Go Back   WeldingWeb™ - Welding forum for pros and enthusiasts > WeldingWeb Disciplines > MIG, TIG, Stick, And Oxy/Fuel Welding
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
View Poll Results: Which is Better?
AC 1 4.35%
DC 22 95.65%
Voters: 23. You may not vote on this poll
Thread Tools Display Modes
Old 02-28-2009, 01:14 PM
ArcBurn007's Avatar
ArcBurn007 ArcBurn007 is offline
Which Polarity Is Better AC Or DC For Stick?
Personally I prefer DC
Old 02-28-2009, 01:37 PM
Sandy Sandy is offline
Re: Which Polarity Is Better AC Or DC For Stick?
Well AC vs DC isn't really a polarity issue in the technical sense. With DC there are, naturally, choices of DCEP or DCEN.
Old 02-28-2009, 01:46 PM
Newfie_1986 Newfie_1986 is offline
Id rather DC. Unless im running a 7024, I prefer to run them on AC
Old 02-28-2009, 02:52 PM
farmersamm's Avatar
I don't know if I could say one is better than the other. I think it depends on what type of rod your using, and whether you're able to work with the rod and your machine to your satisfaction.
First 2 pics.....6011AC two different angles of same weld
Next 2 pics.... 7018DCEP
DC seems gentler smoother, and easier to control the puddle though. Hell, I dunno
I'm currently involved in a hot love affair with 7018, so.............
Old 02-28-2009, 03:10 PM
Hammack_Welding's Avatar
Hammack_Welding Hammack_Welding is offline
Neither is better than the other. The rod alot of times will dictate the current used. I run DC most of the time, but on occaissions have run AC for varying reasons.
Old 02-28-2009, 03:18 PM
Tim Tim is offline
The only input I would make on this is that if you are saving money up to buy a machine, you are better served by saving some more and buying a DC capable machine, and thereby having the choice of not only AC vs DC, but polarity for the DC. That said, a backyard welder on a budget can accomplish a lot with an AC only machine and they are often available for cheap on the used market.
Old 02-28-2009, 08:52 PM
Nitesky Nitesky is offline
It is harder to strike an arc with AC, especially with lower amp settings. At times it is impossible to maintain an arc at low amp settings with AC.
If you ever want to weld thin material then you may find that DC is easier to use.
Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Old 02-28-2009, 11:15 PM
6010's Avatar
6010 6010 is offline
DC electrode positive gives you deepest penetration. Then comes AC. And then DC electrode negative.
AC can be a little harder to learn with as mentioned above because the arc is a little harder to start and the current is going through zero 120 times a second. Good AC rods have things in their coating to help stabilize the arc. For anyone other than someone running his first beads, I don't think the arc problem with AC would even be noticed.
AC is useful when arc blow is a problem.
DC electrode negative is useful when welding something thin.
Old 03-01-2009, 12:22 PM
Ken Dennis's Avatar
Ken Dennis Ken Dennis is offline
I am not the best to be answering this question, as I am re-acquainting myself to stick after using a mig almost exclusively for many years!
But anyway, AC and DC both have their uses, in a nutshell I would say AC for thick material and DC for thin, for just an off the top answer, but DC is smoother for less spatter!
Ken.
#1. If you don't like what I wrote, or if it offends you, then don't read it!
#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Old 03-01-2009, 09:10 PM
quasi quasi is offline
from my experience running a sub arc AC spreads DC digs. so neither is good nor bad just depends on what you are doing.
Old 03-01-2009, 11:46 PM
Fat Bastard's Avatar
Fat Bastard Fat Bastard is offline
What a strange question.
Did you ride the bus to school or carry your lunch?
When did you stop beating your wife?
What rod are you welding with? What material are you welding on?
Brucy is an admitted unemployment cheat. AND he is PROUD of it. Kentucky should be proud. Shame on you Bruce.
Prophet Mohammed, womanizer, child molester and ruthless killer?
Tags
italldepends
