Tools you can't live without in the shop
I've been welding now for a few years and really enjoy it. I'd like to get a wish list together of tools and machines that I could use in a shop. So, what does everyone out there find they can't do without? Or at least what tools or machines really make the process quicker and more efficient? Now, there isn't really anything to big or small that can't be mentioned here so let's hear it. Thanks, Nick. Already on my list is a plasma cutter.
Re: Tools you can't live without in the shop
chopsaw. and a million clamp of all shapes and sizes.
About a half of truck filled with welding clamps and of course a welder since its kind of hard to run a welding shop without some kind of welder.
Own farm:Harris oxyacy torch, lincoln 225, stick,Century 135GL mig, Hypertherm PowerMax 45 Plasma Cutter Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.& 2 Hypertherm HPR260's Plasma Cutter |
The one thing I wouldn't want to work without: Education... any and all I can get!
Ditto on the clamps. If you have 100, you'll need 50 more.
The best things in life all come on a stick! |
I am really enjoying and finding many uses for my American Bender (www.americanbender.com). Quite accurate and versitile machine. I would like to say my lathe, however I tend to end up making stuff that I could purchase and making up for the $ save in time spent fabbing.
I also agree on the clamps, you can never have too many. Also a 4 1/2" grinder along w/ a die grinder w/ flap wheels. Of course then you need an air compressor and--------------------- well, you know. The list just keeps growin'!!!!
Mike
Ol' Stonebreaker "Experience is the name everyone gives to their mistakes" Miller 175 mig Miller thunderbolt ac/dc stick Victor O/A setup Makita chop saw |
To the list already mentioned i would add a drill press and hydraulic press with brake.
Lincoln 225 AC Lincoln Mig Pak 15 Lincoln Mig Pak 10 Purox Oxy-Acet Outfit 20 Ton Press Honda Generator
A wench to pass me a beer when I get hot ...........
Mark I haven't always been a nurse........ Craftsman 12" x 36" Lathe Hobart Handler 175 Lincoln SP 175 Plus Oxy/Acetylene Some left over steel, lots of ideas |
Clamps, drill press, drill bits, band saw, work/welding table, more clamps, a couple of vises, several sizes of angle and bench grinders, hammers of all sizes and shapes, tape measure, even more clamps, straight edge, angle finder, square, yard stick, gotta have more clamps and so on and so on!
Oh! And a welder or two.
#1. If you don't like what I wrote, or if it offends you, then don't read it! #2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**! |
Gotta be this one.
Opens dog food cans, AND beer bottles!!!! ![]() ![]() ![]()
For that once in a while when welding isn't prudent.... Duct Tape
I buy tools all the time, even tools I don't currently have a use for. Somehow, they all end up being used once in a while. My wife used to question the need for such tools, but now she comes to me about once a month and asks, "Do you have a tool that I can use that will..."
Overall, I can only remember one tool that was a complete waste of money--an engine moving tool that was supposed to allow me to tilt the engine in my front wheel drive car to access the spark plugs in the back. It didn't move the engine nearly far enough to do the job. (The engine has to come out to remove the plugs).
America Needs AMERICA'S Oil!!! "Global warming is the greatest scam in history ...There is no run away climate change. The impact of humans on climate is not catastrophic. Our planet is not in peril."--John Coleman, Founder of The Weather Channel |
Or a v6 rav 4 |
The tools I use most often are vice grips, clamps, a square, tape meaure, soapstone, chop saw, flatbar, prybar, crowbar, and several sizes of sledgehammers, mainly 3 and 4 pounders. That's besides the welder, plasma cutter, grinders, O/A torch with a cutting tip and keeping a heating tip handy for bending purposes, and almost forgot a bench vise. Not to mention drill press and a hand drill with HSS bits.
The ol' Noodle is probably the best tool you own. Without the Noodle, the other stuff is just a bunch of metal
I call it liquid wrench - my oxy/acetylene burning outfit.
Looks like a stout rotisserie!!!
#19
#20
B f h
#21
WFM- Now I remember!!!
Tozzi- The coolest stuff you got was, if I remember, the deals for lifting plate. I can't remember exactly
#22
You're close! '93 Olds Cutlass with a 3.4 DOHC engine. The engine has to be dropped to change the spark plugs, the oxygen sensor, the alternator... No wonder Olds went out of business!!!
#23
angle grinder, cut off tool, hack saw, jig saw (i use that for everything) A WELDER OF COURSE! torches, bench grinder, and a good set or sockets and ratchets
#24
#25
That's the one!!!
