Old 02-20-2009, 05:01 PM
Brainfarth's Avatar
Brainfarth Brainfarth is offline
muck bucket
We have 2 more large jobs roll into the shop a few weeks ago and now we're plugging away at them. One is a 54" buck bucket and a 30" version of the 54". What makes these unique is that after he drills and fills the bucket with dirt, he reverses the bit and closes the door. Then he pulls it out of the hole and smacks the trigger and the lid assembly pops open to release the dirt. Here are some photos of the original and some of the work we have started. I drew on these pictures with paint.net to aid in the cad drawings and if any questions came about as the project progresses. They are going to take the old drill away shortly.
Common sense in an uncommon degree is what the world calls wisdom.
Old 02-20-2009, 06:05 PM
Magnetic Mechanic's Avatar
Magnetic Mechanic Magnetic Mechanic is offline
Re: muck bucket
Well if that ain't as slik as snot on a doorknob.
A butterfly without wings,
is just an ugly bug
Old 02-20-2009, 06:58 PM
farmersamm's Avatar
farmersamm farmersamm is online now
Re: muck bucket
Some equipment designs are amazing. You gotta wonder who comes up with the ideas.
Do you use cold drawn extrusions for your hinge barrels.
I used to be able to get 1022 cold drawn stuff in just about any wall thickness, and .010 over on the bore to fit a standard cold roll pin size. I can't get it any more. A 1" id extrusion is exactly 1", and I have to ream it oversize until I get my lathe up and running. Then I can just take a few thou offa the pin instead.
This is the kinda stuff I enjoy workin' on. Looks like it's coming along really good
Old 02-22-2009, 02:03 PM
lars66 lars66 is offline
Re: muck bucket
I have done some repair on smaller versions of the ones in the pictures , also made up a variety of fishing tools when the contractor lost one 100" down the hole.
Old 02-22-2009, 02:13 PM
flatbustedbroke flatbustedbroke is offline
Re: muck bucket
100"(inches) or 100'(feet) down in the hole? I guess at this size its a pain either way but 100' down in a hole is whole lot more of a pain the a**!
Old 02-22-2009, 02:37 PM
Re: muck bucket
flatbusted, 100 feet, well 97' actually.
Old 02-24-2009, 06:48 PM
Brainfarth's Avatar
Re: muck bucket
The center pin for the drill face is 3.5" id with 5" od pipe and the hinge is 2" cold roll round stock(I think) with pipe machined 2" id and 4" od. I made a little more progress on the bit today. I had to burn some T1 which the cutting bits ride on, which required a 30 degree bevel on the end, so I set it up on edge and propped it to the side of the table to get a nice clean cut. The slag fell off when I dropped it on the floor. Then I started assembling the kelly box assembly. And the last picture is of the bits welded out and ready for placement. Most of the bucket is mild steel. The kelly box, latch assembly and various drill face components are T1.
Old 02-24-2009, 09:45 PM
farmersamm's Avatar
Re: muck bucket
You really have a well equiped shop. The track torch is fantastic. Shear, and other goodies. It represents a lot of hard work and saving up to buy, and hard work to keep it busy. It looks like you've done well.
The work reflects your drive to get to where you're at now. It's really nice stuff. I don't recall ever seeing anything crappy come out of your place.
How much for the gumballs???
Old 02-24-2009, 10:03 PM
Brainfarth's Avatar
Re: muck bucket
The gumballs are free if you can get them unstuck. The metal muncher has been a life saver. But it hasn't paid off it's 65k price tag yet.. Maybe a few more years down the road.
Old 03-04-2009, 09:55 PM
Brainfarth's Avatar
Re: muck bucket
Over the past week, we managed to place and weld the teeth to the AR plate, weld out both kelly boxes and welding in the latching arm. I'll have closer pictures of that later when we cut things lose and open the tops for the last of the welding. The rotating lid is held in with a 3 1/2" pin that is threaded. The second photo is of the stop to keep that side of the lid from spinning and allowing the hinge to bust apart trying to hold it shut. I'm sticking around a few hours late tonight to do more work on the teeth and fill in all the little gaps under them.
