Old 05-07-2009, 07:24 AM
pyroracing85 pyroracing85 is offline
Stick being replaced
So who thinks stick wedling is being replaced by MIG?
The only plus I can think of stick is portablity but I am now seeing mig with portable wire drives that you can send out 50 or so feet.
Is stick going to eventually become a lost art?
Old 05-07-2009, 07:43 AM
LarryO's Avatar
LarryO LarryO is offline
Re: Stick being replaced
Stick will never become a lost art.
One advantage of stick is to be able to change the type of filler or stick in a second.
Try changing from mild to stainless in a hurry with MIG.
Old 05-07-2009, 07:47 AM
specter's Avatar
specter specter is offline
I don't think stick welding will ever leave. It may advance a bit but it will never fully go away. There are just too many applications that it still remains the best welding application.
For may folks stick welding is the first step they have into the welding community. I myself started at 6 yrs old on my father's old tombstone stick (which I might add still works).
Own farm:Harris oxyacy torch, lincoln 225, stick,Century 135GL mig, Hypertherm PowerMax 45 Plasma Cutter
Old 05-07-2009, 11:32 AM
Hammack_Welding's Avatar
Hammack_Welding Hammack_Welding is offline
Agreed, Each process has it's place. I don't think any of them will be lost. Try welding with wire in a 40mph wind, even with flux cored wire and see what ya end up with. Stick will always have its place.
Old 05-07-2009, 12:58 PM
mn welder's Avatar
mn welder mn welder is offline
coupla yrs ago in college a seen an article and flux core pipe welding is really taking off some bigger companies have already switched and it keeps costs down hope i dont start a real heated arguement in my opinon you have tobe willing to at least try it if it dont work it dont works if it works more money in somebodies pocket im not up on costs
Old 05-07-2009, 01:21 PM
papabear's Avatar
papabear papabear is offline
How long has OAW been around? Every form of welding has its advantages as well as its disadvantages.
"SOUTHPAW"
A wise person learns from another persons mistakes;
A smart person learns from their own mistakes;
But, a stupid person.............never learns.
Old 05-07-2009, 04:26 PM
ironman715 ironman715 is offline
Wire feed is cheaper. You can lay down more filler faster and have less waster(stubs from stick). The waste is whatever wire is left in the liner when you change the spool out. Many ironworking companies are heavy duty into wire feed...HOWEVER we still use plenty of stick. I doubt stick will ever go away in our lifetimes. I could see maybe OA welding because it seems the TIG process covers just about anything you might use OA welding for...but even then I am sure it will have a place.
Old 05-08-2009, 10:43 AM
dakook's Avatar
dakook dakook is offline
Think Boiler outage at a large electric plant. Think 20-30 guys or more climbing through hatches to get in the boiler. Scaffolding erected every were, string light wires/extention cords ran all over the place, stick welding leads ran in through the hatches with the machines out side. A$$holes to elbows every were. The half life of a mig gun lead would be about 10 minutes in such an environment as it would be kicked/stomped to death or other wise butchered. I like MIG, but I don't think stick is going away.
Old 05-08-2009, 01:10 PM
Hideandseek's Avatar
Hideandseek Hideandseek is offline
and stick welding is the only one where you can bend your rod and weld around a corner! LOL
Old 05-08-2009, 01:33 PM
Pressure_Welder Pressure_Welder is offline
Bah i wont touch a mig machine, stick or tig here. Sure MIG has its place, but Tig and Stick welding require the most skill by far, and please dont try and tell me any different, you could teach a golden retreiver to run a bead with a mig gun. As stated above try and run a root pass or cap pass with MIG outside on pipe.... good luck. Production welding is a different story of course.
Old 05-08-2009, 02:11 PM
I like to draw difference between MIG and FCAW. I know a lot of cats have trouble passing the unlimited all pos. test with the NR232 or NR233 .072 wire. But your right Dakook...I could not see mig standing up to the harsh boiler repair enviroment at all. Even a suitcase welder like the LN-25...might get pretty mashed up in there. Stick is certainly here to stay.
Old 05-08-2009, 08:48 PM
Jolly Roger Jolly Roger is offline
The last 3 construction jobs I worked used fcaw to build the boiler house, other structural was stick and pipe was stick and tig. I now run a fab shop in a manufacturing facility. Almost everything is done with stick and very little with mig. The Chinese scream bloody murder if they can spot a mig weld. I'd hate to have to try and do anything with a mig around a drilling rig, lol. Talk about trashed equipment. Nope the sticks will never be replaced completely. They are just too versatile.
The difference between art and craft is the quality of the workmanship. I am an artist.
Old 05-10-2009, 08:42 AM
JeffB JeffB is offline
Each process has its place where it's most efficient. At my work we use solid wire gas MIG in the shop, where 95% of what we weld is 1/8 mild steel. MIG is just plain quicker in a reasonably dry indoor environment. In the field though, working outside it has to be stick. 6011 for stitching 1/8 mild steel together, or 7018 for more critical welds like door latches and safety chains on rolloff containers.
Old 05-10-2009, 04:06 PM
David R's Avatar
David R David R is offline
Moderator
I ran stick off my ranger 250 most of yesterday.
When I get the piece work in the shop, its Wire All the way!
Stick is here to stay as long as I can work time and materials.
Truly its job specific just like any other process.
David
Real world weldin.
Old 05-10-2009, 08:14 PM
SR20steve SR20steve is offline
There you go, perfect example. Its just too easy to get in hard to reach places, when all you need is power and ground. No need for stringing out hose for shielding gas like TIG, no need for wire spools.
Steve Williams
Pipefitter, USW Local 5
Shell Oil Products US
Syncrowave 180SD, Maxstar 150 STH
Old Dialarc 250
Old 05-11-2009, 02:57 PM
wesdavidson wesdavidson is offline
Stick is being replaced everywhere it can be. We do about 50% wire, 40% tig, and 5% stick - but that is in a shop environment, in the field we used to run 95% stick. . But I agree that stick will last as long as consumables are available. Seems like the small mig welders are outselling stick about 4-1 or more. Too bad though, those little mig things probably disillusion as many folks as they bring into the career.
There have been sticks made for about any alloy or use out there. It is also about the easiest to set parameters on and get guys to stick to them. As long as you have current and sticks you can weld. I've stick welded at 60 deg below zero, in a blizzard, ( Jan 1 '78 western wyoming ) and a lot of times in rain and blizzards when it was warmer weather. I would hate to get a wire feeder to function there. Sometimes a feeder will take aday off even in a good clean warm shop under good conditions, and drive you nuts. Tig is nice until some one forgets to turn on the water, or drops the torch, or cuts the hoses.....or dumps the gas . .
When I have to teach new welders (about 80+ a year) I try to start out with tig, Set up a 14 ga coupon and have them run beads along the edges until they can see the puddle, and have some control. Then have them weld about 40 pieces together, then I go to wire feed, then stick. If they go with wire first they don't learn to see the puddle, if they start with stick then they think they have to see lots of sparks and smoke. Seeing the puddle, and good control are the 2 basics to any weld process.
Seems like hardfacing would be another process hard to do with wire
past work toys; lathes,mills, drills, saws, robots, lasers ironworker, shears, brake, press, grinders, tensile tester, torches, tigs, migs, sticks, platten table, positioner, plasmas , gleeble and spot. Retired June 30, 2009.
