Old 07-25-2009, 09:23 PM
duaneb55's Avatar
duaneb55 duaneb55 is offline
Now I Have to Build Another Stand. . .
. . .for this Wiedemann 12 station manual rotary turret punch press.
Name:  Metal Punch 001.jpg
Was aquired with some other equipment at a machinery auction and it's been sitting outside at the shop ever since it showed up a couple months ago (at least). So Thursday I asked what we were going to do with it and was told we had no need for it because we have the hydraulic IronWorker. I responded "Do you want it to go away?" to which I was told "Take it.". Don't have to tell me twice so it came home in the back of 'burb last night.
Name:  Metal Punch 002.jpg
Name:  Metal Punch 003.jpg
Smallest hole capable is 5/32"(center) as the 1/8" punch is broken. Largest is 1" (right) and the rectangle (guess) is 1/4" wide x 1/2" long. 3/4" punch is missing although the die is there. Material in photo is .063 steel and punched thru with little effort.
Name:  Metal Punch 004.jpg
MM200 w/Spoolmatic 1
Syncrowave 180SD
Bobcat 225G Plus - LP/NG
MUTT Suitcase Wirefeeder
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
SA-200 Blackface Code# 8638
Star Jet 21-110
Old 07-25-2009, 09:28 PM
ZTFab's Avatar
ZTFab ZTFab is offline
Re: Now I Have to Build Another Stand. . .
NICE fine Duane!!
I've wanted one of those for years but have never found a good enough deal on one.
Hold my beer...watch this.
Old 07-25-2009, 09:32 PM
DSW DSW is offline
Moderator
Thats great. How much throat do you have? I would guess you can go in as far as the center pivot.
Old 07-25-2009, 09:43 PM
duaneb55's Avatar
Originally Posted by ZTFab View Post
NICE fine Duane!!
To date I haven't done much of any sheetmetal work ZT but with a small shear and brake that could change.
Just over 12" all the way to the back beam. Upper and lower turrets are timed with chain and jack shaft at the rear of the unit so it's a clear span between them. Upper and lower turret lock pins keep the punch and die properly aligned for use.
Syncrowave 180SD
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
Star Jet 21-110
Old 07-25-2009, 09:58 PM
MarkBall2's Avatar
MarkBall2 MarkBall2 is offline
Dang, as they say on another forum..........
YOU SUCK!!!
Great find & absolutely best price!!
Mark
Craftsman 12"x36" Lathe
Enco G-30B Mill
Hobart Handler 175
Century 230 Amp A/C stick welder
Chicago Electric 165A DC TIG
Oxy/Acetylene set
PapaLion's Gate Build
Old 07-25-2009, 10:19 PM
daddy's Avatar
daddy daddy is offline
You must be livin' right Duane. Very nice!
Old 07-25-2009, 10:36 PM
William McCormick Jr's Avatar
William McCormick Jr William McCormick Jr is offline
Attachment 36533
Attachment 36534
Attachment 36535
Attachment 36536
They still make all the punches for that. They have square punches too. We have two of them. So we can keep some square punches and double punches on a certain machine. Very nice machines.
Awesome find. I am not sure which one you have. One of the ones we have, you have to use a fork, when removing the punch. Especially from thin aluminum. The other one keeps the metal from bending better. But for really nice stuff it pays to make a little "V" fork and use it, when removing the punch from the work.
One has better visibility then the other, when sighting it in. But to be honest if you center punch your work, you can feel the punch line up with the center punch indent, without looking. Sometimes when you are looking you think you have it in the center punch indent. But you do not. Better to feel it line up.
One of the machines is mounted very high, so we can stand and hang on the handle. Ha-ha. The other is low so you can sit down at it.
Make an adjustable stand for yours. Just watch the guys coming into the shop. They might see you sitting down all comfortable, composed and enjoying your work, and give you a nick name like "sit down pee pee". Ha-ha.
If you keep it greased you can just flip the back handle and swing the turret, like a Dillan Aero Space gatling gun. The punches do not fall. Because of the grease.
When it dries up sometimes a punch will fall down a little bit. When you spin the turret something you probably should not do, you hear a crash. Ha-ha.
Sincerely,
William McCormick
Old 07-25-2009, 10:42 PM
With the square punches you can cut, rectangular holes.
Sincerely,
William McCormick
Old 07-26-2009, 12:17 AM
duaneb55's Avatar
Thanks for all the pointers William. Or is it 'Sit Down Pee Pee'.
Certainly sounds as if you've put your prints on those handles a few times. This one spins freely, unlocks easily and punches smooth. The spring loaded punch guides seem to keep the punches from falling when disengaged from the ram but then the unit needs a good cleaning too.
I haven't looked yet but I take it Wiedemann is still around? It would be nice to replace the broken 1/8" and missing 3/4" punch and maybe add a couple other shapes depending on what's available.
Adjustable stand? Now I'm going to have to think about that a bit as Brink and I were looking at it tonight trying to decide how tall to make it. Thanks for the suggestion.
Syncrowave 180SD
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
Star Jet 21-110
Old 07-26-2009, 12:32 AM
Sandy Sandy is offline
That's going to take a fairly wide base, heavy base or a bolted down base isn't it?
Old 07-26-2009, 12:42 AM
duaneb55's Avatar
I don't think it'll be too bad Sandy. It was quite stable just sitting there on the corner of the bench and I didn't have to worry about it pulling over.
Syncrowave 180SD
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
Star Jet 21-110
Old 07-26-2009, 12:57 AM
Not that much outward force on the handle then? Good deal.
Old 07-26-2009, 11:20 AM
Ken Dennis's Avatar
Ken Dennis Ken Dennis is offline
huh!
And you where saying about me?
And this was for free even!
Congrats Duane you lucky so and so!
#1. If you don't like what I wrote, or if it offends you, then don't read it!
#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Old 07-26-2009, 12:56 PM
castweld castweld is offline
Nice Duane
I get some punch and dies from Cleveland Tool and Die, they make several styles. If you need I can get more info.
Peter
Old 07-26-2009, 12:59 PM
duaneb55's Avatar
Thanks Peter. I'll keep your offer in mind if my search otherwise comes up empty.
Syncrowave 180SD
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
Star Jet 21-110
