Old 06-03-2009, 04:32 PM
FluxThis's Avatar
FluxThis FluxThis is offline
Stick Welding Aluminum?
I need to repair a trans bell housing and the only thing I can use right now is my stick welder.. I have yet to buy a tig, it's on the list but the economy won't let it happen yet..
I have a few electrodes and want to give it a shot. Any suggestions to help out complete this..
Thanks!
Jason
Miller 252
Miller 250
Miller Syncrowave 250
Esab Plasma Powercut 1250
HF Basic oxy/act torches
Old 06-03-2009, 04:36 PM
JC'sWelding's Avatar
JC'sWelding JC'sWelding is offline
Re: Stick Welding Aluminum?
look at the secind item in this video. It is a broken bell housing being repaired.
Old 06-03-2009, 04:48 PM
99trxrider 99trxrider is offline
im also interested in knowing how to stick weld aluminum. Dont mean to jack the thread, just thought we both could find something interesting out of it. How many aluminum rods are there?
Old 06-03-2009, 04:56 PM
aametalmaster's Avatar
aametalmaster aametalmaster is offline
I stick welded a few trans cases years ago and it was fine. Just make sure the alum is clean and grease free. Burn it with a torch and get it real clean. Use DC rev (elec +) for the rods. But the rods aren't cheap...Bob
Bob Wright
Salem, Ohio Birthplace of the Silver & Deming Drill
http://groups.yahoo.com/group/southbend10k/
http://groups.yahoo.com/group/sawking/
1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Old 06-03-2009, 07:06 PM
Atticabob Atticabob is offline
Yup same as Bob has said... Be ready to play catchup... they burn quite quickly
Old 06-03-2009, 07:36 PM
Coyote's Avatar
Coyote Coyote is offline
It will work. A few years ago, a friend of mine had a GM 400 tranny crack all the way across the top from one side of the pan to the other. It never quit running, but leaked badly. When in reverse that crack would open up over a quarter inch or so, and in forward it would close up. We took the doghouse out and closed it up and tacked it. A few minutes with a die grinder to vee out the crack, and a little heat from the torch to burn out the oil, we were ready to weld. I used those al rods, 1/8" and about 70 amps. He sold that truck a week later, and some guy drove it for a couple of years. It ended up on a local used car lot, and I looked to see if it still had that same tranny, and it did. I never figured it would hold up behind that 450HP 454.
.............................."Look Good Doing It"!!!!!!!!!!!!!!!
Old 06-03-2009, 10:42 PM
Is there just one kind of aluminum rod?
Old 06-04-2009, 01:08 AM
FluxThis's Avatar
Thanks for the help you guys!! I'm going to give it a try tomorrow.. I'll try to take some before and after pics and let you know how it turns out!
Jason
Miller 252
Miller 250
Old 06-04-2009, 02:16 AM
STwelder STwelder is offline
Where are you Castweld? Seems like castweld would be the perfect one to ask about this....
Miller Thunderbolt 225
Millermatic 130 XP
Lincoln HD 100
Forney C-5bt Arc welder
Plasma Cutter Gianteach Cut40A
Cent Machinery Bandsaw Horz/Vert
Cent Machinery 16Speed H.D. Drill Press
Chicago Electric 130amp tig/90 amp Arc
Old 06-04-2009, 06:54 AM
6010's Avatar
6010 6010 is offline
My suggestion for someone that wants to stick weld aluminum is to practice before jumping on something critical. Aluminum stick rods are a lot different than something like a 7018. Amps and travel speed become a lot more important. Maybe more important is a poor choice of words. It is better to say the tolerance of getting them just right is more narrow.
Old 06-04-2009, 09:48 AM
GerryR GerryR is online now
HTS-2000 is supposed to have three times the elongation strength of the Durafix. It might be worth taking a look at for this repair. http://www.aluminumrepair.com/faqs.asp
Old 06-04-2009, 12:11 PM
farmersamm's Avatar
It's not the new truck you just bought a while back is it?? Crap!!
Old 06-06-2009, 12:29 AM
FluxThis's Avatar
No Samm, it was for a customer.. It worked out pretty darn good, wans't the best looking thing I have ever done but $hit man it worked great!! Talking about moving kinda fast.. He also tossed out and older oil pan that he needed welded as well and boy I had that stick moving the rod FAST! That oil pan was pretty darn thin!
Samm, I sold that whit pick up the other week for $1200.00.. I get my F250 back after it was recovered from the theft and put her to work!! She has a new dually axle under it with some F350 leafs and a flatbed I picked up pretty cheap.. I'll get some pics up soon.. Been pretty darn busy down here south of the border and haven' had much time to spend on the computer..
And thanks again to eveyone for he help!
Jason
Miller 252
Miller 250
Old 06-06-2009, 01:16 AM
farmersamm's Avatar
Jason
Glad you got the truck back. That's pretty rare. I hope it was generally in one piece.
The buyer on the Chevy didn't get a bad deal. They were stout trucks.
