Rosette weld and patch exercise
'm practicing with an Ox/Ac rig; Using mild steel (.035).
Got a little cocky and decided to try a patch on tubing. With a rosette weld as well as along the edges. Well, I chased that hole all over the patch! burning it and filling and burning and filling! The patch obviously getting hotter than the base metal. Tried different angles, nothing successful. Any suggestions are appreciated. Had the same problem along the first edge. Then I wised up and clamped a 'chill bar' on the patch. Worked like a charm; however, I can't see an experienced welder stopping for each side and reclamping the 'bar. I'm using 2psi of both gases, and a blowpipe tip with an opening appropriate for metals .037 thick. Suggestions? - Mike |
appropriate for metals .037 thick<<< Does this mean you left an opening in the tubing or were the ends of the tube closed off while you were welding the patch and hole? In other words, were you welding on an otherwise closed pipe?
Smithboy... if it ain't broke, you ain't tryin'. Last edited by smithboy; 10-11-2005 at 09:40 AM. |
