Old 07-27-2009, 10:24 AM
Ben Bean's Avatar
Ben Bean Ben Bean is offline
Can Aluminum be Stick Welded?
Hello from Eagle Creek Orygun. I've done multiple searchs on the subject but have found no straight forward answers.
Can 1/4" or 3/16" aluminum be stick welded with a Miller Thunderbolt AC/DC welder? I have a chance to buy one for $150. Since being laid off I can't afford much.
Last time I did any stick welding was about 20 years ago and did some TIG a few years back so I'm not skilled at it but can lay a fairly good bead on steel.
Thanks for any & all answers,
Ben
Old 07-27-2009, 10:26 AM
lugweld's Avatar
lugweld lugweld is offline
Location: south GA where its hot in summer and cold in winter
Re: Can Aluminum be Stick Welded?
Yes,
But you need the aluminum electrodes. When you get them and weld, MOOVE it on down the seam. I haven't tried it but several people I know say its like shaking water off the end of the rod.
Welders:
Esab Migmaster 250
Penncraft 230 (oldy but goody)
HF Plasma 30 (Italian)
Lincoln Ranger 8
Smith Oxy/Acetylene/Propane
New to the family:
Lincoln SA200
Everlast Power Tig 250 EX
Everlast PowerUltra 205
Aka..The Everlast Pimp...
Old 07-27-2009, 11:18 AM
cmartman46's Avatar
cmartman46 cmartman46 is offline
My brother n law welded a jon boat with a Lincoln 225 AC/DC with the dc aluminum rods. It was'nt the prettiest weld I ever seen!
Old 07-27-2009, 11:26 AM
Ben Bean's Avatar
Originally Posted by lugweld View Post
Yes,
Lugweld, thanks for the reply. So the Thunderbolt, in your opinion, able to do the job?
thanks.......b
Old 07-27-2009, 11:57 AM
6010's Avatar
6010 6010 is offline
The more you use it, the better it looks. But I don't think you will ever get it as pretty as you could a tig weld. I have tried it and, although the weld didn't look what you would call pretty, it was strong. Weld hot and move fast - best advice I can give you.
Old 07-27-2009, 12:10 PM
Oldiron2 Oldiron2 is offline
Take a look at this site; click their "Products", then choose the 400 series to read what they say about aluminum welding.
[I only get through on Internet Explorer; my Mozilla is blocking it, and I can't look into why right now.]
Old 07-27-2009, 12:48 PM
BlindViper BlindViper is offline
I had to weld up a alum turbo pedestal on my truck. I bought the rods tried them out and they disappear quick. The travel speed is far greater then steel, I went to scratch start the rod and 3/4" of it disappeared. It has not leaked in over 2 years now, and man it was far from pretty
Old 07-27-2009, 12:51 PM
Ben Bean's Avatar
These are great & fast replies. Thanks guys. In some searches I found the 4043 1/8th inch rods to be the suggested rod of choice.
Oldiron, thanks for the link to Messer Welding. They have a 400 rod and also say that welding aluminum is not that hard. I guess peheating is the trick. They also mention a temp indicating crayon. I assume these are redily available at a local welding parts store???
..ben
Old 07-27-2009, 01:10 PM
kneedeep kneedeep is offline
yup
i have done it a few times and as said move fast and its a dirty weld great for strength but to make water tight I had to coat with epoxy. it worked for my needs. I also found washing with solvent before helped as the aluminium is pourus and holds oils and dirt.
Old 07-27-2009, 01:47 PM
hildstrom hildstrom is offline
Yes, check out this thread with some pics. Practice, practice, practice.
http://weldingweb.com/showthread.php?t=11505
Also, here is another link:
http://www.hildstrom.com/projects/st...num/index.html
Old 07-27-2009, 03:06 PM
Ben Bean's Avatar
With all this new information I'm gonna go buy that Miller Thunderbolt AC/DC welder & have some fun! Woo-Hoo
thanks guys......
ben
Old 07-27-2009, 06:22 PM
Brianstick Brianstick is offline
Yeah, you will need DC+ to stick weld aluminum.
Old 07-27-2009, 07:25 PM
Coyote's Avatar
Coyote Coyote is offline
Those Al rods will work. The ones I get are recommended on DC+, and I have not tried any thing else. I was suprised at how strong they are after I welded a 400 Chev transmission cas back togather while it was still in the truck. I really doubt the weld is anywhere close to a TIG weld in quality though. My LWS will sell them by the rod for about $1.05 a piece. The first time I used them the weld looked like a bears a** sewed up with barb wire, and the last time I used them it was not much better, but it did hold.
.............................."Look Good Doing It"!!!!!!!!!!!!!!!
Old 07-27-2009, 10:06 PM
wb4rt's Avatar
wb4rt wb4rt is offline
Aluminum or not, $150 for a Thunderbolt AC/DC is a great price around here. I would buy it at that price just to do steel if I needed a welder. I don't think you can go wrong.
Burt
_____________________
Millermatic 211 w/Spoolmate
Miller 375 Plasma Cutter - terrific machine
Miller Thunderbolt XL AC/DC - still learning
10FtDrillBit.com
