Old 05-01-2009, 09:36 AM
BMO BMO is offline
Cladding furniture with Stainless Strips - Any tips
Am I making an easy job hard work????
I have a table that I have to clad with 100mm / 4" Stainless Steel wide strips. The strips are 0.7mm (0.0276") thin. They go around the table and I am unable to bend the corners as the table manufacturer is not precise with her measurements. My problem comes in the joining of the two pieces where they meet. I used a contact adhesive to glue them to the table and then fuse welded the corners as we can't have anything sharp to cut people. The welds were then cleaned/de-bured and polished.
Is there better adhesives that are much stronger?
The corners are the hard work-difficult, not to burn through once you've glued it all down.
Any criticism or tips would be most welcome.
Tags
adhesives, cladding, glue, stainless, strips
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
