Old 03-24-2009, 01:18 AM
Skippii Skippii is offline
What happens if you stick weld aluminum with AC?
Since all the rods are labled for DC, I'm guessing it won't turn out great.
What happens?
1. You can never start an arc
2. The rod burns straight through the alu.
3. The weld never penetrates
4. The weld looks fine, but will break as soon as a feather falls on it.
5. The weld works just fine on AC, it's just a bit more difficult.
"To tell which polarity to use go to the bathroom and pour some water down the drain. If it runs clockwise use straight polarity. If it runs counter-clockwise use reverse polarity. Or if it just gurgles use alternating current." -RandomDave
Old 03-24-2009, 01:42 PM
Fat Bastard's Avatar
Fat Bastard Fat Bastard is offline
Re: What happens if you stick weld aluminum with AC?
I use GTAW
Somewhere in the world there is an indiginous pigmy praying to a Jet plane flying overhead thinking it's his God, he might just be the sanest one of us all. bigwhitebeast
Old 03-25-2009, 01:09 AM
jdustu's Avatar
jdustu jdustu is offline
I screwed around with some stick aluminum welding last year. The rods were old, but I dried them out a bit and gave it a go. I honestly can't remember what my setting were....I know I tried them all
I just messed around with it for a hot second, I'd be interested in seeing some pics from guys with experiece in sticking aluminum! I've looked for pics before and haven't found any.
Here's my crap, I did a few t-fillets:
Old 03-28-2009, 09:42 AM
Dr Crane's Avatar
Dr Crane Dr Crane is offline
Tried it, didn't like it. Much better results with DCEP and a lot more amperage than with steel of the same thickness. Be prepared for 1/8 rod to go away in less than 10 seconds.
