Old 09-16-2009, 11:27 AM
tpierce tpierce is offline
Which plasma?
I need to cut from 16 ga. up to 3/16" plate, with some short cuts in 1/4" angle and bar. I'm considering the Miller 375 extreme, and the Hypertherm Powermax 30. Does anyone have any recommendations?
Thanks.
Old 09-16-2009, 03:52 PM
LarryO's Avatar
LarryO LarryO is offline
Re: Which plasma?
DO a search.
This is a question that has been asked many times. Almost once a week.
There is a lot of info on this board that will answer your question without ask, all people need to do is use the search function.
Old 09-16-2009, 07:33 PM
Rojodiablo's Avatar
Rojodiablo Rojodiablo is offline
Re: Which plasma?
Thanks.
If you are keeping it small, and want a small machine, I have a Lincoln Pro-cut 25. It will cut up to 3/8" steel. It does cut aluminum to 1/8" well. It flies through 1/8-3/16" steel. I like it because I can use it on 110 or 220V. If you want to cut bigger stuff, step up a size to a Hypertherm PM 30. I sometimes wish it was stronger for thicker aluminum; but I am always happy when I have to cut stuff and I can just run off of household current. Plug in and plasmacate.
Old 09-16-2009, 07:54 PM
piniongear piniongear is offline
Re: Which plasma?
Thanks.
You may want to contact HTP Welding.
http://www.htpweld.com/
I have owned an HTP 625 Mircrocut 625 for years now. This is one size larger than you need but HTP will have a 375 machine and it should be an inverter too. I believe you may find the price is a bit better too.......... pg
Dynasty 200 DX_set up to run on 3 phase
Coolmate 3
MM 251 w/ Spoolmatic 30A
HTP 625 Micro Cut Plasma Cutter
Victor O/A Rig
Bridgeport Mill_3 phase
10 inch South Bend Lathe_3 phase
Quincy 325 2 Stg. Air Compressor_3 phase
Old 09-16-2009, 08:34 PM
DesertRider33's Avatar
Re: Which plasma?
Powermax 30 would be my choice. I'm very happy with my Powermax 380.
MM350P/Python/Q300
MM175/Q300
DialarcHF
HTP MIG200
PowCon300SM
Hypertherm380
ThermalArc185
Purox oa
F350CrewCab4x4
LoadNGo utilitybed
Bobcat250
XMT304/Optima/Spoolmatic
Suitcase12RC/Q300
Suitcase8RC/Q400
Passport/Q300
Smith op
Old 09-16-2009, 09:22 PM
smawgmaw's Avatar
smawgmaw smawgmaw is offline
Re: Which plasma?
I tend to prefer the Lincoln brand overall when it comes to the big 3. But in this instance, If given the choice between the three (Lincoln, Miller, Hypertherm), I definitely would choose the Hypertherm Powermax 30. Reasons: Power (capability), dual voltage (110-220), and price. Although, the Lincoln and Miller are probably good machines, I feel they are overpriced compared to comparable units found from other manufacturers.
A few of my toys !
SparkyLinux
LinuxMint
Crunchbang
Miller Roughneck 2E
Lincoln WeldPak 100
HTP MTS 160
Chicago Electric 80amp Inverter
Victor O/A
Old 09-17-2009, 12:55 PM
tikiboi13's Avatar
tikiboi13 tikiboi13 is offline
Re: Which plasma?
Thanks to everyone on here my garage is becoming a think of beauty. I went with the hypertherm myself. I liked that they are made here in the U.S.A. works like a champ. No regrets
LIVE BETTER WORK UNION! BUY AMERICAN!
Old 09-17-2009, 01:55 PM
specter's Avatar
specter specter is offline
Re: Which plasma?
Good choice I think you'll be more than happy with its performance and the life of the consumables.
Old 09-17-2009, 02:04 PM
Tony D Tony D is offline
Re: Which plasma?
