Old 08-10-2009, 10:29 PM
redcoupe redcoupe is offline
what feeder to run with my Trailblazer 250G
Looking to buy a feeder to run some 0.45 flux on a repair job. I used to run a spoolgun and it did alright but sold it and need something that can lay some wire down. Is my machine big enough to run .45 flux and if so what feeder to get? Its a 95 model Trailblazer 250G with a 20 horse onan. I have been looking at the SP32 miller or the 12VS Suitcase. But wouldn't be afraid of running an LN-25. Any help would be great , Thanks.
AWS CWI/CWE
ASNT NDT Level 2 PT/MT
AWS Certified Welder(aerospace)
Old 08-10-2009, 10:39 PM
adam21584's Avatar
adam21584 adam21584 is offline
Re: what feeder to run with my Trailblazer 250G
I have a s32 p, and have had a 12 vs get a ln25
Old 08-10-2009, 10:42 PM
so my machine willl have plenty of punch to run the feeders?
AWS CWI/CWE
Old 08-10-2009, 11:03 PM
DDA52's Avatar
DDA52 DDA52 is offline
More than enough. I used to run .045FC and 1/16 FC with a Bobcat 225G. You are definitely good.
QamuIs Heg qaq law' lorvIs yInqaq puS
Old 08-11-2009, 09:46 PM
good to know ...thanks guys
AWS CWI/CWE
Old 08-11-2009, 10:06 PM
7A749's Avatar
7A749 7A749 is offline
Moderator
Truthfully, you can run just about any Miller feeder off it you wanted to, providing you have the correct connection.
Not the most practical, but I have seen people run 50, 60 series, even 30 series feeders off engine drives. A suitcase style is the best for portability, but if an inexpensive shop feeder was available, it could be used no problem. The 14 pin puts out both 115 & 24 volts AC.
Just something to keep in mind if one was available for cheap.
Best to keep the leads under 75' on remotely controlled feeders. Voltage sensing units can go quite a ways farther out tho.
Specializing In The Sale & Restoration Of
Miller 50 Series Wire Feeders
Miller Maxtron 450 Inverters
Old 08-11-2009, 10:50 PM
Coyote's Avatar
Coyote Coyote is offline
I run .045 dual shield e71t some on my TB302. It runs it real well I have a 12RC feeder.
.............................."Look Good Doing It"!!!!!!!!!!!!!!!
