 150 STL
HyperTherm PowerMax 380 plasma
Lincoln PowerMig 180
Millermatic 252
Old 01-24-2009, 01:50 AM
Bgbkwndo Bgbkwndo is offline
Re: rotary tables??
Do you require this rotary table for turning weldments during the welding process? If so, a table could be made quite easily and with minimum expense. Google can be a great source of ideas too!
Just my $.02 worth; good luck.
Bgbkwndo.
Old 01-24-2009, 09:11 AM
aametalmaster's Avatar
aametalmaster aametalmaster is offline
Re: rotary tables??
How about a small Boston gearbox and a motor. You could use a foot switch to rotate. You could also make an adaptor to use a lathe chuck on it...Bob
Bob Wright
Salem, Ohio Birthplace of the Silver & Deming Drill
http://groups.yahoo.com/group/southbend10k/
http://groups.yahoo.com/group/sawking/
1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Old 01-25-2009, 11:23 PM
NYS3 NYS3 is offline
Re: rotary tables??
The Phase II rotary tables sold by Enco and some other companies online are excellent in quality and low in price. I picked up an 8" horizontal only table for $200 with free shipping. I am extremely satisfied with the quality and there is almost no backlash in the worm gear.
Linde/Union Carbide HDA-300
Hobart RC-250
Lincoln AC-225
Lincoln WeldPak 100
Hobart Stickmate LX
Victor OxyAcetylene
Old 01-27-2009, 01:06 AM
DSW DSW is offline
Re: rotary tables??
I've got an old 6" 4 jaw lathe chuck I snagged cheap tacked to a lazy susan set of bearings. I can rotate the piece and then weld, reposition and weld, so on. I have seen a bearing mounted shaft with a base plate attached to the shaft. The shaft bearing mounts in a vise and then the plate will rotate around the shaft. Niether of these are great if you need both hands free to say tig weld, but can work ok with say mig with a bit of thought.
Old 01-28-2009, 03:24 AM
wagin's Avatar
Re: rotary tables??
as always thank you all for the info and input. There is no such thing as bad added intel.
NYS3, thank you for the input, I think, according to your description, this is what I'm looking for.
Miller HF-250-1
Millermatic 252
Old 01-28-2009, 01:32 PM
farmersamm's Avatar
Re: rotary tables??
Also check out Grizzly. Usually better package deals. Tailstock, plates, spindles, etc.
Old 01-28-2009, 04:23 PM
Ries Ries is offline
Re: rotary tables??
Are you talking about a rotary table, for machining, or a rotary positioner, for welding?
Two very different beasts.
I have a Grizzly rotary table I use on my milling machine- it was cheap, and does the job, not super duper precision to .0005 quality, but a good deal for the price, especially since a real precision rotary table can easily run $4000 or more.
http://grizzly.com/products/10-Horiz...ry-Table/G9293
A rotary POSITIONER is a welding fixture with a motor, that enables you to weld all the way around a circle, without stopping.
these guys sell em from 200lb capacity to over 100,000lbs- sometimes, you need to weld something heavy.
http://www.weldplus.com/postion.asp
Here is a cute little one-
http://www.starleymfg.com/rotostar1.html
Here is another one, $1000 new.
http://www.jandrweldingsupply.com/st...ositioner.html
They come up on ebay, if you watch for em.
Lots of times welding supply shops have used ones for sale, too.
Old 01-28-2009, 11:22 PM
rode2rouen's Avatar
rode2rouen rode2rouen is offline
Re: rotary tables??
I've got a rotary table that I use on my milling machine, but I'd hate to have to use it for welding. Someone else would have to turn the crank while I held the torch and filler.
I just picked up an 8" chuck on Ebay that is going to become part of the welding positioner I want to build. Along with a DC motor and speed control, a couple of pillow block bearings, a 2" or 2 1/2" OD bit of pipe and some odds and ends square tube and plate, I should be able to put one together for considerably less than what the "cute" one sells for.
That is a nice compact unit, though.
Rex
Old 01-29-2009, 04:25 AM
William McCormick Jr's Avatar
William McCormick Jr William McCormick Jr is offline
Re: rotary tables??
http://www.use-enco.com/CGI/INPDFF?PMPAGE=435&PMCTLG=00
Grizzly may have some reasonable ones too.
Sincerely,
William McCormick
Old 01-29-2009, 12:25 PM
Oldiron2 Oldiron2 is offline
Re: rotary tables??
I once found one at a local flea market; It was a 10" (or 12"?) horizontal/vertical Yuasa in nearly-new condition and selling for something like $125. I had neither the money with me nor a mill at home yet still tried to get it; someone else beat me to it. That was probably twenty years ago, but the 10" would still have been selling for $650---800 new, I think.
Old 01-29-2009, 06:21 PM
David R's Avatar
David R David R is offline
Moderator
Re: rotary tables??
I have the XT-200 with a chuck and a couple of face plates. Here is a dumb question,
Bearings: Turntable shaft supported by 2 Oilite bushings to carry radial loads and 2 ball bearing to carry axial loads.
Which way is axial?
I have some 50 lb plates, 6" wide, 42" long, and 7/8" thick. I have to weld pipe couplings on at various spots on the flat plate. I have been doing it horizontal, but would prefer to do it vertical (like an air plane propeller). I run it about 3 RPM for this job. I think to do it vertical, I would need a counter balance.
David
Real world weldin.
Old 01-29-2009, 07:17 PM
farmersamm's Avatar
Re: rotary tables??
I believe that axial (like in x,y, axis) is the load that the tool puts on the work when it's being machined. The ability of the fixture to resist pressure applied by the machining process. I'm not sure.
