Oxy Fuel
Post your Oxy fuel pics, questions and comments. This is temporary unless it takes off.
David
Real world weldin.
Re: Oxy Fuel
Well I guess this is close enough to our own section. So what does everyone weld with their OA setups?
Re: Oxy Fuel
I use mine for auto body sheet metal. I have an old Smith Airline I have had for 40 years and I also have a Dillon, Henrob, or Cobra what ever you want to call it. The company has been sold three times and they change the name each time. Same torch though.
Charlie Last edited by 59halfstep; 02-11-2009 at 12:34 PM. |
Re: Oxy Fuel
well i just got my o/a set.its a prostar made by victor. i got the full sized bottles too. i will be posting on here hopefully soon. im having to get a second job to make ends meet.
weldpack 3200 squirtgun precision tig 225 with cart prostar o/a setup with full size bottles |
Re: Oxy Fuel
My Craftsman (Harris) carried me for years (no 220v available in the house). But since I bought the TIG, I could almost throw away the O/A............. almost.
9-11-2001......We Will Never Forget Retired desk jockey. ![]() Hobby weldor with a little training. ![]() Craftsman O/A---Flat, Vert, Ovhd, Horz. ![]() Miller Syncrowave 250
Re: Oxy Fuel
The first time I operated a torch was when I was in the 8th grade metal shop class; one of the assigned projects was a small hammer made of 1/2" square CRS, cut at an angle so it tapered to a wedge in back and drilled and filed to get a nearly square handle hole. I guess I put more care into mine than the average student and had even polished it nicely before mounting the handle, when the teacher asked if I'd like to harden mine. I, of course did although I had no idea how to; he showed me how to case harden it's ends with the oxy-acetylene flame, which I did for quite a while, afterward quenching it in water. I got it more than file-hard, but it surely took a long time to sand and re-polish the surface again! Anyway, that opened my eyes to OA torches and what they could do; by my college days, I had my own Harrris rig in the dorm room closet for a while.
I still have and use that hammer, mostly for working on firearms and other smaller stuff in my room. The polish isn't quite like new but the head still isn't mushroomed after the extensive use it's gotten. |
Re: Oxy Fuel
We use it everyday in my shop, silver soldering mainly brass to stainless, which can be a bit tricky at times.
Re: Oxy Fuel
Pictures! I mentioned the rain in another post. Here is what I tacked with the torch. It's already painted though, and sort of a temporary/semi-permanent fix...cart handle. Right on the edges, I want to try some more with the torch, it makes for a nice change in pace compared to mig welding on the time-clock!
City of L.A. Structural; Manual & Semi-Automatic; "Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore." Job 28:1,2 E-tig;SP135t;XMT304;NKJV Bible Danny
Re: Oxy Fuel
For example you could use it to: Heat stubbornly stuck parts that need separating: Or braze a handle onto a valve's brass stem: Maybe heat up a pan of grits - or whatever that was! Even heavy sections can be cleanly cut with a hand held torch: And precise shapes can be cut with machine guided torches: Quote:
Yet O-F is uniquely different enough from any electric process, that it deserves it's own forum. Good Luck |
Re: Oxy Fuel
[quote=denrep;252128...that it deserves it's own forum.
Good Luck[/QUOTE] I meant "that it deserves its own forum" Not "it's" If you don't mind correcting that and deleting this! |
Re: Oxy Fuel
Here is a project I did about 8 yrs ago. I was at the clients office and saw the old trailer sitting there. ...bring back not so fond memories fo a couple of crazy hot days made hotter with the torch. I just added all the strap and top angle.
Re: Oxy Fuel
i found a brand new setup on ebay a smith or victor for 85.00 and that includes everything and i talked to the guy at welder supply store is it easier to lease the tanks or just buy em outright any thoughts? i guess it would depend on how often you would use oxy fuel
Re: Oxy Fuel
Well I own all of mine, (2) 150 acetylene (2) 250 Hydrogen (2) 250 Oxygen (2) BBQ propane. Add on to that all the Argon, CO2, and C25 cylinders and im supprized the ATF isnt on my case! Leasing isnt a bad deal for the bigger tanks. For people just getting into welding I usually recomend a set of the "burgular" bottles ( MC acet and 20cf Oxygen ) and a nice little carry-all. Then lease a big set if they have a big project. That way they always have something for a quick job, and arent paying lease on a tanks they arent using. On the same token match the tanks to the torch and work. If its a little aircraft style torch, then small tanks are ok. The big agricultural torches should be fitted to larger tanks, of course always following the withdrawl rules of acetylene cylinders.
