Careful with those grinders, guys...
I've got a hobby interest in welding, but my day job is in drafting coordination for TransCanada Pipelines. We just had our weekly meeting and it was brought up that Canada has had two grinder fatalities in the past week. (Neither in my company, fwiw)
One was a 35 year old working near Red Deer. Grinding disk blew apart and killed him. I don't have any further information on that one. Second was a 60-something year old grinding on a wrought iron gate in BC. He had removed the guard on his grinder, was using a larger disk than the 5" grinder was built for, and was using a disk rated at 6,110rpm on a 10,000rpm grinder. The disk fragmented, blew apart, and a piece severed one of the larger arteries in his thigh. He died from blood loss. |
Re: Careful with those grinders, guys...
When your time comes to go, there's not much you can do about it.
However, it sounds like the 60 something guy went out prematurely due to his own ignorance using a setup like that. It's a wonder he made it as long as he did. |
Thanks for posting this, I just bought an 11,000 RPM Makita 5" grinder yesterday. Now I am thinking it is more dangerous than the slower model.
Bob. Miller Dynasty 200 DX Millermatic 211 Hypertherm PM 600 In Tool acquisition Mode |
Well, it does produce more energy, but as long as you leave the guard on and use disks designed for it, you should be okay...
Oh yeah.. WEAR PPE!! |
I bought a black and Decker 5" grinder on sale a couple of years ago for something like $25 I never looked at the RPM rating.
First time I used it I put a parting wheel on it and was cutting some tacks with it when the wheel came apart. I took it right out to the driveway and smashed it with a sledge and threw it in the trash. An 11,000 Rpm grinder around my shop is more dangerous than anything else.
Vantage 500's LN-25's, VI-400's, cobramatics, Powcon 300 inverters, XMT304's, 250 Ton pacific 12' press brake, 1/4" 10' Halco Atlantic shear,Koikie plasma table with esab plasmas. Lincoln idealarc tig 330A with bernard cooler. |
Like looking at a cutoff wheel in a die grinder. If you bind it, the edge looks like a snaggle tooth. The guards on the little high speed cutoff tools cover around half of the wheel dia. for good reason
What guard? |
Reminds me of my own accident from a few years back.
I had a 4" grinder and the special Arbor cutting disk was designed to fit a 4 1/2" grinder. The blade was deadly with teethe like a chain saw, so rather than so the silly thing and grind with the guard removed, I went down and bought the cheapest 4 1/2" grinder out there. I had all the safety gear in place, everything was done up nice and tight. Tested the machine and no probs. The piece I had to grind was overhead and as soon as I touched the grinder to the object in question the shaft of the grinder sheared the retaining pin and the whole head (including the deadly blade), and shaft of the grinder spun off my grinder and fell straight onto my forearm, slicing deep into my flesh and bone. I required 18 stitches and a lot of pain and time off work. The machine was faulty and the manufactures didn't give a toss about me !! I was tempted to take them to court and sue them, but in the end decided all the stress was not worth it. MOTTO: Buy quality tools and steer clear from the chinese crap ! |
AMEN
Gordie "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant." Lincoln Weld-Pak 100 Canox Sparkler AC/DC Lincoln SA-200 Harris Torch Miller Elite Helmet |
I can tell you from all the scars on my hands that grinders are dangerous. My hands have ground down to the bone in several places and yes the guards were in place and the grinding wheels were the one's rated for that machine. Each time the grinder had kicked back off the piece I working on and ground up against my hand (yep no gloves).
I certainly wear gloves now. Even gloves do not offer serious protection! But the gloves offer enough protection so that when the grinder kicks back off the piece you can react fast enough before it grinds through the gloves and not your hands.
Own farm:Harris oxyacy torch, lincoln 225, stick,Century 135GL mig, Hypertherm PowerMax 45 Plasma Cutter Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.& 2 Hypertherm HPR260's Plasma Cutter |
In 86 a co-worker was moonlighting, was using a 9" grinder, it kicked back, tangled in his coveralls and cut into his chest. He pulled it out, jammed his glove into the cut, got down out of the machine he was working on, and drove to the hospital, midnight. The nurse looked at him and made him wait for a couple hours. Finally she said "we can see your hand now" "Lady, it aint my hand" was all he got out. Next day he wakes up, 4 sawn off ribs, a cut and collapsed lung, multiple pints of blood and gash in the heart muscle.
Skinny tough guy, would've killed most folks. True story.
past work toys; lathes,mills, drills, saws, robots, lasers ironworker, shears, brake, press, grinders, tensile tester, torches, tigs, migs, sticks, platten table, positioner, plasmas , gleeble and spot. Retired June 30, 2009. |
I guess I am lucky all I did was cut open my hand to the bone. Certainly nothing as bad as that guy had.
He was probably self medicated to start with, it was the 80's!
