Old 04-22-2009, 12:39 PM
1awert1 1awert1 is offline
does anybody have a swivel head horizontal saw
I have it down to several saws, but does anyone here have or use the newer style horz. saw with the swivel head??? and what do they think of it. can it be tipped up to use in a vertical position...
Old 04-22-2009, 03:14 PM
weldbead weldbead is offline
Re: does anybody have a swivel head horizontal saw
my grizzly swivels to allow angular cuts. i belive 90 degrees one way, 45 in the other.
Old 04-22-2009, 06:19 PM
arvidj arvidj is offline
If you are thinking of ones similar to this Northern Tool bandsaw or this one Homier bandsaw then yes.
Like all of the imported saws you need to go thru them, clean them up, replace the lubricants, replace the blade with something of quality and adjust the heck out of them.
After that they have both been great saws for what I use them for. I have used both of them in the vertical mode even though only one of them came with a table. The one that did not come with a table said it could not be used in the vertical position but with a little effort I have used it vertical. I had the feeling it was more of a legal-liability disclaimer than a real technical issue.
And the flexibility to easily make angled cuts made the extra dollars over a 90 degree only saw well worth it to me.
Old 04-22-2009, 07:00 PM
tapwelder tapwelder is offline
I have a jet swivel head. It can be used vertical. It does not come with a table for vertical cutting. You do have to release the down feed cylinder to go vertical.Not big deal to go vertical however, only one large thumb screw to remove.
Nice space saving saw and accurate.
Old 04-22-2009, 07:56 PM
imc188222 imc188222 is offline
I have an Ellis, it can be used vertical. You have to make a table for it though.
Miller millermatic 251
Miller aircrafter 330st, wp20
1961 Lincoln SA200
Ellis 1600 bandsaw
Logan 820 lathe
South Bend 13"
Bridgeport M Head
Old 04-22-2009, 09:42 PM
Xtreme Fabrication's Avatar
Xtreme Fabrication Xtreme Fabrication is offline
Behold the power of a ellis. The 1100-1600 can swivel and have a optional table you can used for vertical work.
Lincoln
300 Vantage 2008
300 Commander 1999
SA250 1999
SA200 1968
Miller
Syncrowave 200
XMT350MPA/S-52E/xr-15
Xtreme 12vs
Millermatic 251 w/30A
Millermatic 251
Dialarc 250
Hypertherm 1250
GEKA & Bantom Ironwokers
Old 04-23-2009, 07:26 AM
I did not realize there was a table available. I guess I spoke to soon. I have the 1600, I bought it used and wanted vertical capabilities so I made a table.
1961 Lincoln SA200
Ellis 1600 bandsaw
Logan 820 lathe
South Bend 13"
Bridgeport M Head
Old 04-23-2009, 12:32 PM
steve45's Avatar
steve45 steve45 is offline
http://weldingweb.com/showthread.php?t=11176
America Needs AMERICA'S Oil!!!
"Global warming is the greatest scam in history ...There is no run away climate change. The impact of humans on climate is not catastrophic. Our planet is not in peril."--John Coleman, Founder of The Weather Channel
Old 04-23-2009, 01:55 PM
Fat Bastard's Avatar
Fat Bastard Fat Bastard is offline
I have the Ellis 1600 Paid $3000.00 including shipping to Alaska. I have had the Jet Enco Chinese saws in the past, (all gone to the scrap heap now),
The Jet Chinese saws did not last for me and to get them cutting true one needs to spend hours Fing with them. Then there is the mess of that coolant all over the shop I don't miss that.
The Ellis is built in the USA wits US parts and US labor and it is one He!! of a saw. The fine tuning took a few minutes. Ant to swing the blade takes a second or two. If you want a saw that will last your life time and then sell for 1/2 what you paid for it then go with the Ellis. If you want something cheep and made by chinese slave labor you know where to go.
Brucy is an admitted unemployment cheat. AND he is PROUD of it. Kentucky should be proud. Shame on you Bruce.
Prophet Mohammed, womanizer, child molester and ruthless killer?
Old 04-26-2009, 10:38 PM
ed mac ed mac is offline
i realy like my grizzly its made in tiwan
and there customer service is great
pump motor died they sent me a new
one and didnt have to send old one back
HTML code is On