Re: Oxy Fuel
Thought you guys might get a kick out of some of my "stable" of torches. With the exception of the large oxweld , all are in new or restored condition. The oldest here is the Marquette "P" from about 1921 and the newest is the Harris 19-6 from this year.
Re: Oxy Fuel
Wow. That photo just made this thread immortal.
Re: Oxy Fuel
Naw,
The individuals and companies that designed and made these tools would make it immortal Unfortunately many do not exist anymore, and the art is dying. Smith and Harris are the only companies here in the US that still have burner engineers on staff. Smith actually did a re-design on some of their products in the last couple years, and my hats are off to them. The new valves on the AW1A handle are a vast improvement, and the new regulators are wonderful, with a touch of elegnace in the cast handles. I was sent 2 prototype sets of regulators to test a couple years ago....and your going to have to pry them from my cold dead hands. Unfortunately quality of design really matters when it comes to torch performance, and its lacking in the mainstream tools. I sometimes wonder if this is part of the casue of frustration for people trying to weld, especially materials like aluminum and nickel based alloys. Oh here is a pic of the latest soon-to-be edition to the torch family. A 1913-1915 Oxweld W1, this is about half way through the restoration and overhaul. Valves are all new, soldered joints repaired and tubes straightened and dents removed. Once I machine a new mixer and tips we are all set! Oh and the threads are all metric non-standard.
Re: Oxy Fuel
Re: Oxy Fuel
Re: Oxy Fuel
Makoman 1860 - That's a nice arsenal!
![]() Thanks for posting it. I wonder what the combined BTU potential is?!? ![]() Good Luck Last edited by denrep; 02-16-2009 at 08:24 AM. |
#20
Re: Oxy Fuel
Damn Makoman 1860
. Thats pretty serious machinery you got there buddy!! Im looking to get a DHC 2000 this weekend. Out of that entire lineup which torch do you like to use on butt welding 18-22 gauge sheetmetal?
#21
Re: Oxy Fuel
Hey,
Glad you asked! For the sheet size you mentioned the Meco N Medget, followed by the Victor J40. Especially if your going to get into hot working sheet parts and such its amazing how nice the position of the valves are for quick adjustment, lighting, etc. A word of caution, if you get the Meco, get the tips from Kent at www.tinmantech.com. The factory meco tips went to garbage about a year ago with a cost reduction, so Kent had the original design tooled back up for himself. The Dillon (DHC 2000) has a nice flame, but weighs a ton and has no advantage really as far as welding over a well made traditional style. Its almost impossible to use on some tight tubing clusters due to the design. However the sheet cutting is nice on it, I wil give it that, and I use it on castings with an extension. For work on things like tubing clusters, exhaust parts, etc I love the "aircraft" style torches. These are typically round handle, forward valves, "A" size fittings. Of the currently made ones I find the Smith Aw1A (airline)and Harris 15(aircrafter) at the top. Of the out of production models there is the much sought after Meco Aviator Jet, The ultra rare Meco Aviator, and the Oxweld W-29. Hope this helps!! -Aaron |
#22
Re: Oxy Fuel
Fellow in another forum asked about stainless welding, and on the subject of flame setting. The old books typically say a 1x reducing, and I have found this to usually work the best. Much over 2x and the puddle can get mushy, and anything near oxidizing...well you know. So I made him a quick sample to show the difference. Enjoy!
316 stainless .040 308 filler Solar B flux Meco Aviator Jet #2 tip |
#23
Re: Oxy Fuel
I use O/A for cutting steel. Also for bending, annealing, and tempering some stock or pieces of certain scales.
Also use it for brazing. And welding steel up to about 5 mm thickness. Someone already mentioned loosening frozen nuts & bolts, and it can be good for that. |
#24
Re: Oxy Fuel
#25
Re: Oxy Fuel