My powermax 30 is getting a good workout here [IMG][/IMG]This was posted on another aera... but that is 1/2 smacked the slag off and was clea.....and it pierced and gouged it WOW and it's not rated for gouging..... but it digs good and the tips last .......and it goes down to 15 amps so it don't burn the paint on the roofing tin and does finer cuts on thinner stuff so that's my choice hands down it''s THE BEST as they are the leader in innovation woo hoo
Lincoln 225 Tombstone,
Miller Big 20,
Hobart 180,150' Argon,
A/D hobart hood
22 Ton Log splitter,
79 F350 dump eats 4.75 TONS and still turns
cutters,grinders,
And a Hypertherm POWERMAX 30
Old 09-17-2009, 02:07 PM
Re: Which plasma?
your posts were not there a min ago... wow I didn't see your choice and posted that how dummy
Well congrats to you and your powermax just gotta keep from cutting everything up LOL
Miller Big 20,
A/D hobart hood
cutters,grinders,
Old 09-17-2009, 03:53 PM
MX727 MX727 is offline
Re: Which plasma?
Posted this in the other thread too for anyone else that is looking:
Current Airgas sale flyer:
Hypertherm Powermax 30 -------------$1139
Miller Spectrum 375 Extreme ---------$1348
Thermal Dynamics Cutmaster 39 ----$1089
Edit/Delete Message
Old 09-18-2009, 06:19 PM
smawgmaw's Avatar
Re: Which plasma?
Weldersource.com ebay store---------Hypertherm Powermax 30-------$1009.
Weldersource.com ebay store---------Thermal Dynamics Cutmaster 39-------$999
Weldersource.com ebay store----------Lincoln ProCut 25------$1360
Weldersource.com ebay store----------Miler 375 Xtreme--------$1245
A few of my toys !
SparkyLinux
LinuxMint
Crunchbang
Miller Roughneck 2E
Lincoln WeldPak 100
HTP MTS 160
Victor O/A
Old 10-06-2009, 12:24 AM
Combat Jump's Avatar
Combat Jump Combat Jump is offline
Re: Which plasma?
I just pulled the trigger on a Miller 375 Extreme from Indiana Oxygen. While I have 230V available, I like that it has the ability to use both 120V and 230V. This feature matches my Miller 211 (which I also bought from Indiana Oxygen).
So after using Red for 16 years, I have completely converted to Blue. I also got a good price, free shipping and no tax.
Miller 211 MIG
Miller 375 Extreme Plasma Cutter
Miller Maxstar 150 STL TIG
Oxy-Acetylene torch
Old 10-06-2009, 04:27 PM
jamlit's Avatar
jamlit jamlit is offline
Re: Which plasma?
I have the TD cutmaster 38 and think it is one of the best plama's going. The cutmaster 39 is even better. With prices like these I think its a pretty clear choice.
Miller DVI2
Lincoln Precision Tig 225
Thermodynamics Cutmaster 38
Everything else needed.
Old 10-06-2009, 09:20 PM
smawgmaw's Avatar
Re: Which plasma?
The TD Cutmaster 39 is also dual voltage (120/240) and about $246 cheaper including shipping than the Miller. Your money, your choice. Hope the blue paint was worth the extra green.
A few of my toys !
SparkyLinux
LinuxMint
Crunchbang
Miller Roughneck 2E
Lincoln WeldPak 100
HTP MTS 160
Victor O/A
Old 10-07-2009, 08:39 AM
Re: Which plasma?
Guys, I finally pulled the trigger on the Powermax 30. I was able to pick it up locally for $1025.00. They threw in shade 5 glasses, leather gloves, and a good air filter. I plan to fire it up over the weekend. Thanks for the input and comments.
Old 10-07-2009, 03:54 PM
jamlit's Avatar
Re: Which plasma?
Congrats.
You can't go wrong with either a Hyperthem or thermodynamics plasma's. Both are the best one going.
Good luck with your purchase
Miller DVI2
Old 10-07-2009, 05:50 PM
smawgmaw's Avatar
Re: Which plasma?
Ditto! Either one of the above machines, TD or Hypertherm, have good quality for the price. To me Lincoln and Miller are pricing themselves out of the market when compared to similiar capacity machines.
A few of my toys !
SparkyLinux
LinuxMint
Crunchbang
Miller Roughneck 2E
Lincoln WeldPak 100
HTP MTS 160
Victor O/A
Old 10-08-2009, 04:44 AM
Billy Billy is offline
Re: Which plasma?
No not really, if you want quality you have to pay for it.
Old 10-08-2009, 09:17 AM
Re: Which plasma?
