Old 09-14-2009, 10:52 AM
PeterB26 PeterB26 is offline
HF Auto Darken helmet says "Not for O-A" ....Whatsup?
I mail-ordered an inexpensive Auto Darken helmet from Harbor Freight. I was surprised when I pulled it out of the box that is has an explicit warning not to use it for Oxy Acetylene welding or cutting.
Since the A-D lense is supposed to block all the harmful IR and UV at all times, even when clear, and the shades are selectable to be dark enough to use with MIG or TIG, which are darker than what one uses for O-A, I was kind of surprised by that.
Does anyone know why? Is this a limitation common to many A-D helmets? Are there some out there suitable to use with O-A without spending a fortune? I am a very occasional user so I don't need the sort of helmet that makes your day go easier after six or seven hours, just something that I can use with saftey-reader glasses underneath once every couple of months for a few minutes at a time.
BTW I would have appreciated it if HF had included that limitation not to use it with O-A processes in their product description.... or is that something which is "common knowledge" about which I was simpy ignorant?
Thanks,
PeterB26
Old 09-14-2009, 11:03 AM
lugweld's Avatar
lugweld lugweld is offline
Location: south GA where its hot in summer and cold in winter
Re: HF Auto Darken helmet says "Not for O-A" ....Whatsup?
You can call
tech support at HF and they wil be able to give you a reason...probably. They are very good as far as those kind of things. My guess is that the standad shade made not be light enough for OA welding or the sensitivity may not be dull enough to stop the unit from switching to dark shade so that you won't be able to see.
Welders:
Esab Migmaster 250
Penncraft 230 (oldy but goody)
HF Plasma 30 (Italian)
Lincoln Ranger 8
Smith Oxy/Acetylene/Propane
New to the family:
Lincoln SA200
Everlast Power Tig 250 EX
Everlast PowerUltra 205
Aka..The Everlast Pimp...
Old 09-14-2009, 01:56 PM
Jack Olsen's Avatar
Jack Olsen Jack Olsen is online now
O-A typically calls for #5 shade lens -- you can use goggles with Oxy, since there's no electrical arc that's going to burn your face with UV. My guess would be the HF mask can't go that light -- it's probably capable of #9-#13. MIG or Arc welding will generally use a #9 through #11 shade.
Jack Olsen
The Garage(And its slideshow)
The Car(And its slideshow)
Old 09-14-2009, 02:20 PM
PilotDan's Avatar
PilotDan PilotDan is offline
The helmet probably isn't sensitive enough to auto darken when using O/A. The inactive shade is probably 3, and it probably doesn't have a low enough shade for O/A anyways. Just use a pair of goggles with O/A, you don't need autodarkening. You can see what you are doing just fine with the goggles on when using O/A... My speedglas works fine for O/A (has a shade 5, and has really good sensitivity control), but I don't use it for that very often.
Esab TradeMaster Torch
Smith AW1A Airline Torch
Lincoln AC/DC 225/125
Millermatic 185
Thermal Arc 190 GTS
SpeedGlas 9100v
And a whole lot of fun when the sparks start flying!!
Old 10-03-2009, 11:52 AM
weldbead weldbead is offline
it will probably flash on you when tigging too. i suggest that ad helmets should be sold in pairs so the owner can crap in one and cover it over with the other..
Old 10-25-2009, 12:56 PM
JeffB JeffB is offline
For using an O/A torch, it may just be easier to pick up a pair of oversize shade 5(or so) cutting glasses that are made to fit over prescription glasses. My LWS has them for around $10.
Old 10-25-2009, 02:04 PM
Sandy Sandy is offline
Nothing to do with the safety issue, there's no "off" to those. The constant flashing back and forth will drive you nuts anyway.
