Old 02-11-2009, 02:05 PM
viper522 viper522 is offline
Great video - shielding gasses
You can't find a better example than this
Old 02-11-2009, 04:22 PM
rode2rouen's Avatar
rode2rouen rode2rouen is offline
Re: Great video - shielding gasses
I'n no MIG meister. Can someone explain why they were using any gas for FCAW?
I was under the impression that flux-core was intended to be used without shielding gas.
Rex
Old 02-11-2009, 05:27 PM
Scott Young Scott Young is offline
t9 wire is a dual shield wire.
Old 02-11-2009, 06:14 PM
shott8283 shott8283 is offline
is t9 mandatory dual sheild.. will it weld fine with out the added shielding gas?
Old 02-11-2009, 07:54 PM
weldrwomn weldrwomn is offline
Rex
Only self-shielded Flux cored wire is meant to be used without gas. Manufacturers also make gas shielded flux cored wires that are meant to be used with a variety of shielding gasses.
None of the T9 wires that I am familiar with will weld at all without gas. The several that I am familiar with use CO2 as their shielding gas.
Old 02-11-2009, 11:58 PM
rode2rouen's Avatar
Cool, I learned something today!
Rex
Old 02-12-2009, 09:29 PM
t9 wire will look like honeycomb or pumice if there is no gas.
Old 02-12-2009, 11:12 PM
quasi quasi is offline
i wish they would have done penetration samples along with that. i always loved straight co2 for doing FCAW stringers when i was putting SAW over them
Old 02-13-2009, 10:32 AM
Nitesky Nitesky is offline
Video no longer available.
Gordie
"I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Lincoln Weld-Pak 100
Canox Sparkler AC/DC
Lincoln SA-200
Harris Torch
Miller Elite Helmet
Old 02-13-2009, 10:49 AM
Still works for me, try reloading
Old 02-13-2009, 10:55 AM
The video says "We are sorry but this video is no longer available". Clicked on some others that scroll across the bottom. Most of them work but some say unavailable too.
Dunno but maybe the format is not supported by my Slackware Linux but I'm not curious enough to start messing with things right now.
Gordie
Lincoln SA-200
Harris Torch
Miller Elite Helmet
Old 02-13-2009, 11:51 AM
lotechman lotechman is offline
The only little problem with changing gas is that it will change the physical characteristics of the weld metal. Most wire packaging will give different impact strengths and ductility values between carbon dioxide and CO2/argon mixes.
Recently I notice more attention is being given to impact strengths especially with seismic structural codes. We have been giving this more attention in colder climates for many years.
Bottom line is.. results may vary.
