Old 09-26-2005, 11:27 AM
kevin oneill kevin oneill is offline
anybody have this happen ?
ust wondering if this ever happened to anyone else. i was welding with my lincoln electric weld pak 100 and out of nowhere the wire feed stopped. i thought the spool was empty and turned it off and checked. the spool was still half full so i turned it back on and it's worked fine since,.\
am i hallucinating, or does this sometimes happen with wire feed machines or should i dust off the receipt. i bought the machine in july and have been very happy with it.
thanks
kev
Old 09-28-2005, 07:18 PM
chipmaster chipmaster is offline
kev
check the connections at the torch and in the unit it self
regards
chipmaster
Ranger 250
LN 25
2 ESAB suitcase feeders
SP135
LINCOLN Square Wave TIG 255
Kondia vert mill
ProtoTrak CNC vertical mill
13" South Bend Lathe
17" South Bend Lathe
caterpillar d-4, 15, 22 and a 20
Old 09-28-2005, 07:31 PM
Jpt921 Jpt921 is offline
You hit the duty cycle happened to me to yeserday!
Old 09-28-2005, 11:47 PM
Pentawelder Pentawelder is offline
Yup, duty cycle's only 20%, but dont turn it off, the fan will cool it off faster.
(If it has a fan)
Old 12-04-2005, 09:30 PM
MetalSculptor MetalSculptor is offline
Guest
If your input 110VAC drops to 90VAC you duty cycle will drop to 12%, Plus a 25 extension cord will drop the duty cycle to about 10%
The Lincolns are know for high power consumption
Old 12-09-2005, 01:08 AM
ctardi ctardi is offline
Geez, if you are going to be a smart ***, at least get a keyboard with a " ' " key.
Owner of Welding Wiki,
The free wiki based resource for weldor's around the world.
http://www.weldingwiki.com
We have cookies!
HTML code is On
