Idealarc Tig 300/300
I have a Idealarc Tig 300/300 it's old and it recently quit working. It won't develop any power I think all I'm getting is the start arc. How do I test the coil to find out if thats bad. I have an other Welder that's the same but doesn't have the foot pedal. I just want to make sure I know whats wrong before I start changing parts. Thanks for any help.
Re: Idealarc Tig 300/300
The Operators and Parts Manual at Lincoln. Duanne can probably tell you how to check the coil. I'm sure there are others, too. Good luck.
http://content.lincolnelectric.com/p...r/im/IM192.pdf
Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money. -Cree Indian Proverb SA 200 Lincoln Victor Torches |
Welcome to the forum S8NSW8N.
![]() Contactor operating or not? Unit code #?
MM200 w/Spoolmatic 1 Syncrowave 180SD Bobcat 225G Plus - LP/NG MUTT Suitcase Wirefeeder WC-1S/Spoolmatic 1 HF-251D-1 PakMaster 100XL SA-200 Blackface Code# 8638 Star Jet 21-110 ![]() Two term limit - one in office, one in jail. |
Contacts are working. Code 8609-C
S8NSW8N,
Mechanical things to check are: 1) Work and electrode output stud connections - both outside and inside the machine. 2) Continuity of work and torch cables. 3) Current range selector switch for proper slider contact at each setting position and lead connections. 4) Polarity selector switch for proper slider contact at each setting position and lead connections. 5) Contactor contacts for burned condition that could result in no continuity across 'closed' contactor. By 'coil' I assume you mean the air core transformer? If so, I can't locate a schematic to identify the circuits you would need to probe to check for AC output voltage but with the machine opened up you can do so by locating the transformer secondary outputs that I would think would be connected to the range selector common terminal and one of the polarity selector switch 'AC' terminals. Is there a wiring schematic on the inside of the machine housing sheetmetal? If so can you get a good legible closeup photo of it? Duane
I will check those things tonight and get back to you in the morning. Thank You
I checked those things they looked fine. Hers what I did. I used an induction ampmeter clamped it on the hose leading to the torch and these are the readings I got. Low- 10-90amps I got 3
Med- 15-150 amps I got 5 High- 35-260 amps I got 15 Max- 60-375amps I got 54 The other tests you wanted me to do I haven't. I'm not all that thrilled about sticking my hands in the welder while it's running. |
