Getting back into stick (pics)
Well I just got back into stick welding, but I was never very good at it to begin with. I did some practice today doing some beads on any piece of scrap I could find, then started sticking metal together. I did some 3-pass 1/2" fillets out of an old overload spring I had laying around the yard. Try not to make fun of my very hasty gasaxe cuts, I just cut them as fast as I could push the torch. I did notice I had alot of undercut on the vertical plate, but that may have been the angle I was holding the rod at. I burned about 3 hours and 7 pounds of 6011 and 7018 (non-ovened) today, and had a blast.
Here's one side root pass (1/8 6011 135A) ![]() Second pass ![]() And third pass ![]() And here's the other side (didn't get pics of the passes) ![]() I know I need to work on aiming better, and I need to clean a bit better but that was done with a horseshoe brush and a chipping hammer. I didn't bevel the vertical piece but since it was a spring it had a rounded edge I had to fill on the root pass. Any words of wisdom? |
Re: Getting back into stick (pics)
seen alot worse, looks pretty good , keep up the practice and you'll have the slag peeling behind you again.
"Si Vis Pacem Para Bellum" (2)Lincoln 225AC/DC portables, Miller Syncrowave 300, miller sidekick,Lincoln Idealarc 250,Miller 251 Mig, Miller 30A spool gun, Hende lathe, Horizontal bandsaw, pora band ,14FT enclosed trailer.SA200's |
I forgot to add that the 2nd and third pass are 7018 1/8" at the same current.
My only suggestion is that I would run the second pass low instead of high like you did and let the 3rd pass sit on top of it. Let the last weld act as a shelf to help support the next one. Why fight gravity if you don't have to?
Looking good. Looks like it wont take that long to get back into.
![]() Did you find the 7018 easier to run than the 6011? Ive never tryed 6011 but ive heard that they usually dont produce a preatty bead.
Kemppi Pro Evolution 4200 ![]() Kemppi 530 wire feed with MXE panel Cigweld TransTig 200 AC/DC Hypertherm PowerMax45 CutSkill O/A setup Speedglas 9000x adflow Speedglas 9100xx 2 Labs All at home! |
Your getting there, keep at it!
OP i would think that 135 A is toomuch heat for 1/8 6010, but the root pass looks nice.looks like thick steel..
DSW i agree with you but someone i think farmersamm once posted from the lincoln book that shows the second pass on top... |
Bottom up.....
My name's not Jim.... Syncrowave 200 Millermatic 251 w/bottle mod Spoolmatic 30A Maxstar 150s Cutmaster 81 Jet JTM-1 mill Jet GH-1340-W3 lathe |
when you did your 3 pass fillet , shouldn't it be root ,bottom , top?
