Old 03-22-2009, 12:59 AM
GunLocators GunLocators is offline
New to Plasma Quick Question
Ok just bought a New In Box powermax 600 and I really like the quality so far. I may of missed it in the book and did not see in the video but being new to plasma I thought I would ask before assuming something is wrong with a brand new machine.
I start a cut everything is fine at end of cut release trigger and I still have air coming out seems it stops only if I depress the trigger again? Is this normal or should it auto stop the airflow immediately?
Equipment
Lincoln 200SA
TrailBlazer 275
MillerMatic 252
Hypertherm Powermax 600
Old 03-22-2009, 01:06 AM
Magnetic Mechanic's Avatar
Magnetic Mechanic Magnetic Mechanic is offline
Re: New to Plasma Quick Question
It should stop after a few seconds. It is cooling off the torch.
A butterfly without wings,
is just an ugly bug
Old 03-22-2009, 01:11 AM
Sandy Sandy is offline
Your manual may refer to that as "post flow". Maybe as long as 20 seconds??
Old 03-22-2009, 01:40 AM
DesertRider33's Avatar
It's normal, my Powermax 380 does the same thing.
MM350P/Python/Q300
MM175/Q300
DialarcHF
HTP MIG200
PowCon300SM
Hypertherm380
ThermalArc185
Purox oa
F350CrewCab4x4
LoadNGo utilitybed
Bobcat250
XMT304/Optima/Spoolmatic
Suitcase12RC/Q300
Suitcase8RC/Q400
Passport/Q300
Smith op
Old 03-22-2009, 10:56 AM
lotechman lotechman is offline
Avoid pulling that trigger extra times. Each time you initiate an arc at the torch in the air you cause double arcing inside the plasma torch. The arc travels between the electrode and nozzle shortening the life of your consumables. Don't start your cut in the air and don't run your cut off the edge of the plate into the air.
Also torches have a bit of preflow before the arc is initiated.... Perfectly normal.
Old 03-27-2009, 07:14 PM
papabear's Avatar
papabear papabear is offline
"Post flow" is your torches friend.
"SOUTHPAW"
A wise person learns from another persons mistakes;
A smart person learns from their own mistakes;
But, a stupid person.............never learns.
Old 03-27-2009, 11:21 PM
Ken Dennis's Avatar
Ken Dennis Ken Dennis is offline
Yup, normal.
my PM 600 does the same thing!
#1. If you don't like what I wrote, or if it offends you, then don't read it!
#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
