Old 03-25-2009, 07:53 PM
Bikespot's Avatar
Bikespot Bikespot is offline
Feeds and speeds
I'm looking for some formulas for feeds and speeds for different cutters. Manly the speeds for cutters.
Old 03-25-2009, 09:29 PM
farmersamm's Avatar
Re: Feeds and speeds
Some stuff to at least get a starting point
Hope it helps
Old 03-25-2009, 09:32 PM
farmersamm's Avatar
Might have to copy the first chart to your computer and resize/zoom whatever......
Site only allows 800x600 uploads
Old 03-25-2009, 09:35 PM
farmersamm's Avatar
Resized on my end, lessee how this works..........
Old 03-25-2009, 09:37 PM
farmersamm's Avatar
No better I guess.
Just copy the stupid thing and ZOOOOOOOOOOOOOM IN ON IT
Old 03-25-2009, 10:10 PM
Bikespot's Avatar
I cant read that chart.
You can upload it on image shack or something and post a link.
Old 03-26-2009, 12:21 AM
farmersamm's Avatar
I'm really sorry.
My copy is only 900 pixels wide, so it won't be much better even if I did put it up somewhere. I just zoom in on mine when I need it.
Right click and "copy picture as", and ya got it.
I forgot where I got it. An evening of surfing the net. Needed some info, and spent the time to get it. I usually don't even use it anymore since I found out what my machine's capable of.
Actually the Surface Feet Per Minute calculator in the second chart is the most valuable. It gives a rough starting point, and actually will vary with the HP of your machine, the finish desired, and the type of cutter(HSS, Carbide, Cobalt, etc), and whether you're using coolant. I don't believe there are any set parameters that hold absolutely true with different variables. As far as I know SFPM is a pretty constant value regardless of what kind of cutter you are using. From a drill to a face mill. When it comes to a starting point I think it's mostly about the speed of the outside edge of the cutter. Feed rates go all over the board. Different style cutters, and different materials react differently when it comes to chip load.
There's probably some really good machinists here that can add to this.
Again, I apologize about the quality of the pics
Old 03-26-2009, 12:55 AM
tanglediver's Avatar
tanglediver tanglediver is offline
Everything you ever wanted to know about machinery, but were afraid to ask, can be found in one little 2,693 page book.
http://www.google.com/search?hl=en&q...=Google+Search
Speeds and feeds, page 1022.
Job 28:1,2
E-tig;SP135t;XMT304;NKJV Bible
Danny
Old 03-26-2009, 12:09 PM
farmersamm's Avatar
Tangledriver recomended the BEST book out there!
But knowin' y'all, and not bein' willin' to spend the moola, or do a search.........
I remembered where I found the info. It's at http://www.niagracutter.com/techinfo...eed/index.html
I ain't good at links. I had to copy this on paper, and do it by hand
Old 03-26-2009, 12:12 PM
farmersamm's Avatar
It's all out there. It's what God gave ya a mouse for
Bet more folks spend more time searchin' for porn than the other stuff
[IMG] code is Off
