Old 04-07-2009, 06:25 AM
jman jman is offline
Lincoln Easy-Mig 180 with Magnum 100SG spool gun ?
How would this setup work for metal up to 3/8" and for thinner Aluminum ?
Almost all of my beads will be quite small and much of the welding will be simple tack welds.... I was curious if anyone else has the same or has used a similar setup ?
What typically can one weld in Aluminum with such a spool gun ? I am also very curious about how the aluminum spool gun compares with a 'mid line' TIG machine ?
Cheers,
/Jman...
Old 04-07-2009, 11:49 AM
Broccoli1's Avatar
Re: Lincoln Easy-Mig 180 with Magnum 100SG spool gun ?
Only Mid line Tig with AC would be a Miller Diversion 165- about 1,300.00
Here is a thread on the Lincoln Spool Gun
http://weldingweb.com/showthread.php...coln+spool+gun
but note he has the Power Mig C
MM211
TA 185
Miller 125c Plasma 120v
O/A set
Old 04-07-2009, 01:04 PM
Are the two not the same ? I assumed that both were "C" and that the MIG PAK was "T".
Have I got it wrong ?
Cheers,
/Jman..
Old 04-07-2009, 01:16 PM
Broccoli1's Avatar
Only model that is Continuous Voltage selection is the C model
Power Mig 140C
Power Mig 180C
ALL other models are Tapped Voltage section
SP 180t
MigPak
Easy Mig
etc
MM211
TA 185
O/A set
Old 04-07-2009, 01:56 PM
Power Mig 140C
Power Mig 180C
SP 180t
MigPak
Easy Mig
etc
CRAP !
Well that's not what I wanted.... I would prefer the continuous voltage vs the Tapped. Especially since I want to foray into Aluminum. Maybe I should just suck it up and go to a TIG machine ! I'm joining a lot of dissimilar metals with my torch now anyway.... I know the cost is going to be a lot higher but maybe I'm better off. Problem is, I don't know squat about TIG machines. Any suggestions ?
Cheers,
/Jman...
Old 04-07-2009, 02:39 PM
Broccoli1's Avatar
It comes down to $$ and how thick you need to go
MM211
TA 185
O/A set
Old 04-07-2009, 10:43 PM
Well,
Thickness isn't really an issue for the stuff I do. I would like to do some thicker Aluminum but most of that would be tacked into place as NONE of it would be load bearing or stressed in any way as it would be mostly ornamental / Artwork.
I see that Miller has a new unit out called the "Diversion 165". I found some decent pricing around the city and thought it might be perfect for what I need it for....
Most of my stuff:
20 gauge to 3/16" steel sheet / plate
20 gauge to 1/8" Aluminum
22 gauge to 1/8" Copper and Brass / Bronze
Square and round stock in both copper, stainless and mild steel
Cheers,
/Jman...
Old 04-07-2009, 11:40 PM
Originally Posted by jman View Post
Well,
Most of my stuff:
Cheers,
/Jman...
Moving this to a new thread... Thanks People, you've been HUGELY helpful !
Cheers,
/Jman...
