Old 06-03-2009, 05:00 PM
mn welder's Avatar
mn welder mn welder is offline
most of 1/4 in
i managed to score a nice chunk of plate steel 1/4 in and its about 4'x 4 ' with abot a 3 1/2 ft hole in centered and still has some usable steel the corners are about 23 in by 23in and i was thinking of how to turn it into a square by cutting it triangular and rotating it and manglueing it together should come ok whats the best way to extract it any ideas the measurements arent exact sorry
miller maxstar 150 hobart handler 210 w mig conversion hobart 250 arc force plasma cutter boston ind cutting torch miller performance auto darkening helmet milwalkee 14in chop saw 10,000 watt generator huge drill press and industrial band saw
Old 06-04-2009, 10:33 AM
Knotbored Knotbored is offline
Re: most of 1/4 in
Why not weld back in a 3 1/2" plug ?
Old 06-04-2009, 11:00 AM
Timberwolf's Avatar
Timberwolf Timberwolf is offline
Re: most of 1/4 in
thats a 3 1/2 foot hole. cut the piece into four at the thin spots 3,6,9 and 12 Oclock, rotate each piece 180 and weld what were the outside edges together.
Seems like a lot of trouble though to make the piece you need.
Lincoln PT185 TIG
Lincoln 175 MIG
Lincoln 240 amp AC Stick
Lind Needle Arc plasma welder
Plasma cutter, soon???
Old 06-04-2009, 11:14 AM
Ironmower Ironmower is offline
Re: most of 1/4 in
What are you using it for? It will be hard too keep flat.
Don't let that iron in your lungs, turn to lead in your @$$!!!!
Old 06-04-2009, 03:24 PM
dabbler dabbler is offline
Re: most of 1/4 in
Hi,
New guy here, post #3. I made a diagram to timberwolf's description to look at the leftover after the square is taken out. It looks like with some cutting could make 4 legs and most all the scrap could live as a low table
Old 06-04-2009, 03:33 PM
IamVince IamVince is offline
Re: most of 1/4 in
For a new guy that is very smart...welcome and I can see already you will be handy to have here.
Old 06-06-2009, 05:12 PM
mn welder's Avatar
Re: most of 1/4 in
that what i had in mind to make a table top for it thanks for theideas
Old 06-07-2009, 12:57 AM
ol' Stick Guy's Avatar
ol' Stick Guy ol' Stick Guy is offline
Re: most of 1/4 in
You could also take the 4 plate sections and make a material rack out of them
Old 06-07-2009, 01:10 PM
farmersamm's Avatar
Re: most of 1/4 in
Alternate welds on alternate sides, and backstep the welds. Ought to stay pretty flat.
Old 06-07-2009, 07:34 PM
tigmusky's Avatar
tigmusky tigmusky is offline
Re: most of 1/4 in
I like the new guy!
[IMG] code is Off
