Old 01-26-2009, 07:17 PM
Brianstick Brianstick is offline
Special impact sockets
Has anybody ever tried those impact sockets that have the corners cleared out so it grips the fastener by the sides insted of gripping on to the corners?
Old 01-26-2009, 07:32 PM
farmersamm's Avatar
Re: Special impact sockets
Never have tried 'em. Still use my old Mac 6pt sockets, and have never rounded a fastener yet.
For regular non impact I prefer 6pt also. Only 12pt I have is for 3/8 drive smaller sockets.
6pt sockets actually can work pretty well in tight areas if you use a fine tooth ratchet
Old 01-26-2009, 07:37 PM
ed mac's Avatar
ed mac ed mac is offline
snapon has had them for years
Old 01-26-2009, 07:40 PM
lugweld's Avatar
lugweld lugweld is offline
Location: south GA where its hot in summer and cold in winter
Yes,
Their grip is like a pit bull, but be aware that the pressure in the corners is severe enough if the fastener won't budge, it can "eat" the corners off.
Welders:
Esab Migmaster 250
Penncraft 230 (oldy but goody)
HF Plasma 30 (Italian)
Lincoln Ranger 8
Smith Oxy/Acetylene/Propane
New to the family:
Lincoln SA200
Everlast Power Tig 250 EX
Everlast PowerUltra 205
Aka..The Everlast Pimp...
Old 01-26-2009, 07:55 PM
David R's Avatar
David R David R is offline
Moderator
I use em all the time. They work.
David
Real world weldin.
Old 01-26-2009, 08:39 PM
Mandau's Avatar
Mandau Mandau is offline
Good stuff I have a set of Facom
Unit in my fab shop dept:
my good hand and team that trust me...
A lone welder make art... a village full of welder make Miracles...
Old 01-26-2009, 11:20 PM
rlitman rlitman is offline
All my sockets have a little extra clearance in the corners. Snap On has been calling this flank drive for what seems like forever, but I've got 20 year old craftsman sockets with the same idea.
I have seen though, that after -much- use, the socket can wear in a way that gets it stuck on the fastener.
Old 01-26-2009, 11:31 PM
farmersamm's Avatar
Are the inside surfaces of the "special" sockets milled, or broached?
I think most standard sockets are broached. Pretty expensive specialized tooling and machine.
Old 01-28-2009, 09:42 PM
dougspair dougspair is offline
...A few years ago, I saw a video on the 'net, Craftsman sockets, flank drive, impact and non-impact. They are mostly all made from round bar stock, square drive hole is broached after drilling, then the rest is cold-formed. Takes about 7-10 seconds to make the sockets....all done on automatic machines of course.
The larger size sockets have some CNC lathe work on the outside diameter...reduced at the drive end.
Then are heat-treated and plated, sizes are now laser etched on most of the chrome plated hand-stuff....that takes a second or two.
Impact sockets have the sizes/numbers rolled on in a machine that turns the socket against the number stamp on a moving rack. Heat-treated after that, then black oxide finish.
Open end and box-combination wrenches are forged, then the openings are broached.
Snap-On pioneered the flank-drive name, but now with patent expired, most all the tool companies are doing it.
Only sockets I've seen that are broached from the open end are the cheaper softer stuff....same goes for 'imported' allen socket screws.
As far as the allen bolts go...most all are cold formed, threads rolled on, then heat-treated/case-hardened....can't dril them out unless you use carbide drill.
Proto at one time had a sequential picture demonstration on here ('net) of how they make the hand wrenches.
Dougspair
HTML code is On
