Old 02-24-2009, 03:11 PM
MetalArchitect MetalArchitect is online now
everlast plasma cutter Cut 50 - pics
Order the cut 50 a while back ( about 2 months ago) after some issues with getting in touch and shipping "mishaps" i got the machine! Set up the garage for 220v with new sub-panel, cut off switch, and outlet. plugged her in and got to cutting. Cut 1/8" bar for a while and than cut some 3/16" angle and 3/16" bar to make a window well grate. Works great!
Tried to tackle some 1/2" it cut it but was slow and messy ( I probably need more practice)
here are the pics:
http://i244.photobucket.com/albums/g...1/DSCF0056.jpg
http://i244.photobucket.com/albums/g...1/DSCF0055.jpg
http://i244.photobucket.com/albums/g...1/DSCF0057.jpg
http://i244.photobucket.com/albums/g...1/DSCF0059.jpg
http://i244.photobucket.com/albums/g...1/DSCF0061.jpg
http://i244.photobucket.com/albums/g...1/DSCF0064.jpg
Old 02-25-2009, 07:11 PM
specter's Avatar
specter specter is offline
Re: Cut 50 - pics
Looks good what is the grate part of?
You may want to use a piece of wallboard as a straight edge and try adjusting your air pressure
Also do you have a water/air filter on thhat unit?
Old 02-25-2009, 08:03 PM
EVERLAST_SUPPORT EVERLAST_SUPPORT is offline
Re: Cut 50 - pics
Nothing really to add other than I agree with Spector. Air pressure and good dry air will help a lot. Otherwise you spend a lot of time grinding. Also cut straight down if you are doing less than 5/8"s.
It does take time to freehand with the plasma cutter. Drywall works or use C clamps and angle iron for a straight cut.
Mike R.
[IMG] code is Off
HTML code is On
