Old 04-23-2009, 01:01 AM
denrep's Avatar
denrep denrep is online now
Pulling exhaust manifold studs - the easy way
No drills, no taps, no EZ-outs.
Don't bother trying to turn the studs and chance breaking them, just cut ‘em off:
Get the pipe out of the way. Another method is to cut the flange off the pipe, leaving the stud intact.
cut! Cut! CUT! Stop the bloody cameras!
We apologize for the delay.
Your thread will resume shortly.
Your pointer is temporarily unavailable, however, please direct your attention to...
Manifold ears being heated. Vise-grips and candle on the ready. Candle wax to be drawn into the cooling threads as lube.
He's back!
Okay, Roll 'em
Old 04-23-2009, 01:20 AM
gizzardgutz's Avatar
gizzardgutz gizzardgutz is offline
Re: Pulling exhaust manifold studs - the easy way
Explain the candle wax lube better! To be drawn? Why doesn't it go up in smoke at that temp? I've never heard of such a thing.
Sorry about your pointer!! I get those regular.
"Time is a great teacher, but unfortunately it kills all of it's pupils." -Louis-Hector Berlioz
SA 200 Lincoln
Victor CA2460 w/310 mixing barrel
Victor CA2050 w/315 mixing barrel
Victor J-100
Old 04-23-2009, 09:04 AM
denrep's Avatar
GG - Things are hot, but they cool fast. I push the candle to the top of the hole, while I gently rock the stud back and forth. Yes, the wax melts like crazy and runs off, but it definitely helps, especially as the parts cool.
By the way, just because it's hot, the studs can't simply be cranked out. That's why the Vise-grips need only a small bite; if it takes more torque than the small bite will handle, the bolt is not ready to turn out damage-free.
Good Luck
Old 04-23-2009, 09:59 AM
I've never heard of the candle trick, can't wait to use it! I love off-the-wall sh!t like this.
SA 200 Lincoln
Victor J-100
Old 04-23-2009, 11:35 AM
Oldiron2 Oldiron2 is offline
Denrep;
Have you ever considered using spermaceti or jojoba oil instead of parrafin?
Old 04-23-2009, 11:45 AM
farmersamm's Avatar
I've never had too much luck with the camlock stud extractor thingie that fits on the ratchet. Usually breaks the stud.
This is a MUST DO for next time. COOL(or Hot)
I hear that Pointer Rehab is a long painful emotional process. Hang in there and remember the good times
Old 04-23-2009, 12:13 PM
59halfstep's Avatar
59halfstep 59halfstep is offline
The good times that pointer has had!!
Charlie
Old 04-23-2009, 06:52 PM
David R's Avatar
David R David R is offline
Moderator
I don't even attempt to remove manifold studs unless everything is red hot.
Thanks Denrep. Medical and mechanical repairs all in one post!
David
Real world weldin.
Old 04-23-2009, 10:46 PM
duaneb55's Avatar
duaneb55 duaneb55 is online now
Judy wants to know when was your last tetanus shot?
Now you'll find out just how many times a day you hit the tip of that pointer.
MM200 w/Spoolmatic 1
Syncrowave 180SD
Aircomatic MIGet CAV II
Bobcat 225G Plus - LP
MUTT Suitcase Wirefeeder
T/D PakMaster 100XL
Marquette Star Jet 21-110
WC-1S/Spoolmatic 1
Old 04-24-2009, 12:18 AM
tanglediver's Avatar
tanglediver tanglediver is offline
Pulling exhaust manifold studs - the easy way??
Au contraire! That pointer would beg to differ with the aft portion of the thread title!
Besides, my second grade teacher says it's not polite to point.
But I'm 'sposed ta be in college now, better check with Professor Farnsworth.
Job 28:1,2
E-tig;SP135t;XMT304;NKJV Bible
Danny
Old 04-24-2009, 05:13 AM
Tractapac Tractapac is offline
Wishing you a speedy recovery on the digit or pointer.
I was going to play with the word wick, as in the candle and looked it up in Apple's Dictionary. I'll let the reference speak for itself:
wick 1 |wik|
noun
a strip of porous material up which liquid fuel is drawn by capillary action to the flame in a candle, lamp, or lighter.
• Medicine a gauze strip inserted in a wound to drain it.
verb [ trans. ]
absorb or draw off (liquid) by capillary action : these excellent socks will wick away the sweat | [ intrans. ] synthetics with hollow fibers that wick well.
PHRASES
dip one's wick vulgar slang (of a man) have sexual intercourse.
ORIGIN Old English wēoce; related to Dutch wiek and German Wieche ‘wick yarn.’
wicked |ˈwikid| |ˈwɪk1d| |ˈwɪkɪd|
adjective ( -eder, -edest |ˈwɪk1d1st|)
evil or morally wrong : a wicked and unscrupulous politician.
• intended to or capable of harming someone or something : he should be punished for his wicked driving.
• informal extremely unpleasant : despite the sun, the wind outside was wicked.
• playfully mischievous : Ben has a wicked sense of humor.
• informal excellent; wonderful : Sophie makes wicked cakes.
• informal [as submodifier ] very; extremely : he runs wicked fast
So, in summary, we have: a wick in the candle, a medical dressing with wick to drain the wound, the rust surrounding the stud acts as a wick when heated and the wax applied, I note you "push the candle to the top of the hole" thereby avoiding the vulgarity of dipping your wick. You exhibit a wicked sense of humor and show us a wicked method of stud removal.
What more could I say?
WICKED
"One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)
Old 04-30-2009, 03:12 AM
92f150300six 92f150300six is offline
ive heard of this befor but i allways thought it was bs. now i want to try it.
Old 04-30-2009, 09:28 AM
specter's Avatar
specter specter is offline
Now just clean out the threads with a tap. Insert the new studs and as John Madden would say Bammmm your ready to go.
Own farm:Harris oxyacy torch, lincoln 225, stick,Century 135GL mig, Hypertherm PowerMax 45 Plasma Cutter
Old 04-30-2009, 10:38 AM
denrep's Avatar
"Bammmm" huh?
Is that like "drop" an engine in and "slap" a transmission in, and "pop" a rear end in it?
I was planning on thread chasing next.
I'm also trying to decide if I should pull the manifolds and replace the attaching bolts with stainless hardware, while it's out of the car.
With all the time I screwed away on the torch race, I probably could've had the engine ready to install in my old car.
Good Luck
Old 05-12-2009, 12:13 PM
scorpio_vette's Avatar
scorpio_vette scorpio_vette is offline
i've seen the candle trick done too. never done it myself though. i usually get it orange hot, and if i can access the nuts with a socket and impact, then just take it off that way. makes for some really cool spark fireworks. LOL
if i can't get an impact on it and have to do it by hand, then i get it orange hot and then hit it with PB-Blaster, or Seafoam Deep Creep. that **** is like magic in a can. specially the seafoam stuff. a couple heat/spray cycles, and you can usually get them out with a hand wratchet.
HTML code is On
