Old 08-15-2009, 04:33 PM
eebasist eebasist is offline
Older Thermal Dynamics Pak 5XR plasma
I have the opportunity to buy an older transformer based Thermal Dynamics plasma cutter. Model is Pak 5XR (mid 90s), and runs off of 240V single phase, Its rated to cut 1/2" and consumes 42A of current from the house.
I can pick it up for 300$. Is it worth it....Its about 200 pounds? I need to cut some 3/8 steel in the near future and a plasma would work great.
What do you all think?
Old 08-17-2009, 08:36 AM
jimcolt jimcolt is offline
Re: Older Thermal Dynamics Pak 5XR plasma
It is probably worth it for the price. The 5xr is a high frequency start, 55 Amp output.....actually has 3 ranges (20, 35 and 55 amps) if I remember correctly. It does not compare performance wise (thickness and speed) to todays 40 and 45 amp plasmas.....and will use a lot more consumables.....but if it works the price is right.
Jim colt
