Old 07-28-2009, 12:23 AM
Boydie's Avatar
Boydie Boydie is offline
Basic Workshop Gotta-haves
To date I have been playing around trying to put into practice the basic (repeat basic) skills that I learned in a 12 week welding course (one night a week). Now I intend to set up for some basic fabrication projects. The first is a welding table. Next shall be a trailer. I have the welder and, thanks to advice from you guys, bought a DeWalt "chop saw" last weekend. The salesman tried to steer me towards some Chinese ones, but I told him that I couldn't possibly because DSW and crew would never talk to me again...
I see the major problem being getting things to be true. For example the first step in the table is to lay out the frame on the floor and weld it. I just know that is not as simple as it sounds. I have some magnetic squares, but they will only tell me how much I buggered it up after the event.
What do I need as basic workshop inventory to keep things square? Anything else that you think that I should have at hand? Apart from the basics - rods helmet, gloves etc. I have a grinder and a chipping hammer (which has had more use knocking oysters off rocks than chipping slag)
[SIGPIC][/SIGPIC]
Global warming = rising sea levels = more fishing spots
Bring it on...
Old 07-28-2009, 12:29 AM
Sandy Sandy is online now
Re: Basic Workshop Gotta-haves
You can never have too many clamps. Clamps of every size and shape. Then ya need good sqaures. Big sqaures and little sqaures.
Old 07-28-2009, 12:38 AM
Boydie's Avatar
so...you true it up using the squares and then clamp the workpiece onto the squares? I assume you would tack weld the four corners first and then weld one side of each corner at a time
I know this is basic stuff to you guys, but I really am trying to get a handle on this (and save money by ruining as little material as I possibly can).
[SIGPIC][/SIGPIC]
Bring it on...
Old 07-28-2009, 12:44 AM
DSW DSW is offline
Moderator
Tape measure, framing square, "speed" square (those alum ones that have a lip on one side) in large and small. I have a small machinist's square for doing funky angles and layout also.
As said clamps and more clamps. I have one true welders corner clamp. I use it when I just can't hold all the parts in place any other way to tack it up. I've also found ratchet straps to be useful to pull things back into square and hold them where I want. The only problem being nylon straps and weld spatter don't play well together, so you have to use common sense. A large bar clamp also works well to tweak things where you want them.
One note on working on a floor. Frequently concrete floors are neither flat nor level. Guy where I used to work, fabed a table on the shop floor. Checked the square and all as he put it together, or so he thought. The table had a terrible twist to it when finished. The floor had a drain and pitched in all directions to it. Because he laid all the parts out on the floor, while the corners were square, he ended up with a twist to the top.
Old 07-28-2009, 12:52 AM
DSW DSW is offline
Moderator
I seldom weld up compleatly with the welders clamp on. Usually I tack the outside edge, check and resquare and tack the inside edge and check and see if I need to break a weld loose and resquare.
Small parts if I can square them up and clamp them to the table, I'll tack both sides at once and then check and see if I have to fix it.
Weld the 2 sides 1st then outside and inside. again if it's important I keep checking as I go to see if I need to adjust or not.
Some of this is just practice. As you weld the joint will pull that way. in time you can get a feel for how much you need to set it out of square at the start so it's square when you are done. I can't say any better than that.
Old 07-28-2009, 12:54 AM
You're not going to clamp to your sqaures. You use those for layout and verification. I do have or make jigs, angles, plates and so-on that you do use for clamping pieces together and still leave tacking spots open. Lots of small clean scraps come in real handy. Especially nice pieces of angle of various dimensions.
Old 07-28-2009, 03:55 AM
weregeek weregeek is offline
Some sort of saw, and/or grinder is a must in my opinion. Ideally, you'd have a cutting torch and/or plasma cutter as well.
Old 07-28-2009, 04:32 PM
Ken Dennis's Avatar
Ken Dennis Ken Dennis is offline
A roof!
Nothing like starting a project and have it start raining on you and your work!
#1. If you don't like what I wrote, or if it offends you, then don't read it!
#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Old 07-28-2009, 04:46 PM
Jack Olsen's Avatar
Jack Olsen Jack Olsen is offline
So I'm not scrambling to find stuff when I need something welded, a separate batch of clamps and tools get stored behind my fold-up table.
Ready to work:
And hidden away:
I keep larger squares over my other workbench, since I also use them for woodworking.
Other basics worth mentioning:
Mig Pliers
Welding Hammer
Stainless Brushes in different sizes
Sandpaper in different grades
Cut-off saw
Sawzall
Files and punches
Soapstone and Sharpie markers
Safety glasses, ventilator, face shield, steel-toe boots, jacket, ear protection, exhaust fan
Lots of gloves
spare tips
Metal thickness gauge
Pam Spray or other anti-spatter stuff
Three or four angle grinders, grinding/cut-off/sanding-flap/steel-brush
Welding blankets
Stand-up welding curtains
Bench Grinder
A first-aid kit
Fire extinguishers and sand/water buckets
and
More clamps
Anvil
Vise
Old 07-29-2009, 12:28 AM
Boydie's Avatar
many thanks, fellas...Jack, that is sooo tidy. How do you convince the wife to keep her junk away?
