Old 04-21-2009, 10:12 PM
farmersamm's Avatar
Working on Non Level Surfaces
If you don't have a nice level concrete floor to work on. Line sighting is the thing for you I suppose this could be done with a level, but it doesn't take distortion into consideration. Some of the members of your weldment have probably pulled a little bit. You may have to split hairs.
For me anyhow, in this situation, it's all eyeball, and using known straight edges, to align the structure.
Also, unitize if you can. Build in units that can be joined. Make sure the smaller units are SQUARE!!!! In this kind of deal, you can't rely on levels unless you want to make your life miserable.
This time around I leveled the second bay (remember, the first bay was already built square, it's a known factor) of the rack by laying a piece of tubing across all three arms of the shelf, then clamped the tubing to the middle of all uprights(it's a pretty good chance that you'll get an average of all the uprights). Next I sighted the uprights top and bottom, and added shims under the runners as needed.
YOU MUST PAY PARTICLAR ATTENTION TO MAKING ALL MEASUREMENTS CORRECTLY, AND BUILDING SQUARE BEFORE JOINING UNITS
Stand far back, and sight all planes. Horizontal, and vertical. Once you are satisfied, tighten the clamps, and tack it. Again tack on braces to hold it true while finish welding if possible
A little note on tacking. For me anyway, it seems to work best to tack on the inside of the "C" on channel. Tack each flange, squaring in between, the lock it up by tacking on the web. When leveling use shims, and have a helper standing by to assist with lifting the heavy stuff
Old 04-21-2009, 10:22 PM
littlefuzz's Avatar
Re: Working on Non Level Surfaces
Lookin good!! Is the left upright leaned out or is that just the way it looks in the pic?
Dewayne
Dixieland Welding
MM350P
Lincoln 100
Some torches
Other misc. tools
Old 04-21-2009, 10:32 PM
farmersamm's Avatar
I think it's the distortion of the camera lense.
Now I gotta get up first thing in the morning and stress about it, and check it
Old 04-21-2009, 10:33 PM
farmersamm's Avatar
littlefuzz's Avatar
LOL, sorry
Dewayne
Dixieland Welding
MM350P
Lincoln 100
Some torches
Other misc. tools
Old 04-21-2009, 10:38 PM
farmersamm's Avatar
Choked on my brew. Geez!!!
It's square, I checked the diagonals.
Dude you're messin' me up
I think they use the same angle/distortion thing in porn shots
Old 04-21-2009, 10:53 PM
duaneb55's Avatar
duaneb55 duaneb55 is online now
Sam I think the far lookout is 1/10th of a pixel off.
MM200 w/Spoolmatic 1
Syncrowave 180SD
Aircomatic MIGet CAV II
Bobcat 225G Plus - LP
MUTT Suitcase Wirefeeder
T/D PakMaster 100XL
Marquette Star Jet 21-110
WC-1S/Spoolmatic 1
Old 04-21-2009, 10:55 PM
littlefuzz's Avatar
It can measure right diagonally and still be out of square.
Dewayne
Dixieland Welding
MM350P
Lincoln 100
Some torches
Other misc. tools
Old 04-21-2009, 10:58 PM
farmersamm's Avatar
I just hope the whole thing doesn't collapse in my lap when I start loading it with steel. This is my first experiment with reinforcing the flange that's under stress, and I'm not sure I added enough meat on the stress side.
I thought, after looking at it, that I also need to add a crossmember across the front of the runners. It's gonna be sitting on soft ground, and the extra support will keep it from nose diving. It's gonna settle, but I'd like it to settle in a controlled manner
Old 04-21-2009, 11:00 PM
duaneb55's Avatar
Have you considered backing it up to the 'machine shop' and tacking it to the outer wall?
Syncrowave 180SD
T/D PakMaster 100XL
WC-1S/Spoolmatic 1
Old 04-21-2009, 11:01 PM
farmersamm's Avatar
Also, channel has a tendancy to roll to one side or the other without lateral bracing. There's gonna be a lot of force on the front end of the runners. It's a whole different thing than having it on a solid concrete floor. There's the possibility that not all runners will equally be supporting the weight depending on how it settles
Old 04-21-2009, 11:03 PM
duaneb55's Avatar
I don't know what all you plan on throwing up there but I believe you'll find that channel will hold alot more than you would think.