I don't know about millers quality as I dont own one.....but Hypertherm did invent plasma cutting and are the leader in innovation ..so quality hmmmm hypertherm makes miller torches or did at least till the patents run out and can be copied now legally soooo that's my thoughts....
Miller Big 20,
A/D hobart hood
cutters,grinders,
Old 10-08-2009, 07:54 PM
smawgmaw's Avatar
Re: Which plasma?
Compare the specs of the above machines. Then compare the prices of each. All are quality machines. But two specifically (TD and Hypertherm) seem to outshine the other two when comparing specs and dollars. I favor Lincoln when it comes to welding products, but I am no fool. The Lincoln unit mentioned above would be the last unit I would consider purchasing out of the group when it comes to value. The Miller unit would follow close on its heels. Like is often stated: "A fool and his/her money are soon parted". I still have mine and plan on keeping it. But, Billy, feel free to waste yours if you deem it neccessary.
A few of my toys !
SparkyLinux
LinuxMint
Crunchbang
Miller Roughneck 2E
Lincoln WeldPak 100
HTP MTS 160
Victor O/A
Old 10-08-2009, 09:58 PM
sidthss's Avatar
sidthss sidthss is offline
Re: Which plasma?
Ya can sit here and tell everybody not to buy the millers, but it seems like quite a few people still do, I purchased mine when miller had that special deal going this summer and it was between the hypertherm and miller, and because the 375 extreme had a case, air purifier, and the cutting guide, it ended up edging the hypertherm on price. Not that i have anything against hypertherm, but i have a hard time passing up a good deal on a good machine. Also smawgmaw, let me know when people stop buying lincolns and millers!
Miller Dynasty 300dx
Speedglas 9002X
Miller Spectrum 375 Xtreme
Lincoln PowerMig 255xt
Lincoln PowerMig 140c
Milwuakee Portaband
Old 10-09-2009, 06:26 PM
smawgmaw's Avatar
Re: Which plasma?
Not telling anyone to not buy Lincoln and Millers. They can buy whatever they want and I can buy what I want. Their money and my money. Given the prices in the previous posts, I know what I would buy and not buy. One would not be Lincoln and the other would not be Miller. I am not talking quality here, I am talking value as to money output vs. specs. As to which I would buy, it would probably be the Hypertherm due to its physical size and portability even though it is just a bit more than the TD Cutmaster 39. If you read a little futher down in my posts at my signiture, you will see that I do own Lincoln products. I do own Miller products also. I apologize for not including the Miller Spoolmate 3035 and SGA100C control box I also own (not enough room due to size limitation). Please forgive me. And as for as letting you know when people stop buying Lincon or Millers, I dont have time for petty BS! Maybe you can waste your time doing so and let us all know when that happens.
A few of my toys !
SparkyLinux
LinuxMint
Crunchbang
Miller Roughneck 2E
Lincoln WeldPak 100
HTP MTS 160
Victor O/A
Old 10-10-2009, 12:09 AM
sidthss's Avatar
Re: Which plasma?
Obviously ya didnt understand it was a rhetorical question, because I dont ever see people not buying lincolns or millers, also I really dont care what you own, like you say, its my money....., but you also didnt understand when I told you that I paid less for my miller than for the PowerMax 30, set up the way I would like it. I never have considered any of the chinese junk and never will, never looked at any of the TD models, they may be good machines, but just not for me. To anyone else reading this thread, miller makes a good plasma cutter as well as hypertherm and others, but it all depends on what you want to spend, I would go with the miller or the hypertherm if I ever had to do it again.
Speedglas 9002X
Milwuakee Portaband
Old 10-10-2009, 12:35 AM
smawgmaw's Avatar
Re: Which plasma?
You dont understand what you read. I did understand what you said about your purchase of the Miller Spectrum, good buy, your happy, thats all that matters. What you fail to understand is the original poster was considering two different units at todays current prices, not what someone else bought on sale. No where on this thread was it stated that Miller or Lincoln was not a good machine. They are both good machines, just not what I would consider better value to me when compared to the other two choices mentioned. And I dont believe anyone ever made a mention of Chinese machines either. Not until you just did.
A few of my toys !
SparkyLinux
LinuxMint
Crunchbang
Miller Roughneck 2E
Lincoln WeldPak 100
HTP MTS 160
Victor O/A
HTML code is On