[SIGPIC][/SIGPIC]
Bring it on...
Old 07-29-2009, 02:10 AM
oxy moron's Avatar
oxy moron oxy moron is offline
Originally Posted by Jack Olsen View Post
I bet you keep your bat-suit in a vacuum-sealed-tamper-glass-enclosed case and every time you open it, it makes that pssss sound as it repressurize
that's entirely wayyy too neat. If i did that, it would last 10 seconds.
my vote goes to horizontal bandsaw that could double as a regular vertical bandsaw. its just so versatile, cheap, not very noisy and easy to use once you get it properly lubed and dialed in.
Old 07-29-2009, 02:22 AM
Jack Olsen's Avatar
Same garage, this week:
I'm making a fence for my front yard.
It'll be neat and clean again, but not until the fence is done.
Old 07-29-2009, 07:43 AM
weldbead weldbead is offline
Originally Posted by DSW View Post
I seldom weld up compleatly with the welders clamp on. Usually I tack the outside edge, check and resquare,,,
boydie..this is what you need when its time to adjust...2#,3# and a couple of 8s...
Old 07-31-2009, 02:30 PM
piniongear piniongear is offline
As far as making a table and keeping the frame square I would get two of these clamps if I were you. Four would be better, but two will do.......
These hold things square and level and really make framing work a bit of a breeze.
You can also use frame members of different thickness and/or size to make a frame...... pg
Dynasty 200 DX_set up to run on 3 phase
Coolmate 3
MM 251 w/ Spoolmatic 30A
HTP 625 Micro Cut Plasma Cutter
Victor O/A Rig
Bridgeport Mill_3 phase
10 inch South Bend Lathe_3 phase
Quincy 325 2 Stg. Air Compressor_3 phase
Old 07-31-2009, 04:26 PM
gofaster gofaster is offline
what band of clamps are those?
Old 07-31-2009, 04:29 PM
Ken Dennis's Avatar
In utter words, what everyone is trying to say is.
Make the steel work for you and not the utter way around, even if you have to beat it into submission!
Old 07-31-2009, 04:31 PM
Mine are a Wilton brand. There are other brands made also. These cost about $65 each. I believe HF carries a similar clamp. I bought mine at a WS, but you can get them online as well. Heavy though, so thats why I got mine local....... pg
Coolmate 3
Victor O/A Rig
Old 07-31-2009, 04:52 PM
7A749's Avatar
7A749 7A749 is online now
Moderator
I personally have always used machinist's squares & clamped to my table.
I have them from 6" to 24" I found the corner clamps to be a little restrictive for me.
Everybody does it different tho.
Specializing In The Sale & Restoration Of
Miller 50 Series Wire Feeders
Miller Maxtron 450 Inverters
Old 07-31-2009, 05:08 PM
thanks
Old 07-31-2009, 05:22 PM
Broccoli1's Avatar
Broccoli1 Broccoli1 is online now
http://www.lincolnelectric.com/knowl...ldingtable.asp
demonstrates how to use Clamps and some angle iron to keep things together/sqaure for weldin'
http://www.millerwelds.com/interests...welding-table/
Good table with plans.
MM211
TA 185
Miller 125c Plasma 120v
O/A set
Old 07-31-2009, 06:12 PM
Re: Basic Workshop Gotta-haves (Gofaster.....)
thanks
After the discussion on the corner clamps I decided I would get another pair to finish out a set of 4.
The clamps are Wilton AC-325 Welders Angle Clamps.
I cannot find them anywhere. Apparently Jet has bought out Wilton in the clamp department anyway. I found one place that had the Jets listed but when I called they had none in stock. So I guess the Wiltons are no longer available......... pg
Coolmate 3
Victor O/A Rig
Old 07-31-2009, 06:32 PM
Broccoli1's Avatar
Northern Tool caries the Strong Hand brand
http://www.northerntool.com/webapp/w...2944_200342944
Bessy makes one also but are quite a bit more $$
MM211
TA 185
O/A set
Old 07-31-2009, 06:43 PM
Yes they do and the Strong Hand brand is a good one. I just have to make sure the SH dimensions are the same as the two Wiltons I have now.
My plan is to ride over to my local Northern store and compare those with a Wiltion. Thanks....... pg
Coolmate 3
Victor O/A Rig
Old 07-31-2009, 07:51 PM
paweldor paweldor is offline
Here's a link to the Wilton web site. You can locate a dealer near you, or an online dealer
http://www.wiltontool.com/
Old 07-31-2009, 08:22 PM
Thanks for the link Paweldor, but that is what I tried. Only two vendors were listed. One sells them for $145 a copy and the other guy sells them for $89. So I called him and that is where I found the clamps to be (1) Jet Brand and (2) they had none in stock...... pg.
Coolmate 3
Victor O/A Rig