Syncrowave 180SD
T/D PakMaster 100XL
WC-1S/Spoolmatic 1
farmersamm's Avatar
The container is settling as we speak My luck, it would pull the crazy thing over backwards
I need a real building
Old 04-21-2009, 11:05 PM
littlefuzz's Avatar
Assuming that both pieces are cut exactly the same it should be square.
Dewayne
Dixieland Welding
MM350P
Lincoln 100
Some torches
Other misc. tools
Old 04-21-2009, 11:07 PM
farmersamm's Avatar
Duane, I was looking at the shelves and spacing. It's gonna be real tempting to put a LOT of stuff up there. Ten full sticks of 3" 3/16 square tubing weighs around 1200 lbs. and that's not counting the other stuff that's gonna be on there.
Might just see my feet sticking out of the mess when it's all said and done.
I think a little prudence is in order
Old 04-21-2009, 11:08 PM
farmersamm's Avatar
I may have seriously underbuilt the uprights
Old 04-21-2009, 11:23 PM
Road Warrior's Avatar
Road Warrior Road Warrior is offline
Personally, I would have opted for an A frame design. Since it's going to be outside, space isn't really an issue (I wouldn't think so anyhow).
However, given what you've done so far, it looks good to me.
A place I worked at a few years ago had a steel rack made completely from 1.5" heavy wall sq. tube. It was bolted to the building posts, the horizontal members that held steel were about 18" long, angled slighty upward, with a short gussett (maybe 5" long) under them. It was loaded with 3" sch. 80 pipe 20' long, lots of 1,2,&4" sq. tube, misc. flat bar of various thicknesses.
Suffice it to say it was loaded to the max yet very solid.
I think you'll be ok. Your rack is built way more stout than what we had.
The only recommendation I would give you is to put a gussett under the horizontals that will be holding your material.
Old 04-21-2009, 11:29 PM
Greyhorse Greyhorse is offline
If your container is off the ground any you can slide the back of it underneath. If it's on the ground then you might still be able to with a little digging. Those containers are amazingly stable, especially once you pack a bunch of stuff in them. I've got a 20' and a 40' side by side that I welded together for extra stability (figured it would be harder for wind to turn them both over than just one) mine are also on concrete blocks so I can re-level as they settle.
HH 187
Miller 1E
Old 04-21-2009, 11:30 PM
farmersamm's Avatar
Might pay to add a gusset. Recently switched to 7018, and maybe I'm expecting too much from it.
The shelves are 26" . It's a pretty far piece considering the weight on it.
Old 04-21-2009, 11:32 PM
I edited your picture, the red lines are the gussets I would add. Looking again, one up the back may be a good insurance policy too.
Old 04-21-2009, 11:42 PM
farmersamm's Avatar
It would relieve the stress, I'm not sure about the ultimate benifit of the flange reinforcement I have now.
We're lookin' at basiclly the same thing as a jib crane considering the cantilevered load out front. Just how much will the upright resist the tendancy to bend
Old 04-21-2009, 11:55 PM
That depends on several key factors - the numerous placement possibilities of ferrous and non-ferrous metals on the rack, atmospheric density subcutaneously discharging multiple rays of gravity deflecting ions, the spinning motion of the earth in relation to the lunar phases, and well, I don't know!!
Old 04-22-2009, 12:01 AM
farmersamm's Avatar
Old 04-22-2009, 12:02 AM
Sandy Sandy is offline
It's called "fish eye" effect. Anything around the perimeter of the lens is especially subject to the effect.
Old 04-22-2009, 12:23 AM
Tractapac Tractapac is offline
Samm, in my opinion that would be a first.
I may have missed something but does anyone recall when Samm seriously under built anything? Everything I've seen has looked pretty sturdy. The only shakey thing I've seen is the wheel change on the tractor.
You could put another set of shelves on the back and extend the feet too, of course and split the loading more evenly.
"One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)
