Old 03-06-2009, 11:33 PM
eyspy's Avatar
eyspy eyspy is offline
Interval & spot timer ????
I am still learning my way around MIG welding with my recent purchase of a used WIA210s from a farm auction here in Australia.
I have two controls on my welder that I am not sure what they do ?
I have put a link to my welders manual. Go to page 6 and number 5 & 6 (circled) are the contols I am talking about.
Any help much appreciated.
http://www.masterhire.net.au/uploads...LDM%20210S.pdf
Old 03-07-2009, 01:57 AM
DesertRider33's Avatar
Re: Interval & spot timer ????
That is a spot welding timer. I have that on my HTP as well. On mine, one control sets the length of time the welder is 'on' duing the spot weld and the other control sets the length of time the welder is 'off' between spot welds, if I remember correctly. It's been a few years since I've used that feature. Your's is probly similar. The purpose is to aid in making consistent intermittent spot welds along a sheetmetal seam, among other things.
MM350P/Python/Q300
MM175/Q300
DialarcHF
HTP MIG200
PowCon300SM
Hypertherm380
ThermalArc185
Purox oa
F350CrewCab4x4
LoadNGo utilitybed
Bobcat250
XMT304/Optima/Spoolmatic
Suitcase12RC/Q300
Suitcase8RC/Q400
Passport/Q300
Smith op
Old 03-07-2009, 09:41 AM
duaneb55's Avatar
duaneb55 duaneb55 is online now
What DR33 said is the way I read the feature description in the posted manual eyspy which differs slightly from the Spot Control on my Miller MM200.
On the Miller, the 'Weld Timer' controls the length of time the current and wire feed is activated once the gun trigger is pulled and the 'Burn Back' is the length of time the current remains on after the wire feed stops. This prevents the wire from sticking to the weld but too much Burn Back and the wire could wind up sticking to the contact tip.
MM200 w/Spoolmatic 1
Syncrowave 180SD
Bobcat 225G Plus - LP/NG
MUTT Suitcase Wirefeeder
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
SA-200 Blackface Code# 8638
Star Jet 21-110
Old 03-07-2009, 10:21 AM
Duane, the spot feature on your Miller I think is probly the best for complete control out of the machines from that era. I had considered the Millermatic 200 when I bought the HTP. Got a better deal on the HTP.
MM350P/Python/Q300
MM175/Q300
DialarcHF
HTP MIG200
PowCon300SM
Hypertherm380
ThermalArc185
Purox oa
F350CrewCab4x4
LoadNGo utilitybed
Bobcat250
Suitcase12RC/Q300
Suitcase8RC/Q400
Passport/Q300
Smith op
Old 03-07-2009, 06:06 PM
eyspy's Avatar
Thanks for the replies.
Not sure if I will ever need that feature, but at least I know what it is for now.
Old 03-07-2009, 10:40 PM
Oldiron2 Oldiron2 is offline
Duane,
My MM200 has a 'continuous,' a 'spot' and a 'pulsed' position; in spot, it uses the 'on' timer and 'burnback' control while in the 'pulsed', it uses the 'on', the 'off' and the 'burnback' controls. The pulse 'on' time varies from .5 to 4 seconds, while the 'off' time runs from .25 to 1 second according to my manual (which happened to be handy).
I think the control #6 on that machine corresponds to our 'off' time for pulse welding. and his machine doesn't have a manual burnback control. In the description for the "Interval Control", it talks about 'Cycle Arc Mode" which I interpret to mean our 'pulse' mode. I also have heard it called "stitch' welding, perhaps in the Bible.
