There are many kinds of protractors to find angles, what is the best? i saw a magnet one but i could move it 1/2" and not get a change in reading. i need something very accurate. and easy to mark that angle. my table saw cuts angles but it seems to have some slop too and i need a tight fit
Exotic Car Fabrications Lincoln 180HD 75/25 |
Re: Whats the best?
There a quite a few engineering type protractors available. Fairly precise in measure.
I have i couple. One is easier to use than the other. I think it is made by a company called General. Will have a look and post back. Will post pics when i install software to resize them. |
Re: Whats the best?
thanks, ive looked at box stores and seen only the compass like one which is easy to use but not accurate. i have a $1 walmart one for kids school thats accurate but not easy to use. ive seen a kind on google that is v shaped, one lays horizontal on 0 axis and the other finds the angle. it has a gauge looks very accurate and when you hit your angle you could just take a marker and swipe it down the upper ruler and your done. wish i could find one like that.
Re: Whats the best?
I found pics on their web site
http://www.generaltools.com/Departme...otractors.aspx It is also an online store so you can puchase direct I have the combo set which does angles, finds center to circle and square, but the one i pick up the most is the square head steel protractor which has 2 deg. increments. . Last edited by LarryO; 08-28-2009 at 07:44 AM. |
Re: Whats the best?
I've always used a carpenter's sliding T-bevel. Get out the compass if the angle needs to be divided.
Mike
Ol' Stonebreaker "Experience is the name everyone gives to their mistakes" Miller 175 mig Miller thunderbolt ac/dc stick Victor O/A setup Makita chop saw |
Re: Whats the best?
This is great for setting saw, but is limited to angles in the vertical orientation http://www.google.com/products?q=Wix...auge&scoring=p
fred
-- fred Lincoln 180C MIG |
Re: Whats the best?
Re: Whats the best?
Go to www.tricktools.com
I have the oil filled angle level and the wixey digital unit. Both are very accurate. Last edited by TSOR; 08-28-2009 at 11:50 AM. |
Re: Whats the best?
the square head is what i think i want, i dont understand how the combination works any different
Re: Whats the best?
I have a General square head protractor that I use on my metal lathe and it works great. My compound only goes down to 30 degrees, so I use the protractor for angles under 30 and they come out accurate.
Re: Whats the best?
Re: Whats the best?
I have this, http://www.starrett.com/download/369_cat_70_p90_91.pdf
And this http://www.starrett.com/download/286_p309_315s.pdf on a 24" square They are both great tools.
Re: Whats the best?
ohhhhhh, thats what i was looking for!
Re: Whats the best?
I use a protractor and a couple straight edges with a pivot bolt and a slotted bolt.. or bolt it to the square or table it's very universal, homemade and very accurate if assembled properly.... works the best on the bench for repetitive cuts.... my 2 cents
Lincoln 225 Tombstone, Miller Big 20, Hobart 180,150' Argon, A/D hobart hood 22 Ton Log splitter, 79 F350 dump eats 4.75 TONS and still turns ![]() cutters,grinders, And a Hypertherm POWERMAX 30
Re: Whats the best?
America Needs AMERICA'S Oil!!! "Global warming is the greatest scam in history ...There is no run away climate change. The impact of humans on climate is not catastrophic. Our planet is not in peril."--John Coleman, Founder of The Weather Channel |
Re: Whats the best?
This is my favorite. You have to watch not to drop it. Or the indicator gets a bit smashed up. I abuse this device though and it still works, over a year for me. That is good for my treatment of tools.
It only has two degree increments. But if you can see that good, you can just split the hairs and get any increment you want. http://www.rockwelder.com/tools/Starretangle1.jpg http://www.rockwelder.com/tools/Starretangle2.jpg Sincerely, William McCormick |
Re: Whats the best?
I have a "line of chords rule" to do some larger plate work angles, they are very compact and tough.
https://www.alltools.com.au/shop/ind..._Cords_24_Inch Mick |
Re: Whats the best?
I would not got that www.alltools,they are EXTREMELY HIGH with their prices.
#19
Re: Whats the best?
Miracle Point http://www.penntoolco.com/catalog/pr...ategoryID=4510
I.B.E.W Electrician and Damn Proud of It !!!! . ![]() Virtus Junxit Mors Non Separabit ![]() http://www.shrinershospitalsforchildren.org/
