how many amps
im poping the breaker on a 20 amp circuit with a lincoln 140 after about a 8 to 10 second bead. how many amps do i need. and if i were to buy a generator what kind can i get that would work
Re: how many amps
30 should do it.
David
Re: how many amps
I would think that breaker is fine...What else is using that circuit? How many amps draw does the machine manual (or tag) say it requires? Is this just at full power, or all settings? Are you using an extension cord (if so, how long, and what gauge wire)? Tell us more!
"Good Enough Never Is" MIller AC/DC Thunderbolt Hobart HH180, 125EZ Riland Cut 40 Plasma oxy/act outfit Tons of "stuff", all treasures to me! |
Re: how many amps
it says imput current @ rated output 20Amps. imput power 120/1/60
nothing else on circuit i think and its at full machine power but it was tripping the same at 75% power. was welding a metal rod to a flat piece. putting wheels on a engine houst. my old house never tripped a circuit so i never paid attention |
Re: how many amps
you night need to replace breaker maybe worn out or just a bad breaker
but from your other post you say it s in the gargae it could be a gfi breaker they are known to trip easy |
Re: how many amps
they are gfi in garage i did not think that the laundry room would be though was using a ridgid 10-3 cord
Re: how many amps
What welding wire and what setting on the Lincoln?
Ed Conley http://www.screamingbroccoli.net/ MM252 MM211 Passport Plus & Spool gun TA 185 Lincoln SP135 Plus- (Gone to a good home) Miller 125c Plasma 120v O/A set SO 2020 bender Beer in the fridge |
Re: how many amps
Lincoln Power Mig 140's require a 30 amp breaker
