6013 question
a 6013 rod on dc positive is a medium to low petration rod correct i just askin me and a friend are in argument a 6010 is a deeper penetrating rod
Re: 6013 question
6010 is deeper yes
only thing worse than an ugly woman is an ugly weld |
Re: 6013 question
6013 is a low penetration rod excellent for part build up and repair of non critical cast steel. ...6010 digs about as deep as you can get. A 6011 is a deep penetrating rod as well. 7014 is a low but slightly more penetration than a 6013..
Who won?
Welders: Esab Migmaster 250 Penncraft 230 (oldy but goody) HF Plasma 30 (Italian) Lincoln Ranger 8 Smith Oxy/Acetylene/Propane Lincoln SA200 Everlast Power Tig 250 EX Everlast PowerUltra 205 |
Re: 6013 question
6013 is a medium penetation all position, general purpose rod.
That information is right out of my pocket welding book by Hobart company. 6010 is a deep penetration rod with very little build up. It is often used for a root pass on pipe. 6011 is also a lot like 6010 and is often used on galvinized pipe like chainlink fences. they both have a nitro cellulose base.
AWS certified welding inspector AWS certified welder 44 years experience. Miller 110V 140 MIG Miller Elite auto sensing helmet. |
Re: 6013 question
yea thanks i just made me fifty bucks i thought thats how it was and my friend had diffrent thoughts but thanks everyone
Re: 6013 question
I've seen you post about 6013 being good on cast steel a few times now. I just wondered if it's reccomended for that. My experience with 6013 has always been pretty much the opposite. It has a tendancy to crack when welding cast. Seems it doesn't handle the cooling stress too well.
Re: 6013 question
Farmersam, you talkin about cast STEEL or cast IRON.
David
Re: 6013 question
I referenced "cast steel" at the begining of my post, then said "cast" later in the post. The entire question was about cast steel. Sorry
Re: 6013 question
7018 for cast steel, never tired 6013.
7018 takes on some of the properties of the parent metal. I don't know about 6013. Its truly a sheet metal rod.
Re: 6013 question
Until I got familiar with 7018, I used 7014 ocassionally, and had pretty good luck with it. And I might of been just that.........Pretty damn lucky Now it's 7018 all the way with lottsa preheat.