Old 01-30-2009, 03:41 AM
wagin's Avatar
Re: rotary tables??
again, I think all y'all for the great info. I apologize for not providing more detail in my org post. I need a weld positioner table or maybe even a set of horizontal powered rollers. I bid a job calling for a 1.98" bushing inserted .5" into a 2"x16" tube and welded. The customer requires 300 per month. An auto positioner would increase my production rate.
Miller HF-250-1
Millermatic 252
Old 01-30-2009, 06:37 PM
David R's Avatar
Moderator
Re: rotary tables??
JUST BUY A GOOD POSITIONER. I did and the work for it keeps coming right now I am using mine every day. It paid for its self on the first job.
My $.02
David
Real world weldin.
Old 01-30-2009, 08:43 PM
rode2rouen's Avatar
Re: rotary tables??
Originally Posted by David R View Post
Which way is axial?
A radial load is from the center of a shaft going (radiating) outward.
An axial load is along the center of the shaft. A thrust load is axial.
Rex
Old 01-30-2009, 08:51 PM
Magnetic Mechanic's Avatar
Magnetic Mechanic Magnetic Mechanic is offline
Re: rotary tables??
If your looking to build something like this I know where you can get a 3 and/or 4 jaw chuck (14" I think) pretty cheap. Oh yeh, there brand new.
A butterfly without wings,
is just an ugly bug
Old 01-30-2009, 09:08 PM
Re: rotary tables??
Axial/Radial
is just an ugly bug
Old 01-31-2009, 06:44 AM
David R's Avatar
Moderator
Re: rotary tables??
Thank you Magnetic Mechanic. I did a search on Ebone last night, there are a LOT of positioners on there right now. I think I said it earlier, I looked and looked for a used one. They were going for new price on Ebone, so I just bucked up and got a new one. I am glad I did. That thing makes me a LOT of money.
The reason I asked is My positioner has bearings and bushings one for radial loads and one for axial loads. I don't want to trash my toy on one job doing those long bars.
I contacted one of the companies linked above for prices on used 500 lb units. They want almost as much and a nice shiny new atlas. 2650 to 2850 used, new is $3500.
David
Real world weldin.
Old 01-31-2009, 01:03 PM
Re: rotary tables??
David;
When you need to run the positioner table vertically for long stock (which is then horizontal), can't you use a 'tailstock' arrangement, perhaps as simple as a couple or rollers from a conveyor track, to support the off end and help save the bushings/bearings? Maybe even support the stock over most of its length, if it's uniformly round and concentric? Or are you saying the radial forces are too great for the bushings anyway?
Old 01-31-2009, 05:00 PM
David R's Avatar
Moderator
Re: rotary tables??
Olsieon2,
I have these pieces 7/8" thick, 6" wide and 36 to 52" long. They get 3/8" pipe couplings welded to them in different places along the stock. The customer gave me a pilot tool that goes through the stock and coupling with an allen bolt and c washer on top. The bottom of the tool is bigger and round, so it goes in the chuck. Now the part I need to weld is in the center, but the plate is hanging off the positioner by up to 50" . This can't bee good for it. Its a 200 lb BALANCED positioner. The ones that go near the center I can just stand back, hold the gun on the joint and press the foot pedal and pull the trigger. The table is turning about 3 rpm, so its a quick weld. I am using pulsed spray, so no gun gyrations are needed, just weld the damn thing and on to the next one. When the coupling is welded near the end,. I start with the plate on my right, run part of the bead with my hand, then step on the pedal. I stop when the piece hits me on the left side.
I paid dearly for the positioner and don't want to trash the bushings by doing this all the time. Last job had 134 couplings. I made a killing on the job. The actual weld takes 20 seconds. I get $5.00 per coupling...... The gave me 4 pilots, so I can do a whole bar in a few minutes. This could be repeat work. I would love it.
I thought of turning the positioner so the face plate and chuck are vertical. I would need a counter weight because I am sure it doesn't have the balls to rotate a 45 lb 42" long piece totally off center. I asked the customer for a scrap bar. He didn't have one, but did send me a nice big piece of 5/8" plate about 8" X 48". To do this, I would need different counterweights for different locations on the bar I am welding. Think of an airplane propeller.
My positioner sez has bushings AND bearings,but now I can't remember which was which. I looked at the manufactures website and can't find it again.
Now you know the WHOLE story..
David
SO this is why I was looking for a bigger positioner. Bigger $ !!
Real world weldin.
Old 01-31-2009, 10:47 PM
farmersamm's Avatar
Re: rotary tables??
Sounds like a lopsided irregular mess.
Might be possible to build a fixture to hold the far end in the horizontal position while protecting your equipment. Know you ain't fond of that kind of thing. MIght come in handy later.
My time isn't money, like yours. I usually take longer to figure out a way to save expensive equipment. I don't have the money to replace a positioner like yours, let alone buy one in the first place.
Old 02-03-2009, 06:47 PM
David R's Avatar
Moderator
Re: rotary tables??
I just bought this
http://cgi.ebay.com/ws/eBayISAPI.dll...m=350158941129
Big cheesy smile!
David
Real world weldin.
Old 02-03-2009, 08:04 PM
Hammer Hammer is offline
Re: rotary tables??
Companies like BAILEIGH do lease to own deals for less than $100 a month. Just a thought.
Old 02-03-2009, 10:37 PM
rode2rouen's Avatar
Re: rotary tables??
I just bought this
Big cheesy smile!
David
How much for shipping from CA to NY?
Rex
HTML code is On
