Old 02-28-2009, 09:27 PM
bdeditch's Avatar
bdeditch bdeditch is offline
OK whats the trick with Ring Rollers??
I have been trying to bend a 1/4 inch rod into a 18 inch circle. It keeps wanting to curl up like a cork screw. What the trick to keeping it straight?
Old 02-28-2009, 09:41 PM
Tensaiteki's Avatar
Tensaiteki Tensaiteki is offline
Re: OK whats the trick with Ring Rollers??
Are you bending the rod a little at a time or trying to achieve the desired radius all at once?
Does the roller you are using have groves in the rollers to keep the rod going straight through the machine?
Visit Tensaiteki.com
Old 02-28-2009, 09:46 PM
aametalmaster's Avatar
aametalmaster aametalmaster is offline
I assume you are trying to roll 1/4" round bar right? Sometimes it will go goofy because of how it was straightened it has a built in curve to it but it is straight and when you roll it it goes back the other way...Bob
Bob Wright
Salem, Ohio Birthplace of the Silver & Deming Drill
http://groups.yahoo.com/group/southbend10k/
http://groups.yahoo.com/group/sawking/
1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Old 02-28-2009, 11:14 PM
Broccoli1's Avatar
Broccoli1 Broccoli1 is online now
You really a helper.
If you need to do a lot of them, find something to wrap the 1/4" around- mucho easier.
TA 185
Miller 125c Plasma 120v
O/A set
Old 03-01-2009, 01:03 AM
bdeditch's Avatar
Yes I have been doing a little at a time. They seem to be going good then all of a sudden they make a hard turn to the right.
bdeditch's Avatar
Do you mean just heat them up and wrap them around a large metal circle?
Old 03-01-2009, 08:13 AM
Ironmower Ironmower is offline
HUH????? Jigs are great!!!!!!!!!!
Don't let that iron in your lungs, turn to lead in your @$$!!!!
Old 03-01-2009, 08:45 AM
DSW DSW is offline
I had similar problems trying to do 8" dia rings out of 1/4" with a ring roller and multiple passes.
The best cheap way I found was to make an undersized ring from some old pipe with a center axle. Tacked the rod to the ring, then turned the ring with a big wrench on the axle until the rod wrapped past the start point by several inches. Cut the tack with a wizzer wheel and then cut thru the over lapped sections. the rings would have a bit of twist but they weren't too bad. You have to cut the end off because the 1st 1" or so wont bend quite right. After the 1st one the little bit of extra bend on the rod left from the previous bend helps with that 1st 1" or so. Trial and error will be needed to figure out how much the rod springs out after you stop trying to bend it. You'll have less problems with the twist and spring back than I did because you have a bigger dia.
Eventually the cust agreed to switch to flat stock over the rings. I use the same jig to do the flat stock and have eliminated the twist all together since I can over run the flat where I had to run up next to the rod when I reached the start point.
Old 03-01-2009, 12:38 PM
Broccoli1's Avatar
1/4" you can bend cold, no problem but as DSW mentioned you have to find the correct diameter to allow for Spring back.
and the helper comment was iffin' ya try to use the Ring roller- the helper watches for the Cork screw and straightens it out- still a PIA
I used a piece of Pipe and cut a notch for the stock, start wrapping the stock around and then just remove the "Coil", compressed it in a vise, cut it with a sawsall.
If you have a Plasma cutter you don't need to put it in a vise
TA 185
O/A set
Old 03-01-2009, 12:51 PM
Broccoli1's Avatar
Couple pics of rings- smaller than you're making but you get the idea.
Small Rings
TA 185
O/A set
Old 03-01-2009, 12:52 PM
Broccoli1's Avatar
Medium Rings
TA 185
O/A set
Old 03-01-2009, 12:55 PM
Broccoli1's Avatar
This is what I call the "Thing"
TA 185
O/A set
Old 03-02-2009, 11:04 AM
bdeditch's Avatar
THANK YOU!!!!! You have given me some darn good ideas now!! Thanks to all that posted, your help is always great.
Old 03-03-2009, 06:15 AM
mrmikey mrmikey is offline
I used to run a set of rolls where I used to work. Round bar is a pia to roll. If I had a bunch to do I'd tack them side by side and roll them as a bunch. Leave them a couple of inches longer and cut off the flat spot , my 2 cents worth...Mike
Old 03-03-2009, 11:42 AM
bdeditch's Avatar
Now this idea I like, I will try that.
Old 03-03-2009, 07:02 PM
mb_welder's Avatar
mb_welder mb_welder is offline
Reminds me of when I used to build rapier hilts as a hobby. If a ring went wonky in the bending process, I would simply bend it back. Nothing a hammer and a vice couldn't fix!
Old 03-03-2009, 07:07 PM
bdeditch's Avatar
You know if it was a smaller size, but when I tried to bend back this 1/4 inch stuff it looked like a easter egg by the time I was done
Old 03-05-2009, 03:08 AM
weldbead weldbead is offline
i recently received a harbor freight planetary gear type ring roller with the features tensaitekai describes in response to OP. see foto.. 1/4" rod is in approximate starting position, moves left to right as machine is cranked ....it seems to me, because the manual is poor at describing how to operate the tool, adjustable (lower right) wheel is moved down initially to align with two driven wheels and allow max 1/4" rod / 3/16" flat stock to be inserted..then raised with handwheel to apply upward pressure against rod .foto reflects this upward pressure condition.. my question is and i hope it helps answer OP's original question , is in this foto position it feels like the upward pressure exerted by the handwheel is maximum, tight.. just by the fact that it is sa handwheel it is only intended to apply a limited amount of pressure.. ..at that point it feels like the rod needs to be cranked through the machine forward and back just a little to start it bending, which relieves the upward pressure permitting me to take another bite with the handwheel , if you want a tight radius this might get repeated several times.. does this seem right? it is a lot of trial ands error, and entire process needs repeating for each ring.. makes all the tried-and-true methods described here make more sense than a ring roller machine...
Old 03-09-2009, 04:13 PM
artworksmetal artworksmetal is offline
I've used one of these for years, they take some getting used to. The round bar does want to wander - have your keep pushing it back in line as you go.
You are limited as to how big a bite you can take on the first pass, and plan on cutting that first inch or so off as waste if your looking for a true circle.
If you're trying to get more than one the same size, then do them assembly line style or you'll be cussing. These are not conducive to repeatable bends, unless decrease the radius very slowly as you get close to the desired radius.
"We live in an age when unnecessary things are our only necessities. "
- Oscar Wilde
Maxstar STL150
Eagle CPM30 Bender
Old 03-09-2009, 04:32 PM
OK, I just noticed you said an 18" circle. It's been a while, but If I remember, by the time you run 5 ft of rod through this you do have something less than a circle and more like a pigtail.
Try this - do your first bend fairly light, so you end up with a large "C". On your later passes, as you close up the gap, have your helper torque both ends of the "C" to bring them back in line.
Great opportunity to get the wife involved...
As far as starting the bend, back the rod off a little so the end of it as at about the 11 o'clock position on that leading roller.
HTML code is On
