1/8 steel and 3/16 steel and the Lincoln Electric Handy MIG Welder
Folks I'm considering the purchase of the Lincoln Electric Handy MIG Welder. My hobbyis is to design and fabricate steel ornament work with 1/8 and 3/16 steel. My 2 questions are,. the LE Handy Mig welder is spec out to weld up 1/8 steel,..I have a 1/8 thick by 2" wide and 24 inches long steel curved in the shape of an "S". I want to weld this "S" shape steel standing on the surface of 3/16 thick steel plate (10x30x3/16), though this mig welder is spec for "up to 1/8 steel", will I be able to accomplish the weld with this mig welder?
I plan on only using flux wire in all my current and future welds,.. will I get enough power from the LE Handy Mig using flux wire to accomplish this? I was also considering the Hobart Handler 125 (which can weld steel up to 3/16 thick) from online, but would like to stay with Lincoln Electric only because I can gets parts easily and quickly at Home Depot, Lowes and Sears. And I haven't found a Home Depot, Lowes or Sear to stock Hobart parts. And I have considered the Lincoln Electric 125, but the price is too expensive for me. Thanks everyone. Last edited by Alec217; 04-19-2009 at 06:53 PM. |
Re: 1/8 steel and 3/16 steel and the Lincoln Electric Handy MIG Welder
Isn't the Lincoln Handy Mig a 100 amp machine? I don't know, mine are 220 Volt.
Mark I haven't always been a nurse........ Craftsman 12"x36" Lathe Enco G-30B Mill Hobart Handler 175 Century 230 Amp A/C stick welder Chicago Electric 165A DC TIG Oxy/Acetylene set PapaLion's Gate Build |
Mark, the Lincoln Electric Handy MIG Welder is actually a 115volt setup and 35-88amps.
Alec,
The HH 125EZ gets really good reviews. Buy a few spare tips and yer good to go. http://www.hobartwelders.com/weldtal...ighlight=125ez read Rocky D's post and then search out his profile and other posts on welding. I wouldn't worry too much about being limited to On-Line for supplies. You can get the wire at HD, Lowes- and that is usually what you run out of anyway. Heck, buy the Lincoln and try it, don't like it return it.
Ed Conley http://www.screamingbroccoli.net/ MM252 MM211 Passport Plus & Spool gun TA 185 Lincoln SP135 Plus- (Gone to a good home) Miller 125c Plasma 120v O/A set SO 2020 bender Beer in the fridge |
