Old 01-24-2009, 09:53 PM
deadman1474 deadman1474 is offline
Jeep Grand Cherokee
I am working on a 93 jeep grand cherokee with a 4.0 liter straight 6 in it. When it is cold it wont start with out a fight. But after it starts up it runs like a champ. I have recently replaced the cap and rotor, spark plugs, and spark plug wires. The car has 150,000 miles on it right now and after you start it it runs great. The check engine light is not on. (But the ABS and AIR BAG lights are). I was thinking coolant temperature sensor but it does not seem to fit with the car starting running great after. And after you run it if you kill it and restart it starts fine only when the engine is cold. Thanks Cody
Old 01-24-2009, 09:56 PM
Brianstick Brianstick is offline
Re: Jeep Grand Cherokee
Is it fuel injected or carb?
Old 01-24-2009, 10:57 PM
fuel injected
Old 01-25-2009, 09:18 AM
It sound like the computer is delivering too lean off a mixture to the engine when it is cold. There are sensors on the engine to tell the computer what mixture to deliver to the engine at various temperatures. In the old days they had automatic chokes that they used to controll mixture with a temperature sensor on the intake manifold that worked pretty well. Check in your service manual under the troubleshooting section.
Old 01-25-2009, 10:47 AM
The service manual is something that I am going to have to buy.
Old 01-25-2009, 10:50 AM
It's probably just a bad sensor. Knowing which one is the trick.
Old 01-25-2009, 11:23 AM
84zmike 84zmike is offline
Try tuning the key on and listening to the fuel pump once it stops running then try to start it if it doesn't then turn the key off and on again a few times letting the fuel pump stop each time before you try and start it if this works you need a new fuel pump as it is "loosing its prime" and the only fix is a new one
Old 01-25-2009, 12:28 PM
Sparky#1 Sparky#1 is offline
Does the truck crank strong or is it lazy ? Also what type of oil are you running ?
Old 01-25-2009, 04:28 PM
Go1lum Go1lum is offline
150k on a 4.0 is brand new. Sounds like a temp sensor. ( hard starts with 4.0's are so common). Also maybe sign up on like pirate4x4.com and search. or www.naxja.org
--Gol'
Old 01-25-2009, 09:43 PM
It cranks fine and as soon as you get it started it runs great great oil pressure altho I am not sure what kind of oil is in it.
Old 01-25-2009, 10:30 PM
If the oil is too heavy that could be an issue and check your oxygen sensor.
Old 01-25-2009, 11:23 PM
Another thing came to mind with the EPA the way it is now there are winter blends for gasoline as well as Diesel so if you have a tank of summer fuel it will be hard to start or if you have a tank of winter blend and the Jeep is in a heat garage same issues......
Old 01-26-2009, 02:21 AM
STwelder STwelder is offline
150000 miles on it...... check the timing on it. Its easy and you don't need a book, you can call auto zone or advance auto and the will tell you the timing degree over the phone.
Miller Thunderbolt 225
Millermatic 130 XP
Lincoln HD 100
Forney C-5bt Arc welder
Plasma Cutter Gianteach Cut40A
Cent Machinery Bandsaw Horz/Vert
Cent Machinery 16Speed H.D. Drill Press
Chicago Electric 130amp tig/90 amp Arc
Old 01-27-2009, 02:41 PM
joeaus joeaus is offline
Post Re: Jeep Grand Cherokee
I have had several of these Jeeps, 4.0 is barely broken in at 150k. I believe it is the temperature sensor. Good luck.
Old 01-27-2009, 02:48 PM
UCHOG UCHOG is offline
Thumbs up Re: Jeep Grand Cherokee
The issue seems to me is it's the "Idle Air Control Valve". Since the engine is an EFI, there is a small electric motor on top of the plentum, (where the carb would normally sit) which has a fan blower inside. Over time, and 150,000 miles, the shaft on the electric motor will carbon up, not allowing the fan to engage, thus, not forcing air inside of the engine, making a cold engine difficult to start.
It is easy to resolve by either cleaning the motor or by simply replacing the unit. Look for a couple wires on top of the plentum.
Old 01-27-2009, 03:46 PM
Magnetic Mechanic's Avatar
Magnetic Mechanic Magnetic Mechanic is offline
Didn't the 93's have obd1? If so you can eliminate sensors as you would get a check engine light on fail. Does the fuel pump relay come on with the ignition, or is it responding to the oil pump switch? Could also be a bad pressure relief in the fuel manifold, i think that can fail w/no code.
A butterfly without wings,
is just an ugly bug
Old 01-27-2009, 06:52 PM
Billdacat's Avatar
Billdacat Billdacat is offline
Talking Re: Jeep Grand Cherokee
I sort of agree with UCHOG on the idle air control motor. In your case I would post this question on the Jeep Unlimited Forum....
http://www.jeepsunlimited.com/forums...splay.php?f=50
Old 01-27-2009, 07:06 PM
Please let us know what you eventually find to be the problem
is just an ugly bug
Old 01-28-2009, 12:34 PM
rustywrangler rustywrangler is offline
Guess I will throw my 2cents. Go over to Jeepforum.com and check out their FAQ section. This is covered in there. Sounds like the air controler as well. Don't go to pirate4x4. They will eat you alive with this kind of question.
Here is a good link to the OBDI testing, even if you do not have a check engine light it still will record stuff sometimes: http://www.jeepforum.com/wiki/index....k_Engine_Codes
Come try it out and stay a while.
Old 02-05-2009, 03:22 PM
SaW's Avatar
SaW SaW is offline
Some good advice right there. They don't really love newbies over there
HTML code is On