Old 03-04-2009, 10:18 PM
farmersamm's Avatar
Re: muck bucket
Wow, even the teeth are set at different angles along the bar. Nothing straightforward about the job at all.
Old 03-11-2009, 07:04 PM
Brainfarth's Avatar
Re: muck bucket
So here is the rig with the new bit attached. A pic with it open, and a pic of me welding on the 30" bit.
Old 03-11-2009, 10:56 PM
farmersamm's Avatar
Re: muck bucket
Really enjoyed watching this. The size of the bucket really comes into perspective when it's mounted on the truck.
Old 03-11-2009, 11:34 PM
lugweld's Avatar
lugweld lugweld is offline
Location: south GA where its hot in summer and cold in winter
Re: muck bucket
Is there some overtly masculine statement with that last pic?
Good work...Are the teeth replacable? I see the shanks are weld on. but I can't see whether the teeth are pin on or weld on. What brand are they?
Welders:
Esab Migmaster 250
Penncraft 230 (oldy but goody)
HF Plasma 30 (Italian)
Lincoln Ranger 8
Smith Oxy/Acetylene/Propane
New to the family:
Lincoln SA200
Everlast Power Tig 250 EX
Everlast PowerUltra 205
Aka..The Everlast Pimp...
Old 03-12-2009, 12:34 PM
Brainfarth's Avatar
Re: muck bucket
Yeah, the last photo is a bit much. My co-worker thought it was funny and snapped the pose, so I went with it... One style of the teeth are a twist on with a rubber that prevents the tooth from twisting back off. The other is a straight on design with a pin.
Old 03-12-2009, 10:45 PM
daddy's Avatar
daddy daddy is offline
Re: muck bucket
Great job Brainfarth.
Jarret
Old 03-14-2009, 05:45 PM
Brainfarth's Avatar
Re: muck bucket
Soo.... After a little over 200 hours in labor, countless hours behind a tape measure, they were shipped down the road yesterday and today. Now I can finally catch up on all my little projects.
Old 03-15-2009, 02:51 AM
sdonecker sdonecker is offline
Re: muck bucket
What kind of money did the customer end up paying for this job?
Old 03-15-2009, 03:10 AM
Oldiron2 Oldiron2 is offline
Re: muck bucket
Are the rectangular cut-outs (seen in the next-to-last shot, on the release lever 'guide' ) to keep dirt from packing around the spring?
To close the hatch, is is just moved sideways while lowering it?
It looks like hard facing on the lower perimeter of one, but not the other? Is that correct, and if so, why?
[You get paid for welding but not for answering lots of dumb questions! ]
Old 03-15-2009, 02:04 PM
Brainfarth's Avatar
Re: muck bucket
Not sure what the final tally is.. We are still adding up materials and machine work.. but to get you in the ball park, over 200 hours at 65 an hour for our labor and 85 an hour for all the cnc plasma work.
The cutouts are access for the springs. they are under pressure, so you have to be able to pry them down just to get the end screwed on. And to open it, we fabbed a wider plate on his machine so when he lifts the bucket all the way up, it trips the latch.
And the hard facing was to be done by the customer to help cut some costs.
I do get paid to answer lots of questions, but the company isnt making any money at that time. Alot of time, it hurts my billable hours in a day. Guess that is what happens when you hire too many green guys at the same time.
Old 03-15-2009, 03:02 PM
Joker11's Avatar
Joker11 Joker11 is offline
Re: muck bucket
Can I come work in your shop and sweep floors? I bet I could learn alot if I slowed down when I swept by your jobs.
That is way cool.
Thanks for posting up. I hope you get to put tons more jobs on here!
Lincoln Power Mig 350MP Ready Pak
Lincoln Ranger 9
Lincoln LN-25 wire feeder
Lincoln Water Cooled Tig Module with HF
Lincoln Water Cooler
Lincoln WeldPak 100
CK TIG TORCH gas diffuser and pyrex cup
Old 03-18-2009, 12:21 AM
RancherBill RancherBill is offline
Re: muck bucket
Very impressive.
I have never seen anything like these. Are they used for digging footings?
