Go Back   WeldingWeb™ - Welding forum for pros and enthusiasts > WeldingWeb Disciplines > Welding Projects & Pictures
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 04-25-2009, 11:31 PM
duaneb55's Avatar
duaneb55 duaneb55 is offline
Made in China - Repaired in USA - or - Judy, Judy How Does Your Garden Grow?
Judy started working on her 'garden' this week and was getting ready to set some tomato plants in the half barrels she grows them in and brought to my attention the beating the wire cages have taken over the last few years and suggested a little welding project. How could I refuse? Besides, it was a perfect opportunity to use the SK-35 spot weld panel on the MM200. All six cages had several broken welds and some had rings completely broken off. At a couple bucks a piece some may wonder why we just didn't go get new ones but what kind of thread would that make for a welding forum? "Bought Some New Tomato Cages Today".
Here's how they looked before starting. Cleaned up the wire where all the broken welds were and straightened everything out as I went.
Close up of one of the welds. Not the best one but the clearest shot. Spot timer allowed pointing, pull the trigger and let the welder do the rest. Switch sides, pull trigger again and all done.
All six cages better than new a short time later. About the same amount of time it would have taken to run to Home Depot or Walmart to get new ones.
Welder settings using C-25 at 20cfh.
Close up of SK-35 Spot Weld Panel settings.
I can taste those fresh tomatoes already. Thanks for looking.
MM200 w/spot controller and Spoolmatic 3
Syncrowave 180 SD
Roughneck 2E
Aircomatic MIGet CAV II
Hypertherm Powermax 350
Marquette 'Star Jet' 21-110
WC-1S / Spoolmatic 1
Weldanpower 150
Old 04-25-2009, 11:34 PM
scotts_enterprises scotts_enterprises is offline
Re: Made in China - Repaired in USA - or - Judy, Judy How Does Your Garden Grow?
I would have done the same thing
Old 04-25-2009, 11:43 PM
farmersamm's Avatar
That's a pretty versatile machine Duane. I've never seen anything like it
Old 04-26-2009, 01:29 AM
duaneb55's Avatar
Sam, the spot weld control is really meant for working with sheet metal but I figured why not go ahead and use it for this quick project.
I've got a WC-1S weld controller with spot weld control and Spoolmatic-1 spoolgun set up too. With those you can set the weld time and burn back same as on the MM200. Another use for these could be consistent stitch welds in addition to controlled spot welding. 1lb aluminum, SS or MS wire spools can be used in the SM-1 spoolgun as required combined with the correct shielding gas.
Syncrowave 180 SD
Roughneck 2E
Weldanpower 150
Old 04-26-2009, 01:33 AM
farmersamm's Avatar
I've heard the spoolgun is really the way to go with aloooominum. I guess it's hard to feed thru a standard liner because it isn' t stiff enough.
Old 04-26-2009, 01:55 AM
Sandy Sandy is offline
Do whatever you have to do to keep the gardner happy.
Funny how much time a guy will spend on something like that. I'll do almost anything other than go into to the big box stores.
Old 04-27-2009, 12:14 AM
Bob's Avatar
Bob Bob is offline
If you want to make her some bigger ones Duane, you could make them out of 6"x^' concrete mesh. Just cut off the end ring but leave the verticals to stick into the ground. Makes a cage 5' tall. I like them about two feet around. Works good for big tomato plants.
Old 04-27-2009, 01:14 AM
duaneb55's Avatar
As long as the gardner keeps coming up with welding projects the weldor will be happy too.
Syncrowave 180 SD
Roughneck 2E
Weldanpower 150
Old 04-27-2009, 01:17 AM
duaneb55's Avatar
Thanks Bob - that's a great idea. In the past some of her bigger tomato plants have definately given the typical sized cage a run for its money.
Syncrowave 180 SD
Roughneck 2E
Weldanpower 150
Old 04-27-2009, 12:41 PM
Greyhorse Greyhorse is offline
I've made about a dozen of the concrete mesh tomato cages. They work great! A t-post and some wire holds them really well too. You don't get bent wire from the huge plants like with the store bought baskets.
HH 187
Miller 1E
Old 04-27-2009, 10:23 PM
danomite33's Avatar
danomite33 danomite33 is offline
I had to read the title of your post many, many, many times before the arc went full bright! Boy do I feel foolish. Guess I've been sniffing flux too long... BTW, Enjoy reading your posts.