Can't stress enough, DON'T do anything silly with angle grinders of any size,far too much speed and energy involved,A while ago a friend of mine wanted to cut a new doorway into a brick wall,9" grinder not quite big enough so he took off the guard and fitted a 12"disc, didn't keep it straight in the groove and the disc shattered,ripped thro' his gloves cutting into the back of 4 fingers,numerous small cuts to his face and the most serious injury to his right leg. large piece of disc just missed his shin bone but sliced into the muscle about 6" long and 11/2" deep.He came hopping to my house to take him to the hospital(massive cut but very little blood) The guards are there for a reason,so if you are evertempted to remove one, think about it for a long time, THEN DON'T DO IT !!!
Lincoln SP-170 Mig Lincoln V 205 Tig Lincoln PC-40 Plasma Butters FM 215 synergic Mig Kemppi 180 adaptive mig O/A welding-burning gear RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE GUIDANCE OF WISE MEN. |
Think of the "flywheel effect". There is a possibility of the disc breaking up from the speed alone when you fit a 12" disc on a grinder that was designed to bring a 9" disc up to speed.
I dont care if the guard is on or not, the biggest problem with grinders is that people get careless. Using the wrong rpm wheel, using to big of a wheel, putting pressure on a disk that isnt meant to handle pressure, letting wheels get in position to kickback or bind, not wearing eye protection, leather gloves, ect. This is what injures people, guards IMO are there to direct sparks. You need to know your tool, what your working on and what might go wrong with what your doing.
Have we all gone mad? |
I myself have been to the hosp 3 times for grinder accidents back in my younger stupid days. Lots of stiches and skin removel to clean the bad gouges in the flesh. So be carefull. The last one i ground thru my thumb knuckle while holding the part and i was in too big of hurry to clamp the piece. The ER Doc said what do you want me to do with that you took the skin off and can see the bone as he cut parts of my thumb away with scissors. It took a year for new skin to grow over the bone...Bob
Bob Wright Salem, Ohio Birthplace of the Silver & Deming Drill http://groups.yahoo.com/group/southbend10k/ http://groups.yahoo.com/group/sawking/ 1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun |
I took the end of my thumb off (not all of it! Just the skin and nail!) with a 19th century hand operated grinder. Considering I was in costume in front of the public was added fun. After a healthy dosing of alcohol and bandages, I was back at the forge.
I've read plenty of stories from the 18th and 19th centuries of large industrial grinders coming apart in use propelling themselves and their operators through roofs and walls. Scary stuff. Paul |
#19
I knew a guy cutting plastic with a 3 inch cut off wheel on an air grinder. The disk loaded up with plastic, got unbalanced, and came apart. One piece caught him in the neck. Bled like crazy but didn't get any main artery. Got very close to being a dead man.
Dynasty200DX w/coolmate1 Econotig (for sale) MM210 Lincoln AC225 tombstone Victor O/A Thermal Dynamics Cutmaster 81 Ingersoll-Rand 2475N7.5FP Evolution Rage3 AEAD-200 on extended loan from Dad |
#20
I appreciate all the posts. I have to say, one of the most dangerous things about grinding disks - and you see almost everyone doing it - is not wearing respiratory protection. Grinding disks are made of powdered quartz that is held together by a glue and reinforced by fiberglass mat. It's mostly the glass mat that scares me; like asbestosis and mesothelioma, the effects of exposures may not present themselves for 20 years or more. At the least we are talking silicosis, and at the worst, cancer. We balk at paying five bucks for a mask, yet think nothing of spending the same for a pack of smokes.
#21
I was using a wire cup wheel to clean a tank so I could read what was stamped on the tag. I was wearing a reflective safety vest and it got caught. Damn thing wire wheeled my gut, my side and ended up tangled in my armpit. Then it smoked. I had to yank the cord.
Now I only buy grinders with paddle switches. |
#22
i have had a cople of disks blow apart on my 4.5" grinder I never thaught anything about it but I could have been killed. now this has me thinking I need to whear ppe.
#23
Two years ago I was helping a friend work on his trailer. Getting ready to weld a broken fender mount back on I used his grinder that did not have a guard. As soon as I started to grinnd the area so I cold weld it the cheap HF disk he bought came apart and it was a trip to teh ER to get my hand stitched up. I had palstic surgery to fix teh damage to my nose. Glad I had put on my safety glasses first.
#24
Anyone recall grinders that were driven by flexible cable attached to stationary motor ? If you hung disc, the difference between motor speed and disc speed would cause the flexible (metal) cable to whip handheld portion (with disc) loose and fly about. There were no guards then.
Concerning paddle switches, did have cheap HF "buffer" (had 60 grit grinding pad on)with 2 speed paddle switch automatically come on while laying disc side down. It was on roof panel of truck, spun around, down on windshield and across hood before I could catch it.Another pucker time. (My application here was cutting off large volumes (thicknesses)of paint at low rpm without warping metal.)
Lincoln Crackerbox-stick Miller Roughneck Small OXY/ACT Portable Large OXY/ACT Portable Century 160 Amp Mig |
#25
My company has strict safety rules for grinding. PPE includes safety glasses, ear protection, AND full face shield. All grinders have safety switches, where you have to either press an extra button or flip an extra lever to operate it. Using a trigger lock is an automatic writeup, as is removing any guard. In tight corners, the boss recommends burning the paint off with your torch rather than removing any grinder guards. The weld in that corner will not be great, but it's much better than risking serious injury by messing with your grinder.