Old 04-27-2009, 10:54 PM
welderShane's Avatar
welderShane welderShane is offline
Nice work duane!! When did you get that mm 200? I have'nt been on this site in a while!! Glad to be back. Looks like theres a whole bunch of new people!
Small and Whimpy + Steel tubing = Big and Beefy!!!!
Old 04-27-2009, 11:01 PM
specter specter is offline
Well I am glad to see that Judy is doing much better and has you helping her out in the garden.
Gee Shane where have you been hiding!!?? are you thats busy working?
Own farm:Harris oxyacy torch, lincoln 225, stick,Century 135GL mig, Hypertherm PowerMax 45 Plasma Cutter
Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.Hypertherm HPR260 Plasma Cutter
Old 04-28-2009, 01:00 AM
duaneb55's Avatar
. Didn't mean to throw ya a curve ball there danomite33.
BTW, thanks.
Syncrowave 180 SD
Roughneck 2E
Weldanpower 150
Old 04-28-2009, 01:09 AM
duaneb55's Avatar
Good to hear from you again Shane and you're right - a bunch of new folks. The project was certainly nothing earth shaking but still fun and I've had the MM200 for awhile now and before acquiring the rest of the 'fleet'.
Syncrowave 180 SD
Roughneck 2E
Weldanpower 150
Old 04-28-2009, 11:51 PM
Joker11's Avatar
Joker11 Joker11 is offline
That is way cool. My PowerMig 350MP has that feature and I haven't used it yet. Looks like your Miller did great! Now you have my mind going! Thanks.
I was wondering what the difference is between using the spot timer and just pulling the trigger for a short time? Does it function differently?
sorry, this is a new thing to me.
And my daughter just started her tomatoes last week. We have 5 green ones so far! whoo hoo! I can't wait to get my salt shaker and sit by the pool eating right off the vine!
Lincoln Power Mig 350MP
Lincoln Ranger 9
Lincoln LN-25
Lincoln Water Cooled Tig Module with HF
Lincoln Water Cooler
Lincoln WeldPak 100
CK TIG TORCH with gas diffuser and pyrex cup
Old 04-29-2009, 12:20 AM
Oldiron2 Oldiron2 is offline
The timer just gives a more repeatable weld, especially for short times on thin sheet metal. Being 'automatic', it doesn't get sidetracked the way some of us can, too.
Old 04-29-2009, 12:32 AM
duaneb55's Avatar
Joker11,
As I was telling Sam and as you probably know, the spot weld panel is really intended for use with sheet metal but I used it here just to use it and once I got it adjusted right it made it easy to produce consistent welds. Pretty much the same as one could get by just pulling the trigger for a short time as you mentioned. The 'burn back' adjustment assures the wire doesn't stick to the puddle when the 'weld time' times out because you would normally be using a special spot weld nozzle that rests on the material and the gun isn't moving. I was really just playing with the feature which could also be used for uniform length stitch welds.
Enjoy those tomatoes once they ripen!
Syncrowave 180 SD
Roughneck 2E
Weldanpower 150
Old 04-29-2009, 12:35 AM
duaneb55's Avatar
Oops - beat me to it Oldiron2 and that's a good way to put it.
Syncrowave 180 SD
Roughneck 2E
Weldanpower 150
Old 05-03-2009, 12:06 AM
dougspair dougspair is offline
...Well....I bought a MM200 in 1980, first one the welding store ever sold....and also bought the Miller plug-in spool-gun for aluminum mainly, doing semi-truck head-rack and fuel tank stuff....never got the spot attachment, but used the front panel space to install polarity reversing switch for using inner-shield....and have Tweco #4 mig-gun with 15 foot lead on there, dealer said Miller gun wouldn't hold up to the spray-arc I would be running most of the time...actually gave me $85 off the Tweco gun/cable-hose in exchange.
...And still using the same machine...never needed any repairs yet....contactor terminals, wire-feeder motor brushes, and gas solenoid all still looking like new...
Dougspair
Old 05-03-2009, 01:06 AM
duaneb55's Avatar
Yeah dougspair the MM200's are real work horses and I've though about modifying mine for switching polarity but quite frankly if welding conditions would require fluxcore I'd just break out the Syncrowave 180 SD or the Roughneck 2E and use stick.
Ironically, I have a 400amp #4 Tweco gun for my '81 MM200 as well should I need it for spray weld purposes to spare the 'original equipment' replacement GA-20 (gas hose failed inside the original gun).
Syncrowave 180 SD
Roughneck 2E
Weldanpower 150
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
